VST got Black Screen & 0 FPS in DeepStream
  • Hardware:Jetson Orin Nano 8GB
  • JetPack Version:6.2 [L4T 36.4.3]
  • AI NVR Version:2.0.1
  • VST Version:1.3.0-24.07.1
  • DeepStream Version:7.1
I followed the process in the Jetson Platform Services documentation to start the AI NVR, but I encountered the following two issues:
  • The sensor status in VST appears normal, but the stream shows a black screen. After a while, the message “Peer connection is successful but VST UI is not receiving frames” appears.
  • DeepStream detects the sensor, but the FPS remains at 0.
I have tried both live RTSP stream and using Nvstreamer to play prerecorded videos, but both have the same issue.
When I use gst-launch-1.0 to open the VST proxy URL, it works fine.
At the moment, I have no clue where the problem is coming from.
Below are the logs from VST and DeepStream.
deepstream.log (6.5 MB)
vst.log (96.6 MB)
Can you share the command line which works fine with your original URL? We can have a try if setting to TCP protocol in rtspsrc GStreamer plugin can work.
This is my command.
Use original URL.
gst-launch-1.0 rtspsrc location=rtsp://admin:admin@10.0.0.146:554/ch01/0 ! decodebin ! autovideosink
gst-launch-1.0 rtspsrc location=rtsp://admin:AAEONiot2017@10.0.0.135:554/ch01/1 ! decodebin ! autovideosink
Use VST proxy URL.
gst-launch-1.0 rtspsrc location=rtsp://10.0.0.138:8554/live/57518e7f-051c-454d-8bb7-384e48d7bae9 ! decodebin ! autovideosink
Do you have any camera which works fine in VST? We have the supported cameras in VST here: VST — Jetson Platform Services documentation. Can you compare the VST log between the camera works and don’t works?
I currently don’t have any camera that works on VST. I’m running on Jetson Nano 8GB with JetPack 6.2.
However, I have another device, a Jetson Xavier NX 16GB with JetPack 6.0, where all my cameras work fine. I’ve compared the logs and noticed some GStreamer-related errors—these are shown in the logs attached in the previous comment. But when I test the GStreamer commands separately, everything runs normally. At the moment, I have no clue where the issue lies.
My cameras are EverFocus EBN series IP cams.
EBN1240-A & EBN1840-A15.
Orin Nano haven’t HW video encoder. Can you check below setting in your setup? Here is the setting document of VST: VST Config — Jetson Platform Services documentation
VST configure file: /opt/nvidia/jetson-2.0.0/services/vst/config/vst_config.json
"use_webrtc_inbuilt_encoder": "h264"
I’ve checked the configuration, and the setting is indeed "use_webrtc_inbuilt_encoder": "h264"
I’ve tried downgrading to JetPack 6.0, and everything works fine with VST and DeepStream.
However, it’s still not working on JetPack 6.2.
Can you share the VST version when you downgrading to JetPack 6.0?
VST 1.2.58 on JetPack 6.0
VST 1.3.0-24.07.1 on JetPack 6.2
Can you have a try set below setting in vst file: /opt/nvidia/jetson-2.0.0/services/vst/config/vst_config.json
“use_software_path”: true,
Changing this parameter worked! Now my VST can properly display both live and playback streams—thank you so much!
However, my DeepStream inference is still running at 0 FPS. Are there any other configuration files or parameters I should modify as well?
Which compose are you using? Do you have any modifications of the config file?
$ ls ai_nvr
base_compose.yaml  compose_agx.yaml  compose_agx_yolov8s.yaml  compose_nano.yaml  compose_nx16.yaml  compose_nx16_yolov8s.yaml  compose_nx8.yaml
I am using compose_nano.yaml, and I haven’t made any modifications to it. The attached file is my compose configuration file.
compose_nano.zip (1.6 KB)
Can you share the log of deepstream container?
No problem, the attached file is my log.
deepstream.log (32.2 MB)
sdr-deepstream.log (355.3 KB)
I found below error log in your deepstream.log. Seems your camera can’t use NV HW video decoder. Your command line selected SW video decoder.
no suitable plugins found:
Missing decoder: H.264 (Baseline Profile) (video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0142001fffe1000f6742001f963540a00b74dc0404040801000468ce3c80, level=(string)3.1, profile=(string)baseline, width=(int)1280, height=(int)720, framerate=(fraction)0/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, colorimetry=(string)1:3:5:1, parsed=(boolean)true)
nvmultiurisrcbin ERROR from element udpsrc0: Internal data stream error.
