Vulkan developer beta driver 383.18(Win) & 381.26.20(Linux)
Windows driver version 383.18 and Linux driver version 381.26.20 provide new features for Vulkan developers to test their upcoming Vulkan applications.
September 28th, 2017 - Windows 383.18, Linux 381.26.20
Full-screen flipping for Linux
    Improved performance of fullscreen Vulkan applications using X11 swapchains. This optimization will cause more events that trigger an out-of-date swapchain, such as when entering or leaving fullscreen mode. This is commonly encountered when using the alt-tab key combination, for example. Applications that do not properly respond to the VK_ERROR_OUT_OF_DATE_KHR return code may not function properly when these events occur. See section 30.8 of the Vulkan specification.
    Known issue with Quadro and non-composited desktops under some situations. Possible workarounds:
        Disable flipping in nvidia-settings (uncheck "Allow Flipping" in the "OpenGL Settings" panel)
        Disable UBB (run 'nvidia-xconfig --no-ubb')
        Use a composited desktop
Bug fixes
    NVX_multiview_per_view_attributes and geometry passthrough shaders
    Fix subpass dstSubpass=VK_SUBPASS_EXTERNAL handling
    Fix vkRegisterObjectsNVX and VK_EXT_sample_
    Fix handling of SPIR-V SSBO layout qualifiers on members
    Fix atomic operations on some 64-bit types
Windows 10 64bit driver zip is corrupted. Comes up with 7-zip: data error
I had the same problem yesterday. I just downloaded the file and it now unzips correctly. So it appears to be fixed.
