"vpiSubmitGaussianFilter" Function Yields Inconsistent Results
Hey,
I’m working on a code where I execute vpiSubmitGaussianFilter function six times in different VPIStream streams. This goes for all the images I’m processing. During this process I record the time it takes to run this function by making use of VPIEvent type. After observing these timings I see that sometimes random stream operations take x10 slower than usual. Keep in mind that I’m processing similar images each time (same resolution, same bit depth, same type). Why does this bottleneck happen?
I’m working on Jetson AGX Orin Dev. Kit.
In order to give you a general understanding of the code I’m working on I’m giving a code piece below:
            VPIEvent ev_start;
            VPIEvent ev_stop;
            CHECK_STATUS(vpiEventCreate(0, &ev_start));
            CHECK_STATUS(vpiEventCreate(0, &ev_stop));
            for (int i = 0; i < 6; ++i) {
                CHECK_STATUS(vpiEventRecord(ev_start, streams[i]));
                CHECK_STATUS(vpiSubmitGaussianFilter(streams[i], VPI_BACKEND_CUDA, vpiRaw, vpiBlurred[i], kernelLengths[i/2], kernelLengths[i/2], sigmas[i], sigmas[i], VPI_BORDER_ZERO));
                CHECK_STATUS(vpiEventRecord(ev_stop, streams[i]));
                CHECK_STATUS(vpiEventSync(ev_stop));
                CHECK_STATUS(vpiEventElapsedTimeMillis(ev_start, ev_stop, &elapsedMS));
For example usually the timing results are like:
elapsedMS: 0.09 ms
elapsedMS: 0.12 ms
elapsedMS: 0.12 ms
elapsedMS: 0.12 ms
elapsedMS: 0.13 ms
elapsedMS: 0.11 ms
But sometimes this timing yields results like this:
elapsedMS: 1.27 ms
elapsedMS: 0.12 ms
elapsedMS: 0.12 ms
elapsedMS: 0.11 ms
elapsedMS: 0.14 ms
elapsedMS: 0.12 ms
or
elapsedMS: 0.15 ms
elapsedMS: 0.12 ms
elapsedMS: 0.11 ms
elapsedMS: 0.12 ms
elapsedMS: 0.11 ms
elapsedMS: 1.16 ms
For information, do you use latest Jetpack 6.2.1(r36.4.4) and observe the issue?
@DaneLLL
My jetpack version is 5.1.2-b104. I’m specifically using 5.x because I also have a Jetson AGX Xavier Dev. Kit. that I’m using interchangeably.
You may try to do profiling like:
Optimizing VPI Stereo Disparity on Jetson Orin 64GB - Seeking to Maximize Memory Usage - #3 by AastaLLL
Also would suggest use latest Jetpack release.
