I have tried to convert the VisionWorks stereoMatching into a ros package. I used the base from https://github.com/ShreyasSkandan/ros_tegra_stereo and replaced the single image concept with subscribing to left and right rectified images.
The code is running but all my disparity images are black with 0 values. I do not get any error on the code and the parameters I use are valid as well.
The main code which uses the stereoMatching from VisionWorks
using namespace message_filters;
using namespace sensor_msgs;
using namespace cv;
using namespace std;
#define IMG_WIDTH 1280 // change
#define IMG_HEIGHT 1024 // change
cv::Mat rmap[2][2];
vx_image left_rect;
vx_image right_rect;
vx_image disparity;
StereoMatching::StereoMatchingParams params;
ovxio::ContextGuard context;
StereoMatching::ImplementationType implementationType;
int counter_global = 0;
int baseline_opt;
vx_uint32 plane_index = 0;
vx_rectangle_t rect = {0u,0u,1280u,1024u}; // change
image_transport::Publisher pub;
image_transport::Publisher left_pcpub;
image_transport::Publisher right_pcpub;
static bool read(const std::string &nf, StereoMatching::StereoMatchingParams &config, std::string &message)
std::unique_ptr<nvxio::ConfigParser> parser(nvxio::createConfigParser());
parser->addParameter("min_disparity",
nvxio::OptionHandler::integer(
&config.min_disparity,
nvxio::ranges::atLeast(0) & nvxio::ranges::atMost(256)));
parser->addParameter("max_disparity",
&config.max_disparity,
parser->addParameter("P1",
&config.P1,
parser->addParameter("P2",
&config.P2,
parser->addParameter("sad",
&config.sad,
nvxio::ranges::atLeast(0) & nvxio::ranges::atMost(31)));
parser->addParameter("bt_clip_value",
&config.bt_clip_value,
nvxio::ranges::atLeast(15) & nvxio::ranges::atMost(95)));
parser->addParameter("max_diff",
&config.max_diff));
parser->addParameter("uniqueness_ratio",
&config.uniqueness_ratio,
nvxio::ranges::atLeast(0) & nvxio::ranges::atMost(100)));
parser->addParameter("scanlines_mask",
&config.scanlines_mask,
parser->addParameter("flags",
&config.flags,
nvxio::ranges::atLeast(0) & nvxio::ranges::atMost(3)));
parser->addParameter("ct_win_size",
&config.ct_win_size,
nvxio::ranges::atLeast(0) & nvxio::ranges::atMost(5)));
parser->addParameter("hc_win_size",
&config.hc_win_size,
message = parser->parse(nf);
return message.empty();
void callback(const ImageConstPtr& left, const ImageConstPtr& right) {
// conversion to rosmsgs::Image to cv::Mat using cv_bridge
nvx::Timer read_rect_timer;
read_rect_timer.tic();
cv_bridge::CvImagePtr cv_left;
try
cv_left = cv_bridge::toCvCopy(left);
catch (cv_bridge::Exception& e)
ROS_ERROR("cv_bridge exception: %s", e.what());
return;
cv_bridge::CvImagePtr cv_right;
try
cv_right = cv_bridge::toCvCopy(right);
return;
left_rect = nvx_cv::createVXImageFromCVMat(context,cv_left->image);
NVXIO_CHECK_REFERENCE(left_rect);
right_rect = nvx_cv::createVXImageFromCVMat(context,cv_right->image);
NVXIO_CHECK_REFERENCE(right_rect);
std::cout<<cv_left->image.rows<<" "<<cv_left->image.cols<<std::endl;
disparity = vxCreateImage(context, cv_left->image.cols, cv_left->image.rows, VX_DF_IMAGE_U8);
NVXIO_CHECK_REFERENCE(disparity);
std::unique_ptr<StereoMatching> stereo(StereoMatching::createStereoMatching(context,
params,implementationType,left_rect, right_rect, disparity));
stereo->run();
nvx_cv::VXImageToCVMatMapper map(disparity,0, NULL, VX_READ_AND_WRITE, VX_MEMORY_TYPE_HOST);
cv::Mat disp = map.getMat();
cv::imwrite("disparity.png",disp);
cv_bridge::CvImage out_disp;
out_disp.header = cv_left->header;
out_disp.encoding = sensor_msgs::image_encodings::MONO8;
out_disp.image = disp;
pub.publish(out_disp.toImageMsg());
//char savefilename[50];
//snprintf(savefilename,sizeof(savefilename),"/home/nvidia/saveddisp-3/disparity%05d.png",counter_global);
//counter_global = counter_global + 1;
//printf("%s",savefilename);
//cv::imwrite(savefilename,disp);
