Question ConnectX-4
- Dose it support an RS-FEC mode in 25GbE mode?
- Dose it support single-mode SFP?
A. If it does, why it supports only multi-mode SFP?
B. How can it scan the mode of SFP (multi-mode or single-mode)? If it judged by SFP DDM (two wire) register, could you tell me which bytes is reference? - We use your product as a monitoring and capturing network traffic, but when I capture packets using Wireshark program, it does not display VLAN tag
Information. I guess that ConnectX-4 remove the VLAN tag. Many NIC chipset maker offer the method to capture VLAN tag using registry value setting.
Is it possible in ConnectX-4?
