… and which is now supposed to run under 6.4 on an AWS T4 instance.
Verdict: It crashes.
Positive reference: deepstream-rtsp-in-rtsp-out works perfectly.
In my desperation I now have carved out most of my old pipeline code and inserted the sample pipeline handling. The crashes don’t go away.
I hesitate a bit to throw all my past work away and just take over the running sample, just because I’m unable to fix it, but I currently don’t know what I’m doing wrong.
Script is started with:
python3 ./inference.py rtsp://127.0.0.1:8554/stream-inference -ml resnet18-trafficcamnet -ll info
and is supposed to read from a local RTSP server stream. Same works with the example.
What I get is:
0:00:02.553421668 84899 0x555556bc36f0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
and then
Thread 8 "pool-python3" received signal SIGABRT, Aborted.
The GDB view doesn’t make it more clear, what’s happening:
2024-04-09 13:36:25,837 inference.py INFO : Inference v.0.1.0
2024-04-09 13:36:25,846 validation.py INFO : Inference configuration file: /tmp/tmp06e8b__n
2024-04-09 13:36:25,846 validation.py INFO : model-engine-file does not exist, skip entry
[Detaching after vfork from child process 84907]
2024-04-09 13:36:25,849 inference.py INFO : DeepStream SDK version: 6.4.0
[New Thread 0x7fffec9ff640 (LWP 84908)]
/home/ubuntu/ai/inference/./inference.py:332: DeprecationWarning: Gst.Element.get_request_pad is deprecated
sinkpad = streammux.get_request_pad(padname)
[New Thread 0x7fffa5b5e640 (LWP 84938)]
WARNING: Overriding infer-config batch-size 30 with number of sources 1
Starting pipeline
[New Thread 0x7fffa43ff640 (LWP 84939)]
[New Thread 0x7fffa3612640 (LWP 84940)]
[New Thread 0x7fffa2e11640 (LWP 84941)]
[New Thread 0x7fffa2610640 (LWP 84942)]
[New Thread 0x7fffa1e0f640 (LWP 84943)]
[New Thread 0x7fffa160e640 (LWP 84944)]
[Switching to Thread 0x7fffa1e0f640 (LWP 84943)]
__pthread_kill_implementation (no_tid=0, signo=6, threadid=140735909262912) at ./nptl/pthread_kill.c:44
44 ./nptl/pthread_kill.c: No such file or directory.
(gdb) thread apply all bt
Thread 9 (Thread 0x7fffa160e640 (LWP 84944) "gdbus"):
#0 0x00007ffff7d18bcf in __GI___poll (fds=0x7fff68001de0, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
#1 0x00007ffff60d31f6 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007ffff607d2b3 in g_main_loop_run () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007ffff5e6b07a in () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#4 0x00007ffff60aca51 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#5 0x00007ffff7c94ac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
#6 0x00007ffff7d26850 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
Thread 8 (Thread 0x7fffa1e0f640 (LWP 84943) "pool-python3"):
--Type <RET> for more, q to quit, c to continue without paging--c
#0 __pthread_kill_implementation (no_tid=0, signo=6, threadid=140735909262912) at ./nptl/pthread_kill.c:44
#1 __pthread_kill_internal (signo=6, threadid=140735909262912) at ./nptl/pthread_kill.c:78
#2 __GI___pthread_kill (threadid=140735909262912, signo=signo@entry=6) at ./nptl/pthread_kill.c:89
#3 0x00007ffff7c42476 in __GI_raise (sig=sig@entry=6) at ../sysdeps/posix/raise.c:26
#4 0x00007ffff7c287f3 in __GI_abort () at ./stdlib/abort.c:79
#5 0x00007ffff64a2692 in () at /lib/x86_64-linux-gnu/libstdc++.so.6
#6 0x00007ffff64ad9da in __gxx_personality_v0 () at /lib/x86_64-linux-gnu/libstdc++.so.6
#7 0x00007ffff5824fe9 in __libunwind_Unwind_Resume () at /lib/x86_64-linux-gnu/libunwind.so.8
#8 0x00007fffb0c2d86d in () at /lib/x86_64-linux-gnu/libproxy.so.1
