Issue running the VST and NVStreamer application
  • Hardware Platform (Jetson / GPU) = Jetson Orin Nx
  • DeepStream Version = 6.3.0
  • JetPack Version (valid for Jetson only) = 35.6.0
  • TensorRT Version = 8.5.2.2
  • CUDA Version (valid for GPU only) = 11.4
  • Issue Type( questions, new requirements, bugs) = Question
I am trying to run VST and Nvstreamer application on jetson orin. But i am facing issue.
In VST im running the container using this cmd - sudo docker run -it --network=host -v /home/vst:/home/vst 0f18f108baa3
I am provding all the required information for rtsp url in sensor management section
and in the dashboard i can see the RTSP url being created for it. But when i am checking the Live stream for this i am alway geting “streaming not ready, try after some time” even thought the rtsp stream is working and i have checked using several method including running it on vlc.
This is the log for your ref:
[2025-3-26T5:44:49.289Z:281472292350944:stream_monitor.cpp:1182: startRtspClient] starting RtspClient for SiteName, uri:rtsp://10.99.17.251:8554/live/295fdf69-38ce-4cd7-9cb8-dd4e
a98a3e29
0
[2025-3-26T5:44:49.289Z:281472292350944:stream_monitor.cpp:1085: QosRtspClient] QosRtspClient: name:SiteName, uri:rtsp://10.99.17.251:8554/live/295fdf69-38ce-4cd7-9cb8-dd4ea98a3e29
[2025-3-26T5:44:49.289Z:281468331879392:stream_monitor.cpp:931: frameMonitorTask] Started the thread frameMonitorTask name: SiteName
[2025-3-26T5:44:50.289Z:281468357241824:rtspconnectionclient.cpp:290: sendNextCommand] [CLIENT] Sending Describe command
[2025-3-26T5:44:50.290Z:281468357241824:rtspconnectionclient.cpp:403: continueAfterDESCRIBE][CLIENT] Received DESCRIBE event, result:404
[2025-3-26T5:44:50.290Z:281468357241824:rtspconnectionclient.cpp:406: continueAfterDESCRIBE]Failed to DESCRIBE: 404 Not Found
[2025-3-26T5:44:50.290Z:281468357241824:stream_monitor.cpp:708: onError] [streamMonitor] onError for SiteName, url:rtsp://10.99.17.251:8554/live/295fdf69-38ce-4cd7-9cb8-dd4ea98a
3e29 error:404 Not Found[2025-3-26T5:44:50.290Z:281468331879392:stream_monitor.cpp:954: frameMonitorTask] Exited the thread frameMonitorTask name: SiteName
[2025-3-26T5:44:52.567Z:281472275442656:nvsoap.cpp:4549: createAndSendRequest] CURL Request failed: 28 : Timeout was reached httpCode: 408, url:http://10.99.17.49/onvif/device_service
, method:GetSystemDateAndTime
[2025-3-26T5:44:52.568Z:281472275442656:nvsoap.cpp:4549: createAndSendRequest] CURL Request failed: 7 : Couldn’t connect to server httpCode: 408, url:http://[fe80::beba:c2ff:fe42:334d
]/onvif/device_service, method:GetSystemDateAndTime
[2025-3-26T5:44:53.574Z:281472275442656:network_utils.cpp:285: getProbeResponse] UUID is missing in the probe match, So generating UUID:e02a97a9-ec8e-4d61-92c4-a5956813fd70
[2025-3-26T5:44:54.581Z:281472275442656:network_utils.cpp:285: getProbeResponse] UUID is missing in the probe match, So generating UUID:c7b15c0d-4b76-4acf-95af-e6de7086ba6b
[2025-3-26T5:44:55.290Z:281468357241824:stream_monitor.cpp:690: restartConnection] Retrying rtsp connection for:SiteName, retry count:1
[2025-3-26T5:44:55.586Z:281472275442656:network_utils.cpp:285: getProbeResponse] UUID is missing in the probe match, So generating UUID:16694156-3cf9-49df-b8a3-714fc57e53bd
[2025-3-26T5:44:59.314Z:281472292350944:stream_monitor.cpp:1182: startRtspClient] starting RtspClient for SiteName, uri:rtsp://10.99.17.251:8554/live/295fdf69-38ce-4cd7-9cb8-dd4e
a98a3e29
[2025-3-26T5:44:59.315Z:281472292350944:stream_monitor.cpp:526: ~QosMeasurementRecord] ~QosMeasurementRecord - SiteName
