Jetson orin nx(16G) installed jetpack 6.0 can't use jtop
When checking the CPU status, it crashes and reports an error. Does anyone know why?
File “/usr/local/bin/jtop”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.10/dist-packages/jtop/main.py”, line 160, in main
curses.wrapper(JTOPGUI, jetson, pages, init_page=args.page,
File “/usr/lib/python3.10/curses/init.py”, line 94, in wrapper
return func(stdscr, *args, **kwds)
File “/usr/local/lib/python3.10/dist-packages/jtop/gui/jtopgui.py”, line 100, in init
self.run(loop, seconds)
File “/usr/local/lib/python3.10/dist-packages/jtop/gui/jtopgui.py”, line 129, in run
self.draw()
File “/usr/local/lib/python3.10/dist-packages/jtop/gui/jtopgui.py”, line 143, in draw
page.draw(self.key, self.mouse)
File “/usr/local/lib/python3.10/dist-packages/jtop/gui/pcpu.py”, line 138, in draw
step_height, step_width, size_columns, size_rows = cpu_grid(
File “/usr/local/lib/python3.10/dist-packages/jtop/gui/pcpu.py”, line 78, in cpu_grid
print_cpu(stdscr, idx, cpu, start_y + idx_row * step_height, start_x + idx_column * step_width, step_height - 1, step_width - 1)
File “/usr/local/lib/python3.10/dist-packages/jtop/gui/pcpu.py”, line 122, in print_cpu
freq = cpu[‘freq’]
KeyError: ‘freq’
We will check it. Please run sudo tegrastats to get the system status.
OK, thanks!
Is this?
09-03-2024 15:42:49 RAM 14115/15656MB (lfb 2x256kB) SWAP 951/7828MB (cached 0MB) CPU [8%@960,0%@960,0%@960,0%@960,off,off,off,off] EMC_FREQ 1%@2133 GR3D_FREQ 0%@[305] NVENC off NVDEC off NVJPG off NVJPG1 off VIC off OFA off NVDLA0 off NVDLA1 off PVA0_FREQ off APE 174 cv0@65.875C cpu@67.718C soc2@66.125C soc0@66.687C cv1@65.531C gpu@65.375C tj@67.468C soc1@67.218C cv2@65.031C VDD_IN 6476mW/6476mW VDD_CPU_GPU_CV 1105mW/1105mW VDD_SOC 2051mW/2051mW
09-03-2024 15:42:50 RAM 14116/15656MB (lfb 2x256kB) SWAP 951/7828MB (cached 0MB) CPU [1%@960,0%@960,8%@960,2%@960,off,off,off,off] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVENC off NVDEC off NVJPG off NVJPG1 off VIC off OFA off NVDLA0 off NVDLA1 off PVA0_FREQ off APE 174 cv0@65.625C cpu@67.5C soc2@66C soc0@66.625C cv1@65.312C gpu@65.218C tj@67.5C soc1@67.312C cv2@65C VDD_IN 6318mW/6397mW VDD_CPU_GPU_CV 947mW/1026mW VDD_SOC 2051mW/2051mW
09-03-2024 15:42:51 RAM 14115/15656MB (lfb 2x256kB) SWAP 951/7828MB (cached 0MB) CPU [9%@960,0%@960,0%@960,0%@960,off,off,off,off] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVENC off NVDEC off NVJPG off NVJPG1 off VIC off OFA off NVDLA0 off NVDLA1 off PVA0_FREQ off APE 174 cv0@65.625C cpu@67.437C soc2@66.031C soc0@66.5C cv1@65.25C gpu@65.218C tj@67.25C soc1@67.187C cv2@64.968C VDD_IN 6318mW/6370mW VDD_CPU_GPU_CV 947mW/999mW VDD_SOC 2051mW/2051mW
09-03-2024 15:42:52 RAM 14115/15656MB (lfb 2x256kB) SWAP 951/7828MB (cached 0MB) CPU [9%@883,0%@883,0%@883,0%@883,off,off,off,off] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[306] NVENC off NVDEC off NVJPG off NVJPG1 off VIC off OFA off NVDLA0 off NVDLA1 off PVA0_FREQ off APE 174 cv0@65.593C cpu@67.187C soc2@65.937C soc0@66.5C cv1@65.125C gpu@65.093C tj@67.187C soc1@67.125C cv2@64.718C VDD_IN 6318mW/6357mW VDD_CPU_GPU_CV 947mW/986mW VDD_SOC 2051mW/2051mW
09-03-2024 15:42:53 RAM 14115/15656MB (lfb 2x256kB) SWAP 951/7828MB (cached 0MB) CPU [9%@960,0%@960,0%@960,2%@960,off,off,off,off] EMC_FREQ 0%@2133 GR3D_FREQ 0%@[305] NVENC off NVDEC off NVJPG off NVJPG1 off VIC off OFA off NVDLA0 off NVDLA1 off PVA0_FREQ off APE 174 cv0@65.406C cpu@67.156C soc2@65.843C soc0@66.468C cv1@65.125C gpu@64.937C tj@67.156C soc1@67C cv2@64.718C VDD_IN 6318mW/6349mW VDD_CPU_GPU_CV 947mW/978mW VDD_SOC 2051mW/2051mW
Please try Jetpack 6.1 and latest jtop. And see if you still observe the issue.
Thanks very much. I have installed jetpack6.1. I would like to ask an off-topic question: Is there a pytorch version corresponding to jetpack6.1 (cuda12.6)?
Please open a new topic, thanks
