use tensorRT gives the following error:
[TensorRT] ERROR: UffParser: Parser error: route_1/concat: Concat operation axis is out of bounds for layer route_1/concat
Building an engine from file yolov3_fu.uff; this may take a while...
[TensorRT] ERROR: Network must have at least one output
File "trt_infer.py", line 57, in <module>
f.write(engine.serialize())
AttributeError: 'NoneType' object has no attribute 'serialize'
Following is the cancat operation:
def __build_nework(self, input_data):
# 输入层进入 Darknet-53 网络后,得到了三个分支
route_1, route_2, input_data = backbone.darknet53(input_data, self.trainable)
input_data = common.convolutional(input_data, (1, 1, 1024, 512), self.trainable, 'conv52')
input_data = common.convolutional(input_data, (3, 3, 512, 1024), self.trainable, 'conv53')
input_data = common.convolutional(input_data, (1, 1, 1024, 512), self.trainable, 'conv54')
input_data = common.convolutional(input_data, (3, 3, 512, 1024), self.trainable, 'conv55')
input_data = common.convolutional(input_data, (1, 1, 1024, 512), self.trainable, 'conv56')
conv_lobj_branch = common.convolutional(input_data, (3, 3, 512, 1024), self.trainable, name='conv_lobj_branch')
conv_lbbox = common.convolutional(conv_lobj_branch, (1, 1, 1024, 3*(self.num_class + 5)),
trainable=self.trainable, name='conv_lbbox', activate=False, bn=False)
input_data = common.convolutional(input_data, (1, 1, 512, 256), self.trainable, 'conv57')
input_data = common.upsample(input_data, name='upsample0', method=self.upsample_method)
with tf.variable_scope('route_1'):
input_data = tf.concat([input_data, route_2], axis=-1)
input_data = common.convolutional(input_data, (1, 1, 768, 256), self.trainable, 'conv58')
input_data = common.convolutional(input_data, (3, 3, 256, 512), self.trainable, 'conv59')
input_data = common.convolutional(input_data, (1, 1, 512, 256), self.trainable, 'conv60')
input_data = common.convolutional(input_data, (3, 3, 256, 512), self.trainable, 'conv61')
input_data = common.convolutional(input_data, (1, 1, 512, 256), self.trainable, 'conv62')
conv_mobj_branch = common.convolutional(input_data, (3, 3, 256, 512), self.trainable, name='conv_mobj_branch' )
conv_mbbox = common.convolutional(conv_mobj_branch, (1, 1, 512, 3*(self.num_class + 5)),
trainable=self.trainable, name='conv_mbbox', activate=False, bn=False)
input_data = common.convolutional(input_data, (1, 1, 256, 128), self.trainable, 'conv63')
input_data = common.upsample(input_data, name='upsample1', method=self.upsample_method)
with tf.variable_scope('route_2'):
input_data = tf.concat([input_data, route_1], axis=-1)
input_data = common.convolutional(input_data, (1, 1, 384, 128), self.trainable, 'conv64')
input_data = common.convolutional(input_data, (3, 3, 128, 256), self.trainable, 'conv65')
input_data = common.convolutional(input_data, (1, 1, 256, 128), self.trainable, 'conv66')
input_data = common.convolutional(input_data, (3, 3, 128, 256), self.trainable, 'conv67')
input_data = common.convolutional(input_data, (1, 1, 256, 128), self.trainable, 'conv68')
conv_sobj_branch = common.convolutional(input_data, (3, 3, 128, 256), self.trainable, name='conv_sobj_branch')
conv_sbbox = common.convolutional(conv_sobj_branch, (1, 1, 256, 3*(self.num_class + 5)),
trainable=self.trainable, name='conv_sbbox', activate=False, bn=False)
return conv_lbbox, conv_mbbox, conv_sbbox
Please help me!
[/quote]
