When we want to start a VM on ESXi we get the message:
Could not initialize plugin ‘/usr/lib64/vmware/plugin/libnvidia-vgx.so’ for vGPU ‘nvidia_a40-1b’.
VMware ESXi, 6.7.0, 19195723
Model: PowerEdge R750 with 2x A40 ECC disabled / SR-IVO enabled
NVIDIA-SMI 470.82 Driver Version: 470.82 CUDA Version: N/A |
| | | MIG M. |
| 0 NVIDIA A40 On | 00000000:17:00.0 Off | Off |
| 0% 28C P8 31W / 300W | 0MiB / 48687MiB | 0% Default |
| | | N/A |
| 1 NVIDIA A40 On | 00000000:CA:00.0 Off | Off |
| 0% 27C P8 31W / 300W | 0MiB / 48687MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Does anyone know this error?
Output from nvidia-smi -q:
==============NVSMI LOG==============
Timestamp : Mon Jan 31 10:31:42 2022
Driver Version : 470.82
CUDA Version : Not Found
Attached GPUs : 2
GPU 00000000:17:00.0
Product Name : NVIDIA A40
Product Brand : NVIDIA
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : Enabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Enabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 1323721106657
GPU UUID : GPU-b1142892-1049-9944-c936-bdc6c4c59986
Minor Number : 0
VBIOS Version : 94.02.5C.00.03
MultiGPU Board : No
Board ID : 0x1700
GPU Part Number : 900-2G133-0100-030
Module ID : 0
Inforom Version
Image Version : G133.0200.00.05
OEM Object : 2.0
ECC Object : 6.16
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : Host VGPU
Host VGPU Mode : SR-IOV
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x17
Device : 0x00
Domain : 0x0000
Device Id : 0x223510DE
Bus Id : 00000000:17:00.0
Sub System Id : 0x145A10DE
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : 0 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 48687 MiB
Used : 0 MiB
Free : 48687 MiB
BAR1 Memory Usage
Total : 65536 MiB
Used : 1 MiB
Free : 65535 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 28 C
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 88 C
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 31.56 W
Power Limit : 300.00 W
Default Power Limit : 300.00 W
Enforced Power Limit : 300.00 W
Min Power Limit : 100.00 W
Max Power Limit : 300.00 W
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 555 MHz
Applications Clocks
Graphics : 1740 MHz
Memory : 7251 MHz
Default Applications Clocks
Graphics : 1740 MHz
Memory : 7251 MHz
Max Clocks
Graphics : 1740 MHz
SM : 1740 MHz
Memory : 7251 MHz
Video : 1530 MHz
Max Customer Boost Clocks
Graphics : 1740 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 712.500 mV
Processes : None
Strange output in vCenter:
In case anyone comes across this, ESXi 6.7.0 only supports A40 in pass-through mode, not NVIDIA vGPU. You’ll need to upgrade to 7.0.2+, then your graphics devices will appear properly and then you can use NVIDIA vGPU.
