通过v4l2-ctl --set-fmt-video=width=3840,height=2160 --set-ctrl bypass_mode=0 --stream-mmap设置没有返回
我通过dmesg查看打印,有报错:
[  11.484711] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[  11.493104] hvc_sysfs: hypervisor is not present
[  11.533342] ALSA device list:
[  11.536392]  No soundcards found.
[  11.540529] Freeing unused kernel memory: 3968K
[  11.545262] Run /init as init process
[  11.549027]  with arguments:
[  11.549027]    /init
[  11.549028]    nv-auto-config
[  11.549029]  with environment:
[  11.549030]    HOME=/
[  11.549031]    TERM=linux
[  11.549032]    mminit_loglevel=4
[  11.561476] Root device found: PARTUUID=ef880900-aa07-49b8-8ad7-808c4b55f158
[  11.867817] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[  11.878718] Rootfs mounted over PARTUUID=ef880900-aa07-49b8-8ad7-808c4b55f158
[  11.890588] random: crng init done
[  11.898077] Switching from initrd to actual rootfs
[  11.948909] systemd[1]: System time before build time, advancing clock.
[  11.994144] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[  12.015245] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[  12.017792] systemd[1]: Detected architecture arm64.
[  12.060386] systemd[1]: Set hostname to .
[  12.176546] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[  12.189578] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[  12.199162] systemd[1]: Created slice system-modprobe.slice.
[  12.220519] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  12.240493] systemd[1]: Created slice User and Session Slice.
[  12.260340] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  12.284518] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  12.308321] systemd[1]: Reached target User and Group Name Lookups.
[  12.328280] systemd[1]: Reached target Slices.
[  12.344273] systemd[1]: Reached target Mounting snaps.
[  12.364266] systemd[1]: Reached target Mounted snaps.
[  12.384271] systemd[1]: Reached target Swap.
[  12.400500] systemd[1]: Listening on RPCbind Server Activation Socket.
[  12.420377] systemd[1]: Listening on Syslog Socket.
[  12.436371] systemd[1]: Listening on fsck to fsckd communication Socket.
[  12.460325] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  12.484471] systemd[1]: Listening on Journal Audit Socket.
[  12.504357] systemd[1]: Listening on Journal Socket (/dev/log).
[  12.524387] systemd[1]: Listening on Journal Socket.
[  12.544387] systemd[1]: Listening on udev Control Socket.
[  12.564341] systemd[1]: Listening on udev Kernel Socket.
[  12.585304] systemd[1]: Mounting Huge Pages File System…
[  12.605226] systemd[1]: Mounting POSIX Message Queue File System…
[  12.625173] systemd[1]: Mounting RPC Pipe File System…
[  12.645211] systemd[1]: Mounting Kernel Debug File System…
[  12.665195] systemd[1]: Mounting Kernel Trace File System…
[  12.685473] systemd[1]: Starting Journal Service…
[  12.705575] systemd[1]: Starting Set the console keyboard layout…
[  12.729458] systemd[1]: Starting Create list of static device nodes for the current kernel…
[  12.757346] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[  12.780338] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[  12.789758] systemd[1]: Starting Load Kernel Module efi_pstore…
[  12.809322] systemd[1]: Starting Load Kernel Module pstore_blk…
[  12.829229] systemd[1]: Starting Load Kernel Module pstore_zone…
[  12.853180] systemd[1]: Starting Load Kernel Module ramoops…
[  12.877220] systemd[1]: Starting NVIDIA specific first-boot udev script…
[  12.905281] systemd[1]: Started Nameserver information manager.
[  12.924424] systemd[1]: Reached target Network (Pre).
[  12.944635] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[  12.953984] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[  12.965070] systemd[1]: Starting Load Kernel Modules…
[  12.976277] nvmap_heap_init: nvmap_heap_init: created heap block cache
[  12.983550] nvmap_page_pool_init: Total RAM pages: 1878203
[  12.989221] nvmap_page_pool_init: nvmap page pool size: 234775 pages (917 MB)
[  12.996776] nvmap_background_zero_thread: PP zeroing thread starting.
[  13.005378] systemd[1]: Starting Remount Root and Kernel File Systems…
[  13.012829] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[  13.030919] nvgpu: 17000000.ga10b         nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[  13.049531] systemd[1]: Starting udev Coldplug all Devices…
[  13.074126] systemd[1]: Started Journal Service.
[  13.378942] systemd-journald[259]: Received client request to flush runtime journal.
[  13.880863] nvidia: loading out-of-tree module taints kernel.
[  13.905486] nv_platform 13800000.display: Adding to iommu group 53
[  13.908934] platform 13800000.display:nvdisplay-niso: Adding to iommu group 54
[  13.919431] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.3.1 Release Build (buildbrain@mobile-u64-6289-d7000) Sun Mar 19 08:09:33 PDT 2023
[  13.938861] spi-tegra114 3210000.spi: Adding to iommu group 2
[  13.950958] spi-tegra114 3230000.spi: Adding to iommu group 2
[  13.953993] imx477 9-001a: tegracam sensor driver:imx477_v2.0.6
[  13.966865] tegra-hda 3510000.hda: Adding to iommu group 55
[  13.970924] r8169 0008:01:00.0: Adding to iommu group 11
[  13.971300] r8169 0008:01:00.0: enabling device (0000 → 0003)
[  13.998889] nvadsp 2993000.adsp: Adding to iommu group 56
[  14.000831] nvadsp 2993000.adsp: in probe()…
[  14.003694] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[  14.004692] nvadsp 2993000.adsp: nvadsp_app_module_probe
[  14.023376] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 56
[  14.023457] tegra210_adsp_audio_probe: platform probe started
[  14.023708] r8169 0008:01:00.0 eth0: RTL8168h/8111h, 48:b0:2d:d8:cb:48, XID 541, IRQ 305
[  14.023714] r8169 0008:01:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[  14.027093] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[  14.028451] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[  14.029713] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[  14.030652] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[  14.030916] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[  14.031099] irq: IRQ307: trimming hierarchy from :pmc@c360000
[  14.031168] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[  14.031173] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[  14.031175] tegra210-adsp tegra210-adsp: using adma channel page 0
[  14.031280] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input6
[  14.031283] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[  14.031371] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input7
[  14.031448] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input8
[  14.031516] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input9
[  14.038170] fusb301 1-0025: failed to read device id, err : 0xffffff87
[  14.051052] cpu-throttle-alert cooling device registered.
