Vkcube: ~300 more FPS on XWayland vs Wayland
Hello there,
I have noticed that, on my system, using XWayland for Vulkan & OpenGL applications results on my dedicated NVIDIA GPU in much better performance than using Wayland. This also applies for DXVK & VKD3D (which means it affects games I play through Proton as well as native apps). I have reproduced the issue with vkcube (using the Xcb backend for XWayland). Here are my system specifications:
CPU: Intel Core i5-11400H
RAM: 2x8 GB DDR4 3200 MHz
GPU: NVIDIA GeForce RTX 3050 Laptop GPU
Driver version: 610.43.03
Operating system: Arch Linux
Kernel version: 7.1.3-arch1-2
Desktop environment: KDE Plasma 6.7.2
I have used the following commands to run vkcube:
MANGOHUD=1 MANGOHUD_CONFIG=test.conf vkcube --wsi xcb --present_mode 0
MANGOHUD=1 MANGOHUD_CONFIG=test.conf vkcube --wsi wayland --present_mode 0
Where test.conf just contains the output_folderoption for MangoHud so I can log the results. And speaking of logs, here are they:
XWayland:
vkcube_2026-07-10_17-23-50_summary.zip (405 Bytes)
Wayland:
vkcube_2026-07-10_17-24-20_summary.zip (406 Bytes)
I do have the complete MangoHud logs if that’s necessary. Here are screenshots that show the performance gap in real-time (first one is Wayland, second one is XWayland):
Finally, I have created two bug reports using nvidia-bug-report.sh, one for each case (XWayland and Wayland vkcube WSIs) when running vkcube:
nvidia-bug-report-wayland.log.gz (1.4 MB)
nvidia-bug-report-xwayland.log.gz (1.4 MB)
Although, the tool complained that mst and nvlsm-bug-report.sh weren’t present, I’m not sure if that’s important.
Finally, I’m happy to share any more information needed!
Side note: I have the KWIN_USE_OVERLAYS=1 environment variable set here (which I believe is set by default now). When setting it to 0, the GPU usage (and thus the FPS) spike up considerably, but there is still a wide performance gap between XWayland (~6000 FPS) vs. Wayland (~3000 FPS).