[2025-3-26T5:44:59.315Z:281472292350944:stream_monitor.cpp:581: stopQoS] [streamMonitor] stopQoS for SiteName
[2025-3-26T5:44:59.315Z:281472292350944:stream_monitor.cpp:1092: ~QosRtspClient] ~QosRtspClient: name:SiteName, uri:rtsp://10.99.17.251:8554/live/295fdf69-38ce-4cd7-9cb8-dd4ea9
8a3e29
[2025-3-26T5:44:59.315Z:281472292350944:livevideosource.h:137: Stop] VideoSource::stop
[2025-3-26T5:44:59.315Z:281472292350944:livevideosource.h:149: Stop] VideoSource::stop : done
[2025-3-26T5:44:59.316Z:281472292350944:livevideosource.h:117: ~VideoSource] ~VideoSource
[2025-3-26T5:44:59.316Z:281472292350944:rtspconnectionclient.cpp:122: ~RTSPConnection] ~RTSPConnection
0
[2025-3-26T5:44:59.316Z:281472292350944:stream_monitor.cpp:1085: QosRtspClient] QosRtspClient: name:SiteName, uri:rtsp://10.99.17.251:8554/live/295fdf69-38ce-4cd7-9cb8-dd4ea98a3e29
[2025-3-26T5:44:59.316Z:281468331879392:stream_monitor.cpp:931: frameMonitorTask] Started the thread frameMonitorTask name: SiteName
[2025-3-26T5:45:0.316Z:281468357241824:rtspconnectionclient.cpp:290: sendNextCommand] [CLIENT] Sending Describe command
[2025-3-26T5:45:0.317Z:281468357241824:rtspconnectionclient.cpp:403: continueAfterDESCRIBE] [CLIENT] Received DESCRIBE event, result:404
[2025-3-26T5:45:0.317Z:281468357241824:rtspconnectionclient.cpp:406: continueAfterDESCRIBE] Failed to DESCRIBE: 404 Not Found
[2025-3-26T5:45:0.317Z:281468357241824:stream_monitor.cpp:708: onError] [streamMonitor] onError for SiteName, url:rtsp://10.99.17.251:8554/live/295fdf69-38ce-4cd7-9cb8-dd4ea98a3e29 err
or:404 Not Found[2025-3-26T5:45:0.317Z:281468331879392:stream_monitor.cpp:954: frameMonitorTask] Exited the thread frameMonitorTask name: SiteName
and the issue in NVstreamer is that
I am starting the container using this cmd - sudo docker run -it -v /home/parkzap/nvstreamer:/home/vst/vst_release/streamer_videos/ --network=host -e ADAPTOR=streamer -e HTTP_PORT=31000 -e RTSP_SERVER_PORT=31554 0f18f108baa3
when i am trying to stream one of the sample video which i have uploaded in the stream section the video is not playing and the aplication is crashing and giving me this error -
744:gstnvvideodecoder.cpp:477: busWatch] Received ASYNC_DONEfa89b3e6-c89e-4caa-9066-abbb3d1c303f [2025-3-25T10:3:15.854Z:281467426171872:gstnvvideodecoder.cpp:611: appsrc_src_pad_cb] [appsrc-output-probe] Received buffer:4 [2025-3-25T10:3:15.854Z:281467426171872:gstnvdecodebin.cpp:209: decodebin_sink_pad_cb] [decodebin-input-probe] Received buffer:4 [2025-3-25T10:3:15.854Z:281467628022752:gstnvvideodecoder.cpp:1462: getstate_internal] [2025-3-25T10:3:15.854Z:281467485350880:ll_transform.cpp:305: doTransformTask] Current state : Allocating surfaces of resolution = 1920 x 1080 4 [2025-3-25T10:3:15.854Z:281467485350880:Main.cpp:138: sig_handler] Entered Signal Handler, sig:11 [2025-3-25T10:3:15.854Z:281467485350880:Main.cpp:62: dumpstack] stack trace: [2025-3-25T10:3:15.854Z:281467611114464:event_loop.cpp:163: Process] Run task: get_state, msg id: fa89b3e6-c89e-4caa-9066-abbb3d1c303f on event loop: dec_event_loop [2025-3-25T10:3:15.855Z:281467628022752:gstnvvideodecoder.cpp:1462: getstate_internal] Current state: 4 [2025-3-25T10:3:15.855Z:281467400809440:gstdemux.cpp:203: processNewSampleFromSink] [demux]: count:9, size:3017, pts:1742895286133, nal_type:1 [2025-3-25T10:3:15.856Z:281467485350880:Main.cpp:122: dumpstack] linux-vdso.so.1 : __kernel_rt_sigreturn+0 [2025-3-25T10:3:15.856Z:281467485350880:Main.cpp:142: sig_handler] FATAL: Segmentation Fault, Logged StackTrace
Please have a try to follow this guide to setup JPS 2.0 on Jetpack 6.2: AI NVR — Jetson Platform Services documentation
