Running Nvidia VST(Video Storage Toolkit) on Mac M1
I am trying to run Nvidia VST on Mac M1 machine.
I downloaded the below docker image
nvcr.io/nvidia/jps/vst:v1.2.58_aarch64
Am trying to run it usind docker run .
My objective is just to run the VST container and see the UI.
However when i run i am not able to see the UI.
The final logs show as:
[2024-7-16T7:9:22.587Z:281473415696416:sensor_management.cpp:633: notifyVmsRedinessEvent] {
“alert_type” : “service_status_change”,
“created_at” : “2024-07-16T07:09:22Z”,
“event” :
“service_status” : “init_ready”
“source” : “vst”
Question:
  1. Is it possible to run VST on a non NVIDIA GPU machine?
  2. If the answer to above is yes, what is that i need to do to make it work correctly on my local machine?
  3. Where can i get the vst_configs.json file ?
  4. What are the minimum fields i need to modify, is there any link which can guide in modifying those fields and giving a brief description of the fields?
• Ubuntu Version
• TensorRT Version
This forum is for JPS on Jetson. I can more the topic to other forum if you can provide more details of your setup.
Thanks for the prompt reply.
I am trying to run NVIDIA VST (Video storgae toolkit) – Overview — mms-docs 2.1 documentation
Hardware platform : Apple Mac M1
Ubuntu version : Not applicable
JetPack Version : Not applicable
TensorRT Version : Not applicable
NVIDIA GPU Driver Version (valid for GPU only) : Not applicable
Issue Type( questions, new requirements, bugs) : Question
Reproduce the issue :
  1. Pull the docker image : docker pull nvcr.io/nvidia/jps/vst:v1.2.58_aarch64
  2. Run the image : docker run --rm -it nvcr.io/nvidia/jps/vst:v1.2.58_aarch64
    Expectation : Web UI launched on a URL
    Observation : Not able to open the UI
Not sure where this question fits exactly, any help would be appreciated
VST depend on NVIDIA GPU for video decode/encode and video process (draw line onto video). I think we only test it on NVIDIA dGPU or Jetson.
Thanks, understood.
If i run it on a remove server which has gpu, can i access the UI from a different machine, if yes, what is the process for that.
E,g,
  1. VST running on a machine with ip a.b.c
  2. Access the web UI from a different machine with x.y.z
    How to do it?
You can access VST with Chrome browser. If the server and client in different network, you need install TURN based on: Usage & Configuration — mms-docs 2.1 documentation (nvidia.com)
My VST container is running on a remote server which does not have a UI component.
I am trying to access the VST web UI from a different machine. Do i need to install the TURN on the server?
One more question:
I found 2 different images
nvcr.io/nvidia/jps/vst:nvstreamer_v0.2.31_x86_64
nvcr.io/rxczgrvsg8nx/vst-1-0/vst:v1.2.60_x86_64
Which is the one which has to be used
Any update on this?
Seems VST works in your side based on. Please try to use the latest version of VST: Recording in VST(Video storage toolkit) - #8 by rahul.jha
