sbor
June 25, 2018, 6:33pm
1
I am trying to run inference on Jetson TX2 for an image segmentation DNN. The network was written in TensorFlow. I was able to convert the trained network to UFF file, but when I try to create TensorRT engine following SampleUffMnist example (replacing the UFF file with mine and changing input and output node names), I get this error:
ERROR: UFFParser: Parser error: Reshape_1: Reshape: Volume mismatch
ERROR: sample_uff_mnist: Fail to parse
ERROR: sample_uff_mnist: Model load failed
What does this error mean and how can I resolve it?
The volume mismatch error means that the reshape operation you are trying to perform on a tensor does not retain the same volume (as it must).
For example, you can reshape a tensor from 1,3,3 to 9,1,1 (the volume is 9 in both cases) but you will get this error if you try to reshape 1,3,3 to 2,2,2 (volume 9 to volume 8).
We suspect there is a mismatch between the network and your dimension specification.
Please double check it.
sbor
June 26, 2018, 6:40pm
3
Hello AastaLL,
Thank you for your response. I attached a capture of the part of my network contianing Reshape_1 part. It shows input to reshape being 32x28x28x2, and output 25088x2, which seems to be the same volume? My network uses “tf.reshape(tensor,[-1, 2])” to do reshape, which does preserve volume. What else do I need to look at in this case?
I also attached the graph I am using in case that might be helpful.
graph_optimized_test.pb.tar.gz (6.62 MB)
We need more information to debug this issue.
Could you try to collect info-level log and share with us?
gLogger = Logger(nvinfer1::ILogger::Severity::kINFO);
sbor
June 29, 2018, 5:48pm
5
Here is the full output:
INFO: UFFParser: parsing Reshape
INFO: UFFParser: parsing conv2d/kernel
INFO: UFFParser: parsing cnn_conv_A1c/conv2d/Conv2D
INFO: UFFParser: parsing conv2d/bias
INFO: UFFParser: parsing cnn_conv_A1c/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization/gamma
INFO: UFFParser: parsing batch_normalization/beta
INFO: UFFParser: parsing batch_normalization/moving_mean
INFO: UFFParser: parsing batch_normalization/moving_variance
INFO: UFFParser: parsing cnn_conv_A1c/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_A1c/Relu
INFO: UFFParser: parsing conv2d_1/kernel
INFO: UFFParser: parsing cnn_conv_A2c/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_1/bias
INFO: UFFParser: parsing cnn_conv_A2c/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_1/gamma
INFO: UFFParser: parsing batch_normalization_1/beta
INFO: UFFParser: parsing batch_normalization_1/moving_mean
INFO: UFFParser: parsing batch_normalization_1/moving_variance
INFO: UFFParser: parsing cnn_conv_A2c/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_A2c/Relu
INFO: UFFParser: parsing max_pooling2d/MaxPool
INFO: UFFParser: parsing conv2d_2/kernel
INFO: UFFParser: parsing cnn_conv_B1c/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_2/bias
INFO: UFFParser: parsing cnn_conv_B1c/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_2/gamma
INFO: UFFParser: parsing batch_normalization_2/beta
INFO: UFFParser: parsing batch_normalization_2/moving_mean
INFO: UFFParser: parsing batch_normalization_2/moving_variance
INFO: UFFParser: parsing cnn_conv_B1c/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_B1c/Relu
INFO: UFFParser: parsing conv2d_3/kernel
INFO: UFFParser: parsing cnn_conv_B2c/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_3/bias
INFO: UFFParser: parsing cnn_conv_B2c/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_3/gamma
INFO: UFFParser: parsing batch_normalization_3/beta
INFO: UFFParser: parsing batch_normalization_3/moving_mean
INFO: UFFParser: parsing batch_normalization_3/moving_variance
INFO: UFFParser: parsing cnn_conv_B2c/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_B2c/Relu
INFO: UFFParser: parsing max_pooling2d_1/MaxPool
INFO: UFFParser: parsing conv2d_4/kernel
INFO: UFFParser: parsing cnn_conv_E1/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_4/bias
INFO: UFFParser: parsing cnn_conv_E1/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_4/gamma
INFO: UFFParser: parsing batch_normalization_4/beta
INFO: UFFParser: parsing batch_normalization_4/moving_mean
INFO: UFFParser: parsing batch_normalization_4/moving_variance
INFO: UFFParser: parsing cnn_conv_E1/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_E1/Relu
INFO: UFFParser: parsing conv2d_5/kernel
INFO: UFFParser: parsing cnn_conv_E2/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_5/bias
INFO: UFFParser: parsing cnn_conv_E2/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_5/gamma
INFO: UFFParser: parsing batch_normalization_5/beta
INFO: UFFParser: parsing batch_normalization_5/moving_mean
INFO: UFFParser: parsing batch_normalization_5/moving_variance
INFO: UFFParser: parsing cnn_conv_E2/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_E2/Relu
INFO: UFFParser: parsing conv2d_transpose/kernel
INFO: UFFParser: parsing conv2d_transpose/Shape
