here is the log:
<nvidia@nvidia 19:51:52> ~
$deepstream-app -c ./deepstream_sdk_on_jetson/samples/configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt
Using winsys: x11
>>> Using TRT model serialized engine /home/nvidia/deepstream_sdk_on_jetson/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_int8.engine crypto flags(0)
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
z<row-index(0-9)><column-index(0-9)>: Expand a source from the 2D tile array
u: Go back to 2D tile array
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:98>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading sys.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 1280x720 (x 12), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3595: Send OMX_EventPortSettingsChanged: nFrameWidth = 1280, nFrameHeight = 720
nvstreamtiler: batchSize set as 30
** INFO: <bus_callback:84>: Pipeline running
buf_convert: Wrong src surface count in ConvertBuffer
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg) FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg) FPS 23 (Avg) FPS 24 (Avg) FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
