VPI sample code cannot run properly in a thread
I’m trying the latest 4.6 with VPI.
The sample code for stereo depth estimation runs fine without issue.
However, I am having difficulties running the stereo estimation program in a thread.
I simply put the python sample code into a thread function like the following:
import cv2
import vpi
import numpy as np
import threading
from PIL import Image
class StereoDepth():
    def __init__(self):
        self.process = threading.Thread(target=self.depth_estimate, args=())
        self.neglect_range = 0
        self.process.start()
        self.process.join()
    def depth_estimate(self):
        backend = 'cuda'  # cpu, cuda, pva, pva-nvenc-vic
        left = 'chair_stereo_left.png'
        right = 'chair_stereo_right.png'
        # scaling factor when loading input
        scale = 1
        backend = vpi.Backend.CUDA
        # Load input into a vpi.Image and convert it to grayscale, 16bpp
        with vpi.Backend.CUDA:
            left = vpi.asimage(np.asarray(Image.open(left))).convert(vpi.Format.Y16_ER, scale=scale)
            right = vpi.asimage(np.asarray(Image.open(right))).convert(vpi.Format.Y16_ER, scale=scale)
        # Preprocess input
        maxDisparity = 64
        confidenceMap = vpi.Image(left.size, vpi.Format.U16)
        disparity = vpi.stereodisp(left, right, out_confmap=confidenceMap, backend=backend, window=5,
                                   maxdisp=maxDisparity)
        # Postprocess results prior saving them to disk
            # Scale disparity and confidence map so that values like between 0 and 255.
            # Disparities are in Q10.5 format, so to map it to float, it gets
            # divided by 32. Then the resulting disparity range, from 0 to
            # stereo.maxDisparity gets mapped to 0-255 for proper output.
            disparity = disparity.convert(vpi.Format.U8, scale=255.0 / (32 * maxDisparity))
            disparityColor = cv2.applyColorMap(disparity.cpu(), cv2.COLORMAP_JET)
            # Converts to RGB for output with PIL
            # disparityColor = cv2.cvtColor(disparityColor, cv2.COLOR_BGR2RGB)
            if confidenceMap:
                confidenceMap = confidenceMap.convert(vpi.Format.U8, scale=255.0 / 65535)
                # When pixel confidence is 0, its color in the disparity
                # output is black.
                mask = cv2.threshold(confidenceMap.cpu(), 1, 255, cv2.THRESH_BINARY)[1]
                mask = cv2.cvtColor(mask, cv2.COLOR_GRAY2BGR)
                disparityColor = cv2.bitwise_and(disparityColor, mask)
        return
a = StereoDepth()
And it gives me the following error:
line 48, in depth_estimate
RuntimeError: VPI_ERROR_INVALID_OPERATION: Can't use object created in one context with stream created in a different context
Could you please give me feedback on this? Is there any context operation I missed?
Please noted that you need to handle CUDA context push/store in the multi-threading use case.
An example can be found in the below topic:
Thanks for the reply, I added the pycuda and context push and pop into the code. however it still gives me error.
The code I modified is like:
# imports
import pycuda.driver as cuda
import pycuda.autoinit
    def __init__(self):
        self.process.join()
        cfx = cuda.Device(0).make_context()
        cfx.push()
        # depth estimate with sample code...
        cfx.pop()
        return
a = StereoDepth()
The error message is showed below:
[WARN ] 2021-10-18 10:28:48 (cudaErrorDeviceUninitialized)
[WARN ] 2021-10-18 10:28:48 (NVMEDIA_STATUS_TIMED_OUT)
Exception in thread Thread-1:
  File "/usr/lib/python3.6/threading.py", line 916, in _bootstrap_inner
    self.run()
  File "/usr/lib/python3.6/threading.py", line 864, in run
    self._target(*self._args, **self._kwargs)
  File "/home/yyc/Documents/test.py", line 53, in depth_estimate
Is there anything i did wrong?
Thanks for the testing.
We are checking this issue with our internal team.
Will share more information with you later.
Hi @AastaLLL,
I am facing similar error when using VPI 2.3.9 on Jetson Orin with python multi-processing. Is there any update on this issue or how should one go about using multiprocessing or threading with VPI?
Please open a new topic for your issue.