#9 0x00007fffb0c36827 in px_proxy_factory_get_proxies () at /lib/x86_64-linux-gnu/libproxy.so.1
#10 0x00007fffec0a9827 in () at /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
#11 0x00007ffff5e08194 in () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#12 0x00007ffff60af6b4 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#13 0x00007ffff60aca51 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#14 0x00007ffff7c94ac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
#15 0x00007ffff7d26850 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
Thread 7 (Thread 0x7fffa2610640 (LWP 84942) "dconf worker"):
#0 0x00007ffff7d18bcf in __GI___poll (fds=0x7fff70001de0, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
#2 0x00007ffff607b3e3 in g_main_context_iteration () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007fffd3d5d33d in () at /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
Thread 6 (Thread 0x7fffa2e11640 (LWP 84941) "gmain"):
#0 0x00007ffff7d18bcf in __GI___poll (fds=0x7fff78010d50, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
#3 0x00007ffff607b431 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
Thread 5 (Thread 0x7fffa3612640 (LWP 84940) "task0"):
#0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
#1 0x00007ffff60ccb43 in g_cond_wait () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007ffff5e0708b in g_task_run_in_thread_sync () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#3 0x00007fffec0a9a75 in () at /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
#4 0x00007ffff5ded1af in () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#5 0x00007ffff5dfe18b in g_socket_client_connect () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#6 0x00007ffff5dfeadf in g_socket_client_connect_to_uri () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#7 0x00007fffdab60880 in gst_rtsp_connection_connect_with_response_usec () at /lib/x86_64-linux-gnu/libgstrtsp-1.0.so.0
#8 0x00007fffdab61297 in gst_rtsp_connection_connect_usec () at /lib/x86_64-linux-gnu/libgstrtsp-1.0.so.0
#9 0x00007fffdb0f4070 in () at /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtspclientsink.so
#10 0x00007fffdb0f8fb6 in () at /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtspclientsink.so
#11 0x00007fffdb0fb698 in () at /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtspclientsink.so
#12 0x00007ffff58ef127 in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#13 0x00007ffff60af6b4 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#14 0x00007ffff60aca51 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#15 0x00007ffff7c94ac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
#16 0x00007ffff7d26850 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
Thread 4 (Thread 0x7fffa43ff640 (LWP 84939) "cuda-EvtHandlr"):
#0 0x00007ffff7d18bcf in __GI___poll (fds=0x7fff8c000c20, nfds=11, timeout=100) at ../sysdeps/unix/sysv/linux/poll.c:29
#1 0x00007ffff0ab8bef in () at /lib/x86_64-linux-gnu/libcuda.so.1
#2 0x00007ffff0b7be5f in () at /lib/x86_64-linux-gnu/libcuda.so.1
#3 0x00007ffff0ab1cdf in () at /lib/x86_64-linux-gnu/libcuda.so.1
#4 0x00007ffff7c94ac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
#5 0x00007ffff7d26850 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
Thread 3 (Thread 0x7fffa5b5e640 (LWP 84938) "cuda-EvtHandlr"):
#0 0x00007ffff7d18bcf in __GI___poll (fds=0x555556bc3ee0, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
Thread 2 (Thread 0x7fffec9ff640 (LWP 84908) "python3"):
#0 __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x7fffec9feb40, op=137, expected=0, futex_word=0x7ffff49d2170 <g_nvbuf_res_storage+80>) at ./nptl/futex-internal.c:57
