I am trying to get a vulkan context without running X11.
It works really well with egl and I am unable to do something similar for Vulkan
MartijnBerger,
Do you mean your app with egl+vulkan works well and you would like to know if there is a non-X11 case for vulkan?
egl + opengl works well when no Xserver / X11 is running.
The vulkan implementation seems to require a DISPLAY variable and Xserver. is that correct ?
Which is also what the icd seems to say:
cat /etc/vulkan/icd.d/nvidia_icd.json
"file_format_version" : "1.0.0",
"ICD": {
"library_path": "libGLX_nvidia.so.0",
"api_version" : "1.0.61"
MartijnBerger,
Even egl + openGL also needs Xserver if you need to render to display.
Currently, only DRM-KMS is able to be used for rendering under non-X scenario.