//cv::waitKey(1);
double timer = read_rect_timer.toc();
std::cout << "Time Elapsed For Rect + SGBM : " << timer << " ms" << std::endl << std::endl;
vxReleaseImage(&left_rect);
vxReleaseImage(&right_rect);
vxReleaseImage(&disparity);
int main(int argc, char **argv)
ros::init(argc, argv, "image_listener");
ros::NodeHandle nh;
std::string configFile = "/home/ubuntu/catkin_ws/src/ros_tegra_stereo/data/stereo_matching_params.ini"; // change
implementationType = StereoMatching::LOW_LEVEL_API;
std::string error;
if (!read(configFile, params, error)) {
std::cerr << error;
return 0;
std::cout << "SGBM Parameters loaded\n" ;
vxDirective(context, VX_DIRECTIVE_ENABLE_PERFORMANCE);
vxRegisterLogCallback(context, &ovxio::stdoutLogCallback, vx_false_e);
left_rect = vxCreateImage(context, IMG_WIDTH, IMG_HEIGHT, VX_DF_IMAGE_RGBX);
right_rect = vxCreateImage(context, IMG_WIDTH, IMG_HEIGHT, VX_DF_IMAGE_RGBX);
disparity = vxCreateImage(context, IMG_WIDTH, IMG_HEIGHT, VX_DF_IMAGE_U8);
image_transport::ImageTransport it(nh);
pub = it.advertise("/disparityimage",1); // change
message_filters::Subscriber<Image> left_sub(nh, "/camera/left/image_rect", 1);
message_filters::Subscriber<Image> right_sub(nh, "/camera/right/image_rect", 1);
//time syncronizer to publish 2 images in the same callback function
typedef sync_policies::ApproximateTime<Image, Image> MySyncPolicy;
Synchronizer<MySyncPolicy> sync(MySyncPolicy(1), left_sub, right_sub);
//TimeSynchronizer<Image, Image> sync(left_sub, right_sub, 50);
//call calback each time a new message arrives
sync.registerCallback(boost::bind(&callback, _1, _2));
ros::spin();
Since I subscribe to mono images in ROS, i commented out the color disparity option and kept the remaining code of stereo_matching from VisionWorks as default as well.
SGBM::SGBM(vx_context context, const StereoMatchingParams& params,
vx_image left, vx_image right, vx_image disparity)
vx_df_image format = VX_DF_IMAGE_VIRT;
vx_uint32 width = 0;
vx_uint32 height = 0;
vx_uint32 D = params.max_disparity - params.min_disparity;
NVXIO_SAFE_CALL( vxQueryImage(left, VX_IMAGE_ATTRIBUTE_FORMAT, &format, sizeof(format)) );
NVXIO_SAFE_CALL( vxQueryImage(left, VX_IMAGE_ATTRIBUTE_WIDTH, &width, sizeof(width)) );
NVXIO_SAFE_CALL( vxQueryImage(left, VX_IMAGE_ATTRIBUTE_HEIGHT, &height, sizeof(height)) );
main_graph_ = vxCreateGraph(context);
NVXIO_CHECK_REFERENCE(main_graph_);
vx_image left_gray = vxCreateVirtualImage(main_graph_, width, height, VX_DF_IMAGE_U8);
NVXIO_CHECK_REFERENCE(left_gray);
vx_image right_gray = vxCreateVirtualImage(main_graph_, width, height, VX_DF_IMAGE_U8);
NVXIO_CHECK_REFERENCE(right_gray);
//left_cvt_color_node_ = vxColorConvertNode(main_graph_, left, left_gray);
//NVXIO_CHECK_REFERENCE(left_cvt_color_node_);
//right_cvt_color_node_ = vxColorConvertNode(main_graph_, right, right_gray);
//NVXIO_CHECK_REFERENCE(right_cvt_color_node_);
vx_image left_census = NULL, right_census = NULL;
// apply census transform, if requested
if (params.ct_win_size > 1)
left_census = vxCreateVirtualImage(main_graph_, width, height, VX_DF_IMAGE_U32);
NVXIO_CHECK_REFERENCE(left_census);
right_census = vxCreateVirtualImage(main_graph_, width, height, VX_DF_IMAGE_U32);
NVXIO_CHECK_REFERENCE(right_census);
left_census_node_ = nvxCensusTransformNode(main_graph_, left_gray, left_census, params.ct_win_size);
NVXIO_CHECK_REFERENCE(left_census_node_);
right_census_node_ = nvxCensusTransformNode(main_graph_, right_gray, right_census, params.ct_win_size);
NVXIO_CHECK_REFERENCE(right_census_node_);
else
left_census_node_ = NULL;
right_census_node_ = NULL;
vx_image convolved_cost = vxCreateVirtualImage(main_graph_, width * D, height, VX_DF_IMAGE_U8);
NVXIO_CHECK_REFERENCE(convolved_cost);
// nvxConvolveCostNode can be seen as a simple "filtering" function for
// the evaluated cost volume. By setting the `sad` parameter to 1 we can
// omit it overall.