#1 __futex_abstimed_wait_common (cancel=true, private=0, abstime=0x7fffec9feb40, clockid=0, expected=0, futex_word=0x7ffff49d2170 <g_nvbuf_res_storage+80>) at ./nptl/futex-internal.c:87
#2 __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x7ffff49d2170 <g_nvbuf_res_storage+80>, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7fffec9feb40, private=private@entry=0) at ./nptl/futex-internal.c:139
#3 0x00007ffff7c942dd in __pthread_cond_wait_common (abstime=0x7fffec9feb40, clockid=1, mutex=0x7ffff49d2120 <g_nvbuf_res_storage>, cond=0x7ffff49d2148 <g_nvbuf_res_storage+40>) at ./nptl/pthread_cond_wait.c:503
#4 ___pthread_cond_clockwait64 (abstime=0x7fffec9feb40, clockid=1, mutex=0x7ffff49d2120 <g_nvbuf_res_storage>, cond=0x7ffff49d2148 <g_nvbuf_res_storage+40>) at ./nptl/pthread_cond_wait.c:691
#5 ___pthread_cond_clockwait64 (cond=0x7ffff49d2148 <g_nvbuf_res_storage+40>, mutex=0x7ffff49d2120 <g_nvbuf_res_storage>, clockid=1, abstime=0x7fffec9feb40) at ./nptl/pthread_cond_wait.c:679
#6 0x00007ffff2de2c65 in NvBufResStorage::taskTrim(NvBufResStorage*) () at ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvbufsurftransform.so
#7 0x00007ffff64dc253 in () at /lib/x86_64-linux-gnu/libstdc++.so.6
#8 0x00007ffff7c94ac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
#9 0x00007ffff7d26850 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
Thread 1 (Thread 0x7ffff7e71480 (LWP 84899) "python3"):
#0 0x00007ffff7ca48b0 in _int_malloc (av=av@entry=0x7ffff7e1ac80 <main_arena>, bytes=bytes@entry=904) at ./malloc/malloc.c:4382
#1 0x00007ffff7ca5139 in __GI___libc_malloc (bytes=904) at ./malloc/malloc.c:3329
#2 0x00007ffff64ae98c in operator new(unsigned long) () at /lib/x86_64-linux-gnu/libstdc++.so.6
#3 0x00007fffe22737d5 in () at /lib/x86_64-linux-gnu/libnvinfer.so.8
#4 0x00007fffe2273fa7 in () at /lib/x86_64-linux-gnu/libnvinfer.so.8
#5 0x00007fffe2264590 in () at /lib/x86_64-linux-gnu/libnvinfer.so.8
#6 0x00007fffe2137681 in () at /lib/x86_64-linux-gnu/libnvinfer.so.8
#7 0x00007fffe2137629 in () at /lib/x86_64-linux-gnu/libnvinfer.so.8
#8 0x00007ffff7c99ee8 in __pthread_once_slow (once_control=0x7fffeb987760, init_routine=0x7ffff64dad50 <__once_proxy>) at ./nptl/pthread_once.c:116
#9 0x00007fffde63e21c in () at /lib/x86_64-linux-gnu/libnvinfer.so.8
#10 0x00007fffde3b63a5 in createInferBuilder_INTERNAL () at /lib/x86_64-linux-gnu/libnvinfer.so.8
#11 0x00007ffff03a6611 in () at ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_infer.so
#12 0x00007ffff0380eed in nvdsinfer::NvDsInferContextImpl::buildModel(_NvDsInferContextInitParams&) () at ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_infer.so
#13 0x00007ffff0381c03 in nvdsinfer::NvDsInferContextImpl::generateBackendContext(_NvDsInferContextInitParams&) () at ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_infer.so
#14 0x00007ffff0388af4 in nvdsinfer::NvDsInferContextImpl::initialize(_NvDsInferContextInitParams&, void*, void (*)(INvDsInferContext*, unsigned int, NvDsInferLogLevel, char const*, void*)) () at ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_infer.so
#15 0x00007ffff038946e in createNvDsInferContext(INvDsInferContext**, _NvDsInferContextInitParams&, void*, void (*)(INvDsInferContext*, unsigned int, NvDsInferLogLevel, char const*, void*)) () at ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_infer.so
#16 0x00007ffff07d0d25 in () at /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so
#17 0x00007ffff2941441 in () at /lib/x86_64-linux-gnu/libgstbase-1.0.so.0
#18 0x00007ffff2941675 in () at /lib/x86_64-linux-gnu/libgstbase-1.0.so.0
