i am running nvidia VST using docker and sucessfully pulled image this the output
Host HTTP port: 30000
Recorded Video Root: /root/vst_release/vst_video
stunurl list: stun.l.google.com:19302, stun1.l.google.com:19302
static_turnurl_list:
use_coturn_auth_secret: 0
use_twilio_stun_turn: 0
coturn_turnurl_list_with_secret:
twilio_account_sid:
twilio_auth_token:
use reverse proxy RP: 0
reverse proxy server address: REVERSE_PROXY_SERVER_ADDRESS:100
NTP servers:
Use sensor ntp time: 0
Sensor Discovery Timeout(secs): 10
Sensor Discovery Freq(secs): 15
Onvif request Timeout(secs): 10
Sensor Discovery Network Interfaces:
Enable perf logging: 1
Max Webrtc output connections: 8
Max Webrtc input connections: 8
Storage Config file: ./configs/vst_storage.json
Total video storage size: 10000
VST database path: /root/vst_release/vst_data
storage threshold percentage: 95
storage monitoring frequency secs: 2
enable aging policy: 0
Max Video Download Size in MB: 1000
Always Recording: 0
Event Recording: 0
Event Recording Length Secs: 10
Recording Buffer Length Secs: 2
Use Software Path: 0
Use Webrtc out inbuilt encoder:
Enable rtsp server sei support: 0
Enable Proxy server sei support: 0
Webrtc IN Resolution: 1280x720
Webrtc IN max frameRate: 30
Webrtc IN video bitrate thresold: 50
Webrtc IN Pass-through mode: 0
Webrtc Sender Quality: pass_through
Is camera auto discovery enabled ?: 1
Webservice allowed/denied Subnet/IP list?:
RTSP preferred network interface:
RTSP server port: -1
RTSP server instances: 1
Incoming rtsp initial port: -1
Outgoing rtsp initial port: -1
rtsp streaming over tcp: 0
RTSP server reclamation client timeout sec: 10
Server domain name:
Enable Notfication: 0
Message Broker used: kafka
Notification event: vst_events
Message Broker payload key: sensor.id
Message Broker metadata topic: test
Redis server env var: REDIS_SVC_SERVICE_HOST:6379
Kafka Server address: 10.0.0.1:9092
Max Sensors Supported: 16
Enable Stream Monitoring: 1
Max stream_monitor_interval (secs): 5
rtp_udp_port_range: 31000-31200
Max udp_latency_ms: 200
udp_drop_on_latency: 0
webRTC Latency ms: 1000
Frame Drop Enabled: 1
Video Metadata Server URL:
Video Metadata Max results fetched: 300
Video Use old specs for metadata parsing: 0
Enable QoS Monitoring: 1
QoS logfile path:
QoS data capture interval sec: 1
QoS data publish interval sec: 5
Enable GST debug Probes: 1
Recieve Socket Buffer Size: 1000000
Send Socket Buffer Size: 1000000
Enable Prometheus: 0
Prometheus Port: 8080
NV Streamer directory path: /home/vst/vst_release/streamer_videos/
NV Streamer loop playback: 1
NV Streamer max upload file size: 10000
NV Streamer seekable: 0
NV Streamer Sync Playback: 0
NV Streamer RTSP server buffer size kb: 1000
NV Streamer supported containers: mp4, mkv
Video codecs supported: h264, h265
Audio codecs supported: pcmu, pcma, mpeg4-generic
Bitrate Kbps: 8000
Framerate: 30
Resolution: 1920x1080
GOV Length: 60
Enable Highlighting logs: 1
Enable debug options: 1
Enable dump webrtc input stats: 0
Enable network bandwidth notification: 0
Enable frameId in webrtc stream: 0
Use HTTP digest authentication: 0
Use multi user: 0
Enable user cleanup: 0
Session max age sec: 2592000
Multi user extra flags: Secure, SameSite=none
Use HTTPS authentication: 0
Nv org ID:
Nv NGC kry:
Use RTSP authentication: 0
docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
inet6 fe80::42:8ff:fee0:2b45 prefixlen 64 scopeid 0x20
ether 02:42:08:e0:2b:45 txqueuelen 0 (Ethernet)
RX packets 519 bytes 360262 (360.2 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 385 bytes 66266 (66.2 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.49 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::d3d8:e509:6cc2:5a93 prefixlen 64 scopeid 0x20
ether 3c:6d:66:01:79:15 txqueuelen 1000 (Ethernet)
RX packets 1411182 bytes 1982438323 (1.9 GB)
RX errors 0 dropped 19540 overruns 0 frame 0
TX packets 404859 bytes 126027230 (126.0 MB)
device interrupt 251 base 0x7000
l4tbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.55.1 netmask 255.255.255.0 broadcast 192.168.55.255
inet6 fe80::1 prefixlen 128 scopeid 0x20
ether 3e:c7:e7:79:f3:87 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 8581 bytes 790065 (790.0 KB)
TX packets 8581 bytes 790065 (790.0 KB)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 7a:bf:97:45:3d:89 txqueuelen 1000 (Ethernet)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 7a:bf:97:45:3d:8b txqueuelen 1000 (Ethernet)
vethc93595c: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::d0ab:39ff:fec3:7919 prefixlen 64 scopeid 0x20
ether d2:ab:39:c3:79:19 txqueuelen 0 (Ethernet)
RX packets 120 bytes 95554 (95.5 KB)
TX packets 112 bytes 19457 (19.4 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.51 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::e6fd:ece5:8be6:dbe prefixlen 64 scopeid 0x20
ether 90:cc:df:ff:05:00 txqueuelen 1000 (Ethernet)
RX packets 55887 bytes 42364161 (42.3 MB)
RX errors 0 dropped 4850 overruns 0 frame 0
TX packets 33237 bytes 5038095 (5.0 MB)
above are the output of running ifconfig and docker image
I am not able to access VST UI
