I wrote a network which include a concat layer, and after that , an error raised caused by Order size not matching.
add_denseblock can be used for training and generate pb file, but can not convert to tensorrt engine.
def instance_norm(x, w, h, n_features, training):
with tf.variable_scope('instance_norm') as scope:
_BATCH_NORM_DECAY = 0.997
print("instance_norm x.shape: ", x.shape)
x_reshaped = tf.reshape(x, [-1, w*h, n_features])
x_reshaped = tf.reshape(x, [-1, w*h, n_features//3, 3])
#x_reshaped = tf.transpose(x_reshaped, [0, 2, 3, 1])
y = tf.layers.batch_normalization(
inputs=x_reshaped, axis=1,
momentum=_BATCH_NORM_DECAY, epsilon=1e-3, center=True,
scale=True, training=training, fused=True)
#y = tf.transpose(y, [0, 3, 1, 2])
y = tf.reshape(y, [-1, w*h, n_features])
y_reshape = tf.reshape(y, [-1, w, h, n_features])
return y_reshape
def conv2d_reflct(input,
input_filters,
output_filters,
kernel,
strides,
mode='REFLECT'):
add REFLECT padding and then conv2d
with tf.variable_scope('conv') as scope:
if kernel == 1:
input_pad = input
else:
pass
input_pad = tf.pad(tensor = input,
paddings = [[int(0),int(0)],
[int(kernel / 2), int(kernel / 2)],
[int(0),int(0)]],
name = 'input_pad')
shape = [kernel, kernel, input_filters, output_filters]
weight = tf.Variable(tf.truncated_normal(shape=shape,
mean=0.0,
stddev=0.1),
name = 'weight')
return tf.nn.conv2d(input = input_pad,
filter = weight,
strides = [1, strides, strides, 1],
padding = "VALID",
name = 'conv')
def composite_function(_input, w, h, c, out_features, training, kernel_size=3):
with tf.variable_scope("composite_function"):
# BN
# output = batch_norm(_input, is_training)
# ReLU
output = tf.nn.relu(_input)
# convolution
#in_features = int(output.get_shape()[-1])
in_features = c
output = conv2d_reflct(input=output,
input_filters=in_features,
output_filters=out_features,
kernel=kernel_size,
strides=1,
mode="REFLECT")
output = instance_norm(output, w, h, out_features, training)
# no dropout for style transfer
return output
def bottleneck(_input, in_features, out_features, is_training=False):
with tf.variable_scope("bottleneck"):
inter_features = out_features * 4
# in_features = int(output.get_shape()[-1])
in_features = in_features
print("bottleneck:shape:",output.shape)
output_filters=inter_features,
kernel=1,
strides=1,
mode="REFLECT")
print(output.shape)
return output, inter_features
def add_internal_layer(_input, w, h, c, growth_rate, training):
temp_c = c
# call composite_function with 3x3 kernel
print("add_internal_layer:_input:shape:", _input.shape)
bottleneck_out, c = bottleneck(_input,
in_features=c,
out_features=GROWTH_RATE,
is_training=training)
print("add_internal_layer:bottleneck_out:shape:", bottleneck_out.shape)
comp_out = composite_function(bottleneck_out, w, h, c,
kernel_size=3,
training=training)
print("add_internal_layer:comp_out:shape:", comp_out.shape)
output = tf.concat(axis=3, values=(_input, comp_out))
print("add_internal_layer:output:shape:", output.shape)
c = temp_c + GROWTH_RATE
return output, c
def add_denseblock(_input, w, h, c, growth_rate, layers_per_block, training):
output = _input
for layer in range(layers_per_block):
with tf.variable_scope("layer_%d" % layer):
output, c = add_internal_layer(output, w, h, c, growth_rate,
training=training)
return output
[TensorRT] INFO: UFFParser: parsing x
[TensorRT] INFO: UFFParser: parsing generator/dmux1/dmux/Reshape/shape
[TensorRT] INFO: UFFParser: parsing generator/dmux1/dmux/transpose
[TensorRT] INFO: UFFParser: parsing generator/dmux1/dmux/Reshape_1/shape
[TensorRT] INFO: UFFParser: parsing generator/dmux1/dmux/transpose_1
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/Reshape/shape
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/batch_normalization/gamma
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/batch_normalization/beta
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/batch_normalization/moving_mean
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/batch_normalization/moving_variance
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/batch_normalization/FusedBatchNorm
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/Reshape_1/shape
[TensorRT] INFO: UFFParser: parsing generator/dmux1/instance_norm/Reshape_2/shape
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/bottleneck/Relu
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/bottleneck/conv/weight
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/bottleneck/conv/conv
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/Relu
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/conv/weight
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/conv/conv
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/Reshape/shape
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/batch_normalization/gamma
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/batch_normalization/beta
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/batch_normalization/moving_mean
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/batch_normalization/moving_variance
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/batch_normalization/FusedBatchNorm
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/Reshape_1/shape
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/composite_function/instance_norm/Reshape_2/shape
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_0/concat
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_1/bottleneck/Relu
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_1/bottleneck/conv/weight
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_1/bottleneck/conv/conv
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_1/composite_function/Relu
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_1/composite_function/conv/weight
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_1/composite_function/conv/conv
[TensorRT] INFO: UFFParser: parsing generator/denseblock1/layer_1/composite_function/instance_norm/Reshape/shape
[TensorRT] ERROR: generator/denseblock1/layer_1/bottleneck/conv/conv: kernel weights has count 1152 but 576 was expected
[TensorRT] ERROR: UFFParser: Parser error: generator/denseblock1/layer_1/composite_function/instance_norm/Reshape: Order size is not matching the number dimensions of TensorRT
[TensorRT] ERROR: Failed to parse UFF model stream
File “/home/wang/.local/lib/python2.7/site-packages/tensorrt/utils/_utils.py”, line 255, in uff_to_trt_engine
assert(parser.parse(stream, network, model_datatype))
File “/home/wang/Downloads/aifilter2_tf_copy/convert.py”, line 81, in
create_and_save_inference_engine()
File “/home/wang/Downloads/aifilter2_tf_copy/convert.py”, line 60, in create_and_save_inference_engine
trt.infer.DataType.FLOAT
File “/home/wang/.local/lib/python2.7/site-packages/tensorrt/utils/_utils.py”, line 263, in uff_to_trt_engine
raise AssertionError(‘UFF parsing failed on line {} in statement {}’.format(line, text))
AssertionError: UFF parsing failed on line 255 in statement assert(parser.parse(stream, network, model_datatype))
Process finished with exit code 1
this error happened after a concat layer, can anyone give any suggestion.
concat_error.zip (1.38 MB)