vx_int32 sad = params.sad;
if (sad > 1)
vx_image cost = vxCreateVirtualImage(main_graph_, width * D, height, VX_DF_IMAGE_U8);
NVXIO_CHECK_REFERENCE(cost);
// census transformed images should be compared by hamming cost
compute_cost_node_ = nvxComputeCostHammingNode(main_graph_, left_census, right_census, cost,
params.min_disparity, params.max_disparity,
params.hc_win_size);
else
compute_cost_node_ = nvxComputeModifiedCostBTNode(main_graph_, left_gray, right_gray, cost,
params.bt_clip_value);
NVXIO_CHECK_REFERENCE(compute_cost_node_);
convolve_cost_node_ = nvxConvolveCostNode(main_graph_, cost, convolved_cost,
D, sad);
NVXIO_CHECK_REFERENCE(convolve_cost_node_);
vxReleaseImage(&cost);
else
compute_cost_node_ = nvxComputeCostHammingNode(main_graph_, left_census, right_census, convolved_cost,
1);
else
compute_cost_node_ = nvxComputeModifiedCostBTNode(main_graph_, left_gray, right_gray, convolved_cost,
convolve_cost_node_ = NULL;
vx_image aggregated_cost = vxCreateVirtualImage(main_graph_, width * D, height, VX_DF_IMAGE_S16);
NVXIO_CHECK_REFERENCE(aggregated_cost);
aggregate_cost_scanlines_node_ = nvxAggregateCostScanlinesNode(main_graph_, convolved_cost, aggregated_cost,
D, params.P1, params.P2, params.scanlines_mask);
NVXIO_CHECK_REFERENCE(aggregate_cost_scanlines_node_);
vx_image disparity_short = vxCreateVirtualImage(main_graph_, width, height, VX_DF_IMAGE_S16);
NVXIO_CHECK_REFERENCE(disparity_short);
compute_disparity_node_ = nvxComputeDisparityNode(main_graph_, aggregated_cost, disparity_short,
params.uniqueness_ratio, params.max_diff);
NVXIO_CHECK_REFERENCE(compute_disparity_node_);
vx_int32 shift = 4;
vx_scalar s_shift = vxCreateScalar(context, VX_TYPE_INT32, &shift);
NVXIO_CHECK_REFERENCE(s_shift);
convert_depth_node_ = vxConvertDepthNode(main_graph_, disparity_short, disparity, VX_CONVERT_POLICY_SATURATE, s_shift);
NVXIO_CHECK_REFERENCE(convert_depth_node_);
vxReleaseScalar(&s_shift);
vxReleaseImage(&disparity_short);
vxReleaseImage(&aggregated_cost);
vxReleaseImage(&convolved_cost);javascript:void(0);
vxReleaseImage(&right_census);
vxReleaseImage(&left_census);
vxReleaseImage(&right_gray);
vxReleaseImage(&left_gray);
NVXIO_SAFE_CALL( vxVerifyGraph(main_graph_) );
Any suggestions of what I could be doing wrong? Thanks!
