Originally published at: https://developer.nvidia.com/blog/visualizing-depth-precision/
Discussion and diagrams to help you understand how nonlinear depth mapping works in different situations, intuitively and visually.
jwitsoe
1
Related topics
| Requesting ability to use double float for depth in drivers | 5 | 1029 | February 24, 2023 | |
| The ultimate remedy for z-fighting requires extension! | 1 | 3938 | September 1, 2014 | |
| Floating-point precision problems | 14 | 4621 | January 7, 2011 | |
| [BUG] depthlinear is not correct | 2 | 403 | June 20, 2022 | |
| Render to Far Plane (gl_Position.z = 1) | 2 | 1169 | March 31, 2017 | |
| Problems reading the z-buffer | 0 | 2037 | July 2, 2014 | |
| Does CUDA support 24bit float ? Try to use openGL depthbuffer in CUDA | 7 | 2170 | June 23, 2011 | |
| Inverse Depth Projection - Tutorial or code sample | 3 | 1073 | July 5, 2022 | |
| Vulkan wrong depth values | 15 | 198 | May 18, 2025 | |
| PtZDepth to meters? | 0 | 47 | August 30, 2024 |