[  14.056298] fusb301 1-0025: fusb301 not support
[  14.061046] gpu-throttle-alert cooling device registered.
[  14.061229] fusb301: probe of 1-0025 failed with error -22
[  14.067390] cv0-throttle-alert cooling device registered.
[  14.067729] cv1-throttle-alert cooling device registered.
[  14.068010] cv2-throttle-alert cooling device registered.
[  14.068675] soc0-throttle-alert cooling device registered.
[  14.069517] soc1-throttle-alert cooling device registered.
[  14.069905] soc2-throttle-alert cooling device registered.
[  14.070222] hot-surface-alert cooling state: 0 → 1
[  14.092513] hot-surface-alert cooling device registered.
[  14.113845] tegra-asoc: sound: Adding to iommu group 56
[  14.255017] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx477 9-001a bound
[  14.256326] imx477 10-001a: tegracam sensor driver:imx477_v2.0.6
[  14.290297] cryptd: max_cpu_qlen set to 1000
[  14.435848] tegra210-adsp tegra210-adsp: Loaded app wire
[  14.435854] tegra210-adsp tegra210-adsp: Loaded app apm
[  14.435856] tegra210-adsp tegra210-adsp: Loaded app adma
[  14.435858] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[  14.435862] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000908cc7f1
[  14.462369] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[  14.557364] imx477 10-001a: imx477_board_setup: error during i2c read probe (-121)
[  14.565200] imx477 10-001a: board setup failed
[  14.571949] imx477: probe of 10-001a failed with error -121
[  14.859699] using random self ethernet address
[  14.866953] using random host ethernet address
[  15.148642] loop: module loaded
[  15.331538] Mass Storage Function, version: 2009/09/11
[  15.331545] LUN: removable file: (no medium)
[  15.336096] using random self ethernet address
[  15.342076] using random host ethernet address
[  15.356069] rndis0: HOST MAC 56:8c:5f:6b:66:38
[  15.356081] rndis0: MAC 56:8c:5f:6b:66:39
[  15.357066] usb0: HOST MAC 56:8c:5f:6b:66:3a
[  15.357075] usb0: MAC 56:8c:5f:6b:66:3b
[  15.358006] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[  15.360883] l4tbr0: port 1(rndis0) entered blocking state
[  15.360907] l4tbr0: port 1(rndis0) entered disabled state
[  15.361041] device rndis0 entered promiscuous mode
[  15.366183] l4tbr0: port 2(usb0) entered blocking state
[  15.366196] l4tbr0: port 2(usb0) entered disabled state
[  15.366322] device usb0 entered promiscuous mode
[  15.632286] Generic FE-GE Realtek PHY r8169-8-100:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-8-100:00, irq=IGNORE)
[  15.832406] r8169 0008:01:00.0 eth0: Link is Down
[  16.769516] pstore: Using crash dump compression: deflate
[  16.769552] printk: console [ramoops-1] enabled
[  16.769554] pstore: Registered ramoops as persistent store backend
[  16.769556] ramoops: using 0x200000@0x268000000, ecc: 0
[  16.858068] CPU4: shutdown
[  16.860972] psci: CPU4 killed (polled 0 ms)
[  16.898410] CPU5: shutdown
[  16.901289] psci: CPU5 killed (polled 0 ms)
[  16.934145] nvgpu: 17000000.ga10b                tpc_pg_mask_store:1067 [INFO] no value change, same mask already set
[  17.081965] nvgpu: 17000000.ga10b                 gk20a_scale_init:539 [INFO] enabled scaling for GPU
[  17.260217] zram: Added device: zram0
[  17.263716] zram: Added device: zram1
[  17.275271] zram: Added device: zram2
[  17.280438] zram: Added device: zram3
[  17.351405] zram0: detected capacity change from 0 to 961642496
[  17.380297] Adding 939100k swap on /dev/zram0. Priority:5 extents:1 across:939100k SS
[  17.384009] zram1: detected capacity change from 0 to 961642496
[  17.432609] Adding 939100k swap on /dev/zram1. Priority:5 extents:1 across:939100k SS
[  17.434645] zram2: detected capacity change from 0 to 961642496
[  17.468314] Adding 939100k swap on /dev/zram2. Priority:5 extents:1 across:939100k SS
[  17.470454] zram3: detected capacity change from 0 to 961642496
[  17.512409] Adding 939100k swap on /dev/zram3. Priority:5 extents:1 across:939100k SS
[  18.158404] fuse: init (API version 7.32)
[  18.309647] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.3.1 Release Build (buildbrain@mobile-u64-6289-d7000) Sun Mar 19 08:09:35 PDT 2023
[  18.542787] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
[  18.543925] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
[  18.549279] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[  18.629225] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[  18.629751] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
[  19.423577] r8169 0008:01:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[  19.423632] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  25.475228] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
