VSS on DGX Spark - ImportError: libnvrm_mem.so
Hi everyone,
I’m trying to deploy VSS on my DGX Spark, following the guide available here: NVIDIA DGX Spark — Video Search and Summarization Agent
After running all commands in the Fully local Single GPU docker deployment guide, the docker compose up never reaches the final stage of “VIA Server loaded”: a couple seconds after “Starting VIA server in release mode”, I see the “ImportError: libnvrm_mem.so: cannot open shared object file: No such file or directory”, and shortly after, the last via-server log entry: “ProcessGroupNCCL.cpp:1538] Warning: WARNING: destroy_process_group() was not called before program exit, which can leak resources
How can I install the set of libnvrm libraries?
This issue got resolved by adding
export IS_SBSA=1
to the .env file.
Subsequently, I receive the following exception:
via-server-1         | 2025-10-23 16:55:07 | ERROR | gradio_web_server | Error loading default prompts: 'functions'
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr | Traceback (most recent call last):
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr |   File "/opt/nvidia/via/via-engine/via_demo_client.py", line 204, in <module>
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr |     demo = build_demo(args)
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr |            ^^^^^^^^^^^^^^^^
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr |   File "/opt/nvidia/via/via-engine/via_demo_client.py", line 159, in build_demo
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr |     build_summarization(args, appConfig, logger)
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr |   File "/opt/nvidia/via/via-engine/client/summarization.py", line 883, in build_summarization
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr |     (
via-server-1         | 2025-10-23 16:55:07 | ERROR | stderr | ValueError: too many values to unpack (expected 3)
via-server-1         | 2025-10-23 16:55:08,934 INFO Initializing Context Manager Handler no.: 5
via-server-1         | 2025-10-23 16:55:08,935 ERROR Error in configuring context manager handler: 'functions'
via-server-1         | 2025-10-23 16:55:08,935 ERROR Traceback (most recent call last):
via-server-1         |   File "/usr/local/lib/python3.12/dist-packages/vss_ctx_rag/context_manager/context_manager_handler.py", line 99, in aconfigure
via-server-1         |     for function_name in config["functions"]:
via-server-1         |                          ~~~~~~^^^^^^^^^^^^^
via-server-1         | KeyError: 'functions'
Any help would be appreciated.
Please follow our playbook for how to deploy VSS on DGX Spark: Try NVIDIA NIM APIs
