Jetpack 4.2, deepstream samples giving error
/usr/bin/deepstream-app -c configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt
Error: Can’t initialize nvrm channel
Couldn’t create ddkvic Session: Cannot allocate memory
nvbuf_utils: Could not create Default NvBufferSession
(gst-plugin-scanner:24868): GStreamer-WARNING **: 22:44:14.643: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenglmixers.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:24870): GStreamer-WARNING **: 22:44:14.857: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopengl.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
Hi harpreet8rb5h,
DeepStream3.0 is specific to R31.1. We will have new release for r32.1.
For R31.1, please install the system with Jetpack 4.1.1
[url]https://developer.nvidia.com/embedded/jetpack-4-1-1[/url]
Hi kayccc
I tried installing 4.1.1
giving same issues as
https://devtalk.nvidia.com/default/topic/1045444/fresh-flash-on-xavier-out-of-box-fail-error-cuda-cannot-be-installed-on-device/
Hi harpreet8rb5h,
Do you mean you cannot install CUDA via Jetpack?
Hi DaneLLL
Yes, Neither cuda nor tensorRT
Hi Hi harpreet8rb5h,
We don’t hit the issue. Do you use Jetpack4.1.1 and Xavier?
Yes DaneLLL
Hi harpreet8rb5h,
Can you try to install CUDA by manually?
Steps: [url]https://devtalk.nvidia.com/default/topic/1045444/jetson-agx-xavier/fresh-flash-on-xavier-out-of-box-fail-error-cuda-cannot-be-installed-on-device/post/5304913/#5304913[/url]
Hi Carolyuu,
I am able to run deepstream app.
but getting below error now:
agx-xavier:~/deepstream_sdk_on_jetson$ sudo rm ${HOME}/.cache/gstreamer-1.0/registry.aarch64.bin
agx-xavier:~/deepstream_sdk_on_jetson$ sudo rm -rf ~/-cache/
agx-xavier:~/deepstream_sdk_on_jetson$ sudo deepstream-app -c configs/deepstream-app/config_infer_secondary_carcolor.txt
(gst-plugin-scanner:13996): GStreamer-WARNING **: 03:20:11.772: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenglmixers.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:13996): GStreamer-WARNING **: 03:20:12.507: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstkms.so’: /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstkms.so: undefined symbol: drmModeGetFB
(gst-plugin-scanner:13996): GStreamer-WARNING **: 03:20:12.886: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libcluttergst3.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:13996): GStreamer-WARNING **: 03:20:13.078: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopengl.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
** ERROR: <parse_config_file:1289>: parse_config_file failed
** ERROR: main:584: Failed to parse config file ‘configs/deepstream-app/config_infer_secondary_carcolor.txt’
Quitting
App run failed
Resolved ** ERROR: <parse_config_file:1289>: parse_config_file failed , by giving correct path:
ran, and got below error now:
agx-xavier:~/deepstream_sdk_on_jetson$ sudo deepstream-app -c samples/configs/deepstream-app/config_infer_secondary_carcolor.txt
** ERROR: main:613: Failed to set pipeline to PAUSED
Quitting
ERROR from src_bin_muxer: Output width not set
Debug info: /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvmultistream/gstnvstreammux.c(1633): gst_nvstreammux_change_state (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
App run failed
Hi harpreet8rb5h,
Are you install JetPack-4.1.1 all packages? (include CUDA, cuDNN, TensorRT, OpenCV, VisionWorks)
And install prerequisites packages:
