Hi! I’m creating an image with the following information:
VkImageCreateInfo info =
VK_STRUCTURE_TYPE_IMAGE_CREATE_INFO,
NULL,
0,
height > 1 ? VK_IMAGE_TYPE_2D : VK_IMAGE_TYPE_1D,
vkformat,
extents,
mips,
cube ? numFaces : numImages,
VK_SAMPLE_COUNT_1_BIT,
VK_IMAGE_TILING_OPTIMAL,
VK_IMAGE_USAGE_SAMPLED_BIT,
VK_SHARING_MODE_CONCURRENT,
2,
queues,
VK_IMAGE_LAYOUT_PREINITIALIZED
Where in my case mips is 9, cube is false and numImages is 1, height is 256 and extents is 256, 256, 1. The memory is created using the VK_MEMORY_PROPERTY_DEVICE_LOCAL_BIT only. However, when running the following:
vkImageSubresource subres;
subres.arrayLayer = 0;
subres.aspectMask = VK_IMAGE_ASPECT_COLOR_BIT;
subres.mipLevel = mip;
VkSubresourceLayout layout;
vkGetImageSubresourceLayout(VkRenderDevice::dev, this->img, &subres, &layout);
‘layout’ becomes:
offset: 0
rowPitch: 0
arrayPitch: 89600
depthPitch: 89600
Basically I get no bytes per row, but I do get bytes per array layer, which is also bigger than the entire size of my image. Is the vkGetImageSubresourceLayout only available for certain types of images? The memoryTypeBits I get from vkGetImageMemoryRequirements is 2, and the two first memory properties are 0 and 1 respectively, so the only flags I can use when allocating image memory is either 0, or VK_MEMORY_PROPERTY_DEVICE_LOCAL_BIT.
Anyways, tested this on an AMD card and it works fine, I get a valid row, array and depth pitch for each mip level.
