Having seen the announcement of JetPack 4.2.1 GA release,
I have replaced JetPack 4.2.1 EA with JetPack 4.2.1 GA.
Then, I found nvinfer won’t run anymore.
For example, deepstream-test1 fails as follows:
Xavier
deepstream_sdk_on_jetson/sources/apps/sample_apps/deepstream-test1$ ./deepstream-test1-app ../../../../samples/streams/sample_720p.h264
Unknown key 'parse-func' for group [property]
Now playing: ../../../../samples/streams/sample_720p.h264
Using winsys: x11
Opening in BLOCKING MODE
Creating LL OSD context new
0:00:01.061567650 29051 0x55655b4730 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:40.376531335 29051 0x55655b4730 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/emi/projects/deepstream_sdk_on_jetson/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
nvbufsurface: memory type (-2145384446) not supported
0:00:40.416460734 29051 0x55655b4730 WARN nvinfer gstnvinfer.cpp:773:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to set buffer pool to active
Running...
ERROR from element primary-nvinference-engine: Failed to set buffer pool to active
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(773): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine
Returned, stopping playback
Deleting pipeline
TX2
Using winsys: x11
0:00:02.555543306 31982 0x5585015730 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:02.556668653 31982 0x5585015730 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:00:44.125731956 31982 0x5585015730 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/emi/projects/deepstream_sdk_on_jetson/samples/models/Primary_Detector/resnet10.caffemodel_b1_fp16.engine
0:00:44.207355800 31982 0x5585015730 WARN nvinfer gstnvinfer.cpp:773:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to set buffer pool to active
Running...
Deleting pipeline
The error message, nvbufsurface: memory type (-2145384446) not supported, is new to me.
I can’t find through gst-inspect, but is there any new setting introduced?
Or I have to wait until DeepStream 4.0 is released?