$ sudo apt-get install libssl1.0.0 libgstreamer1.0-0 gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav libgstrtspserver-1.0-0 libjansson4
Hi carolyuu,
Was able to get one config working with below steps:
export DISPLAY=:0
change sink type to fake sink in all sinks in config file
sudo deepstream-app -c $HOME/deepstream_sdk_on_jetson/samples/configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt
below is the log:
vMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 261
Allocating new output: 1280x720 (x 12), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3528: Send OMX_EventPortSettingsChanged: nFrameWidth = 1280, nFrameHeight = 720
** INFO: <bus_callback:84>: Pipeline running
**PERF: 20.85 (20.85) 20.92 (20.92) 20.85 (20.85) 20.85 (20.85) 21.13 (21.13) 21.48 (21.48) 21.48 (21.48) 20.92 (20.92) 20.92 (20.92) 21.13 (21.13) 20.85 (20.85) 20.85 (20.85) 20.85 (20.85) 20.87 (20.87) 20.85 (20.85) 21.13 (21.13) 20.85 (20.85) 20.92 (20.92) 20.87 (20.87) 20.92 (20.92) 21.48 (21.48) 20.85 (20.85) 20.92 (20.92) 21.13 (21.13) 20.92 (20.92) 21.13 (21.13) 20.85 (20.85) 21.13 (21.13) 20.85 (20.85) 20.85 (20.85)
**PERF: 21.72 (21.47) 21.72 (21.49) 21.72 (21.47) 21.72 (21.47) 21.72 (21.55) 21.72 (21.66) 21.72 (21.66) 21.72 (21.49) 21.72 (21.49) 21.72 (21.55) 21.72 (21.47) 21.72 (21.47) 21.72 (21.47) 21.72 (21.48) 21.72 (21.47) 21.72 (21.55) 21.72 (21.47) 21.72 (21.49) 21.72 (21.48) 21.72 (21.49) 21.72 (21.66) 21.72 (21.47) 21.72 (21.49) 21.72 (21.55) 21.72 (21.49) 21.72 (21.55) 21.72 (21.47) 21.72 (21.55) 21.72 (21.47) 21.72 (21.47)
**PERF: 21.85 (21.63) 21.85 (21.64) 21.85 (21.63) 21.85 (21.63) 21.85 (21.67) 21.85 (21.74) 21.85 (21.74) 21.85 (21.64) 21.85 (21.64) 21.85 (21.67) 21.85 (21.63) 21.85 (21.63) 21.85 (21.63) 21.85 (21.64) 21.85 (21.63) 21.85 (21.67) 21.85 (21.63) 21.85 (21.64) 21.85 (21.64) 21.85 (21.64) 21.85 (21.74) 21.85 (21.63) 21.85 (21.64) 21.85 (21.67) 21.85 (21.64) 21.85 (21.67) 21.85 (21.63) 21.85 (21.67) 21.85 (21.63) 21.85 (21.63)
WARNING from sink_sub_bin_sink1: A lot of buffers are being dropped.
Debug info: gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstFakeSink:sink_sub_bin_sink1:
There may be a timestamping problem, or this computer is too slow.
**PERF: 21.91 (21.71) 21.91 (21.72) 21.91 (21.71) 21.91 (21.71) 21.91 (21.74) 21.91 (21.79) 21.91 (21.79) 21.91 (21.72) 21.91 (21.72) 21.91 (21.74) 21.91 (21.71) 21.91 (21.71) 21.91 (21.71) 21.91 (21.72) 21.91 (21.71) 21.91 (21.74) 21.91 (21.71) 21.91 (21.72) 21.91 (21.72) 21.91 (21.72) 21.91 (21.79) 21.91 (21.71) 21.91 (21.72) 21.91 (21.74) 21.91 (21.72) 21.91 (21.74) 21.91 (21.71) 21.91 (21.74) 21.91 (21.71) 21.91 (21.71)
**PERF: 21.82 (21.74) 21.82 (21.74) 21.82 (21.74) 21.82 (21.74) 21.82 (21.76) 21.82 (21.80) 21.82 (21.80) 21.82 (21.74) 21.82 (21.74) 21.82 (21.76) 21.82 (21.74) 21.82 (21.74) 21.82 (21.74) 21.82 (21.74) 21.82 (21.74) 21.82 (21.76) 21.82 (21.74) 21.82 (21.74) 21.82 (21.74) 21.82 (21.74) 21.82 (21.80) 21.82 (21.74) 21.82 (21.74) 21.82 (21.76) 21.82 (21.74) 21.82 (21.76) 21.82 (21.74) 21.82 (21.76) 21.82 (21.74) 21.82 (21.74)
Why I am getting below warning on Jetson Xavier?
Hi harpreet8rb5h,
Before running DeepStream, please set your device to MAX performance.
sudo nvpmodel -m 0
sudo ./jetson_clocks.sh
Hi carolyuu,
Thanks it worked.
Please help me understand whats does this config do?
Does it use tensorRT?
Does it use hardware decoding?
Yes. you can check with
$ export GST_DEBUG=*FACTORY*:4
nvinfer plugin runs TensorRT engine.
omxh264dec and nvv4l2decoder plugins run hardware decoding engine.