#19 0x00007ffff58bd73f in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#20 0x00007ffff58bdfec in gst_pad_set_active () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#21 0x00007ffff58a5155 in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#22 0x00007ffff58ae36b in gst_iterator_fold () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#23 0x00007ffff591c29a in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#24 0x00007ffff58a2a56 in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#25 0x00007ffff58a5410 in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#26 0x00007ffff58a4729 in gst_element_change_state () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#27 0x00007ffff58a4e35 in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#28 0x00007ffff587d7ec in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#29 0x00007ffff58d0796 in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#30 0x00007ffff58a4729 in gst_element_change_state () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#31 0x00007ffff58a476f in gst_element_change_state () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#32 0x00007ffff58a4e35 in () at /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#33 0x00007ffff6634e2e in () at /lib/x86_64-linux-gnu/libffi.so.8
#34 0x00007ffff6631493 in () at /lib/x86_64-linux-gnu/libffi.so.8
#35 0x00007ffff619c722 in () at /usr/lib/python3/dist-packages/gi/_gi.cpython-310-x86_64-linux-gnu.so
#36 0x00007ffff619a826 in () at /usr/lib/python3/dist-packages/gi/_gi.cpython-310-x86_64-linux-gnu.so
#37 0x00007ffff619aa7d in () at /usr/lib/python3/dist-packages/gi/_gi.cpython-310-x86_64-linux-gnu.so
#38 0x00005555556a4a7b in _PyObject_MakeTpCall ()
#39 0x000055555569d629 in _PyEval_EvalFrameDefault ()
#40 0x00005555556ae9fc in _PyFunction_Vectorcall ()
#41 0x000055555569745c in _PyEval_EvalFrameDefault ()
#42 0x00005555556ae9fc in _PyFunction_Vectorcall ()
#43 0x000055555569726d in _PyEval_EvalFrameDefault ()
#44 0x00005555556939c6 in ()
#45 0x0000555555789256 in PyEval_EvalCode ()
#46 0x00005555557b4108 in ()
#47 0x00005555557ad9cb in ()
#48 0x00005555557b3e55 in ()
#49 0x00005555557b3338 in _PyRun_SimpleFileObject ()
#50 0x00005555557b2f83 in _PyRun_AnyFileObject ()
#51 0x00005555557a5a5e in Py_RunMain ()
#52 0x000055555577c02d in Py_BytesMain ()
#53 0x00007ffff7c29d90 in __libc_start_call_main (main=main@entry=0x55555577bff0, argc=argc@entry=7, argv=argv@entry=0x7fffffffe108) at ../sysdeps/nptl/libc_start_call_main.h:58
#54 0x00007ffff7c29e40 in __libc_start_main_impl (main=0x55555577bff0, argc=7, argv=0x7fffffffe108, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7fffffffe0f8) at ../csu/libc-start.c:392
#55 0x000055555577bf25 in _start ()
(gdb)
Here is the config read from a tmp file:
[property]
gpu-id=0
net-scale-factor=0.00392156862745098
tlt-model-key=tlt_encode
tlt-encoded-model=/home/ubuntu/ai/inference/models/primary_detector/resnet18-trafficcamnet/resnet18_trafficcamnet.etlt
labelfile-path=/home/ubuntu/ai/inference/models/primary-detector/resnet18-trafficcamnet/labels.txt
int8-calib-file=/home/ubuntu/ai/inference/models/primary-detector/resnet18-trafficcamnet/cal_trt.bin
force-implicit-batch-dim=1
batch-size=30
process-mode=1
model-color-format=0
network-mode=2
num-detected-classes=4
interval=0
gie-unique-id=1
uff-input-order=0
uff-input-blob-name=input_1
output-blob-names=output_cov/Sigmoid;output_bbox/BiasAdd
cluster-mode=2
infer-dims=3;544;960
operate-on-class-ids=2
filter-out-class-ids=0;1;3;
[class-attrs-all]
pre-cluster-threshold=0.5
eps=0.5
group-threshold=1
Please help, I’m lost a bit.
