what algorithms are used in cusparse
I wonder what algorithm is used in CUSPARSE for multiplying sparse matrix in CSR format with vector. Could I get source code of Cusparse or is this algorithm documented somewhere?
Thanks, Tomas.
It is similar to the one provided in CUSP library (which is open-source). You can get it at code.google.com/cusp-library
Hi, Cusp library uses mainly the Hybrid format combining Ellpack and COO format. This format is not as fast as Cusparse library.
Tomas.
Did you read this paper :
Also, here are the GTC 2010 presentations about CUSPARSE and all other libraries (CUBLAS, CUFFT, etc.), which contains similar results:
