VSS Custom deployment docker compose build failure
  • Hardware Platform (GPU model and numbers): RTX 4070
  • System Memory: 8GB dedicate 16 GB shared memory
  • Ubuntu Version: 22.04.5
  • NVIDIA GPU Driver Version (valid for GPU only): 560.35.03
  • Issue Type( questions, new requirements, bugs): bugs
  • How to reproduce the issue ? (This is for bugs. Including the command line used and other details for reproducing)
  • Requirement details (This is for new requirement. Including the logs for the pods, the description for the pods)
For VSS I am trying custom deployment using remote vlm, llm and reranker models so according to the guide the minimum GPU requirement is 8GB. I have a RTX 4070 windows machine with Ubuntu 22.04.5 installed in my system.
Docker version: Docker version 28.0.4, build b8034c0
Docker compose version: Docker Compose version v2.35.0
When I try docker compose up, I get this error:
✘ via-server Error 3.6s
✘ graph-db Error 3.6s
Error response from daemon: unauthorized:
401 Authorization Required
nginx/1.22.1
Does this have anything to do with ubuntu being run from my windows machine?
Are you using WSL on your windows OS?
Yes I am using WSL on my windows OS
We have not confirmed the compatibility of VSS on the WSL at this time.
For the remote vlm mode, You need to configure the correct NVIDIA_API_KEY key and make sure you have enough credits in your NGC account.
Thank you, I will run on a linux machine in that case. Can you please tell me where I can check and add credits to my NGC account?
Hey shresht.shetty,
The way API endpoints on build.nvidia.com work has now changed. There are no more credits associated with accounts, and the limit is based on # of calls per minute, where each NIM has a different rate.
I am now having an issue creating a launchable with Brev. When I try to launch an instance for VSS using brev there is a 500 error and the page doesn’t load. Is it an issue with my account or is there an issue in the brev backend?
Additionally, where are my payment details set for my account so that I can continue to use the NIMs without stoppage due to payment related errors? I cannot seem to find any usage or payment setup page in the https://build.nvidia.com/ website
Could you refer to the #7 and see if that can fix your issue?
