First time user and jumping full in on learning all thing AI and llms.
Below is my first crack of getting a model running on the DGX Spark and then exposed via a nginx proxy to an openwebui instance I have running.
Everything is working and I see no glaring errors in the container logs. However, I’m looking for suggestions on what I can improve or should tune regarding this config.
Furthermore for a model of this size is it expected to take over 100GB of RAM? I was under impression it should use less based on the 20b parameter size, or do I need to put some additional config in place to ensure it does not consume everything so that I can also test with a coder model and a model for RAG in parallel?
services:
vllm:
image: nvcr.io/nvidia/vllm:25.09-py3
container_name: vllm
command:
- vllm
- serve
- openai/gpt-oss-20b
networks:
llm:
proxy:
# ports:
# - "8000:8000"
volumes:
- /home/chris/models/vllm_cache_huggingface:/root/.cache/huggingface # Cache Hugging Face models
- /home/chris/models/manual_download:/models # mount your home directory models folder
- /home/chris/models/manual_download/openai_gpt-oss-encodings_fix/cl100k_base.tiktoken:/etc/encodings/cl100k_base.tiktoken # openai fix
- /home/chris/models/manual_download/openai_gpt-oss-encodings_fix/o200k_base.tiktoken:/etc/encodings/o200k_base.tiktoken # openai fix
environment:
# openai gpt-oss-20b/120b fix 10/25/25
- TIKTOKEN_ENCODINGS_BASE=/etc/encodings
# Explicitly tell Hugging Face to use default directory as of 10/25/25.
- HF_HOME=/root/.cache/huggingface
# - HUGGING_FACE_HUB_TOKEN=${HF_TOKEN} # Optional: if you need to download private models
- VLLM_API_KEY=${API_KEY} # Optional: for API key authentication
deploy:
resources:
reservations:
devices:
- driver: nvidia
count: "all"
capabilities: ["gpu"]
ulimits:
memlock: -1
stack: 67108864
ipc: host
restart: unless-stopped
tty: true
networks:
llm:
proxy:
external: true