INFO: UFFParser: parsing conv2d_transpose/strided_slice/stack
INFO: UFFParser: parsing conv2d_transpose/strided_slice/stack_1
INFO: UFFParser: parsing conv2d_transpose/strided_slice/stack_2
INFO: UFFParser: parsing conv2d_transpose/strided_slice_1/stack
INFO: UFFParser: parsing conv2d_transpose/strided_slice_1/stack_1
INFO: UFFParser: parsing conv2d_transpose/strided_slice_1/stack_2
INFO: UFFParser: parsing conv2d_transpose/mul/y
INFO: UFFParser: parsing conv2d_transpose/add/y
INFO: UFFParser: parsing conv2d_transpose/strided_slice_2/stack
INFO: UFFParser: parsing conv2d_transpose/strided_slice_2/stack_1
INFO: UFFParser: parsing conv2d_transpose/strided_slice_2/stack_2
INFO: UFFParser: parsing conv2d_transpose/mul_1/y
INFO: UFFParser: parsing conv2d_transpose/add_1/y
INFO: UFFParser: parsing conv2d_transpose/stack/3
INFO: UFFParser: parsing conv2d_transpose/conv2d_transpose
INFO: UFFParser: parsing conv2d_transpose/bias
INFO: UFFParser: parsing conv2d_transpose/BiasAdd
INFO: UFFParser: parsing concat
INFO: UFFParser: parsing conv2d_6/kernel
INFO: UFFParser: parsing cnn_conv_B1e/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_6/bias
INFO: UFFParser: parsing cnn_conv_B1e/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_6/gamma
INFO: UFFParser: parsing batch_normalization_6/beta
INFO: UFFParser: parsing batch_normalization_6/moving_mean
INFO: UFFParser: parsing batch_normalization_6/moving_variance
INFO: UFFParser: parsing cnn_conv_B1e/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_B1e/Relu
INFO: UFFParser: parsing conv2d_7/kernel
INFO: UFFParser: parsing cnn_conv_B2e/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_7/bias
INFO: UFFParser: parsing cnn_conv_B2e/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_7/gamma
INFO: UFFParser: parsing batch_normalization_7/beta
INFO: UFFParser: parsing batch_normalization_7/moving_mean
INFO: UFFParser: parsing batch_normalization_7/moving_variance
INFO: UFFParser: parsing cnn_conv_B2e/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_B2e/Relu
INFO: UFFParser: parsing conv2d_transpose_1/kernel
INFO: UFFParser: parsing conv2d_transpose_1/Shape
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice/stack
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice/stack_1
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice/stack_2
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice_1/stack
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice_1/stack_1
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice_1/stack_2
INFO: UFFParser: parsing conv2d_transpose_1/mul/y
INFO: UFFParser: parsing conv2d_transpose_1/add/y
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice_2/stack
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice_2/stack_1
INFO: UFFParser: parsing conv2d_transpose_1/strided_slice_2/stack_2
INFO: UFFParser: parsing conv2d_transpose_1/mul_1/y
INFO: UFFParser: parsing conv2d_transpose_1/add_1/y
INFO: UFFParser: parsing conv2d_transpose_1/stack/3
INFO: UFFParser: parsing conv2d_transpose_1/conv2d_transpose
INFO: UFFParser: parsing conv2d_transpose_1/bias
INFO: UFFParser: parsing conv2d_transpose_1/BiasAdd
INFO: UFFParser: parsing concat_1
INFO: UFFParser: parsing conv2d_8/kernel
INFO: UFFParser: parsing cnn_conv_A1e/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_8/bias
INFO: UFFParser: parsing cnn_conv_A1e/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_8/gamma
INFO: UFFParser: parsing batch_normalization_8/beta
INFO: UFFParser: parsing batch_normalization_8/moving_mean
INFO: UFFParser: parsing batch_normalization_8/moving_variance
INFO: UFFParser: parsing cnn_conv_A1e/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_A1e/Relu
INFO: UFFParser: parsing conv2d_9/kernel
INFO: UFFParser: parsing cnn_conv_A2e/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_9/bias
INFO: UFFParser: parsing cnn_conv_A2e/conv2d/BiasAdd
INFO: UFFParser: parsing batch_normalization_9/gamma
INFO: UFFParser: parsing batch_normalization_9/beta
INFO: UFFParser: parsing batch_normalization_9/moving_mean
INFO: UFFParser: parsing batch_normalization_9/moving_variance
INFO: UFFParser: parsing cnn_conv_A2e/batch_normalization/FusedBatchNorm
INFO: UFFParser: parsing cnn_conv_A2e/Relu
INFO: UFFParser: parsing conv2d_10/kernel
INFO: UFFParser: parsing output_score/conv2d/Conv2D
INFO: UFFParser: parsing conv2d_10/bias
INFO: UFFParser: parsing output_score/conv2d/BiasAdd
INFO: UFFParser: parsing output_score/output_relu
INFO: UFFParser: parsing Reshape_1/shape
Thank you
In TensorRT 3.0, reshape applies only on constant weights.
Tensor reshape is automatically dropped when importing it from UFF to TensorRT engine.
Since TensorRT supports multiple inputs/outputs.
A quick workaround is to use multiple outputs and receive output_score separately
Hello, Aastalll,
Could you give an explanation about how TensorRT engine works when encounter a fully connection layers, which have to use reshape operation to reshape the features to flatten. and it indeed works for tensorRT3.0.
