vkWaitSemaphores pegs the thread while running
We have a vulkan application that uses a timeline semaphore to handle ensuring resources are done being used by the GPU before we start using them for a subsequent frame, which requires calling vkWaitSemaphores early in a frame.
I was very surprised to see that vkWaitSemaphores does not relinquish the thread, and instead seems to run sched_yield in a tight loop, pegging the core for the entire vkWaitSemaphores call. This info was gathered by perfetto, which gives scheduler insights & uses ftrace to show which syscalls happen when.
For this simple test app, almost the entire frame time is taken up by vkWaitSemaphores, but the thread is actually scheduled to a CPU during the whole time (see the “Running” bar above it). Zooming in, all the tiny blue bars are sched_yield syscalls, about 1/microsecond:
This is very surprising to me; waiting on a semaphore should not consume much CPU time, just wall time.
I’ve recorded a vulkan API capture with gfxreconstruct v0.9.11:
gfxrecon.zip (186.2 KB)
Which can be replayed with gfxrecon-replay. It seems to have the same behavior (high CPU usage with spurts of 1MHz sched_yield calls. We’re happy to attach a test application privately if it’s helpful.
I’ve tested the same app on a discrete nvidia GPU (linux, RTX 3050 Ti Mobile), which does not have the same issue (in fact, it doesn’t even spend any significant amount of wall time in vkWaitSemaphores, vsync wait time ends up in vkQueuePresent), as well on intel+linux.
I can’t think of something we’re doing wrong, and considering it works fine on other (even other nvidia) platforms, it seems possible it’s a driver bug.
L4T 36.4.3, Jetson Orin NX 8GB on Jetson Orin Nano devkit board, gnome desktop (X11).
Thanks for the help!
Thanks for the information. The low-level software stacks are separate for dGPU and Jetson platforms. It is possible certain functions work differently. We will check it while unifying the software stack in future Jetpack release.
I see, is that coming soon to jetpack?
It may take some time and not be present in near future.
I see–so is the current driver stack being maintained? Is there any hope of this issue being fixed?
