Hi everyone, I’m new to Cuda programming because I’m compiling the source code from other using CUDA and openCV. I got an error in MVS 10:
error : identifier "CUDA_SAFE_CALL" is undefined
What is replaced CUDA_SAFE_CALL in the new version?
Here is the code form .cu file:
#include <stdlib.h>
#include "CvFastBgGMM.h"
#if(CUDAGMM_VERSION == 5)
#define SWAP(a, b, t) t = (a); a = (b); b = (t)
__constant__ CvFastBgGMMParams d_GMMParams;
__constant__ CvFastBgGMMData d_GMMData;
__constant__ int d_arrImageInfo[ImageInfoCount];
// forward declarations
int InitCUDA(CvFastBgGMM* pGMM);
template <int BLOCK_SIZE>
__global__ void cudaUpdateFastBgGMM(unsigned char* data, unsigned char* output);
void cudaUpdateFastBgGMM_Wrapper(unsigned char* data, unsigned char* output,
int iGridSize, int iBlockSize, int sharedSize, cudaStream_t stream);
CvFastBgGMMParams* cvCreateFastBgGMMParams(int width, int height)
CvFastBgGMMParams* pGMMParams = new CvFastBgGMMParams();
int size = width*height;
pGMMParams->nWidth = width;
pGMMParams->nHeight = height;
pGMMParams->nSize = size;
pGMMParams->nNBands=3; //always 3 - not implemented for other values!
//set parameters
// K - max number of Gaussians per pixel
pGMMParams->nM = 4;
// Tb - the threshold - n var
pGMMParams->fTb = 4*4;
// Tbf - the threshold
pGMMParams->fTB = 0.9f;//1-cf from the paper
// Tgenerate - the threshold
pGMMParams->fTg = 3.0f*3.0f;//update the mode or generate new
pGMMParams->fSigma= 11.0f;//sigma for the new mode
// alpha - the learning factor
pGMMParams->fAlphaT=0.001f;
// complexity reduction prior constant
pGMMParams->fCT=0.05f;
//shadow
// Shadow detection
pGMMParams->bShadowDetection = 1;//turn on
pGMMParams->fTau = 0.5f;// Tau - shadow threshold
pGMMParams->bRemoveForeground = 0;
return pGMMParams;
template <bool toPinned>
void copyImageData(IplImage* h_img, unsigned char* d_pinnedMem, int channels)
if(h_img->widthStep == channels*h_img->width)
memcpy(
toPinned ? (d_pinnedMem) : (unsigned char*)(h_img->imageData),
toPinned ? (unsigned char*)(h_img->imageData) : (d_pinnedMem),
h_img->widthStep*h_img->height);
else
unsigned char* d_curData = d_pinnedMem;
if(toPinned)
for(int i = 0; i < h_img->height; ++i)
memcpy(
d_curData,
&CV_IMAGE_ELEM(h_img, unsigned char, i, 0),
channels*h_img->width);
d_curData += (channels*h_img->width);
else
memcpy(
d_curData,
CvFastBgGMM* cvCreateFastBgGMM(CvFastBgGMMParams* pGMMParams, IplImage* frame0)
CvFastBgGMM* h_pGMMRet = new CvFastBgGMM();
if(InitCUDA(h_pGMMRet) < 0)
delete h_pGMMRet;
return NULL;
CvFastBgGMMData* h_pGMMData = new CvFastBgGMMData();
// allocate device global memory
int iElemCount = pGMMParams->nSize * pGMMParams->nM * sizeof(float);
int iSizeCount = pGMMParams->nSize * sizeof(int);
CUDAGMM_SAFE_CALL(cudaMalloc((void**)&(h_pGMMData->ucGaussian), 4*iElemCount));
CUDAGMM_SAFE_CALL(cudaMalloc((void**)&(h_pGMMData->rWeight), iElemCount));
CUDAGMM_SAFE_CALL(cudaMalloc((void**)&(h_pGMMData->rnUsedModes), iSizeCount));
CUDAGMM_SAFE_CALL(cudaMemset(h_pGMMData->rnUsedModes, 0, iSizeCount));
CUDAGMM_SAFE_CALL(cudaMemcpyToSymbol(d_GMMData, h_pGMMData, sizeof(CvFastBgGMMData), 0, cudaMemcpyHostToDevice));
h_pGMMRet->internal_data = h_pGMMData;
// we will use 4-channels image as input data!
h_pGMMRet->inputFrame = cvCreateImage(cvSize(pGMMParams->nWidth, pGMMParams->nHeight), IPL_DEPTH_8U, 4);
h_pGMMRet->nInputImgSize = 4 * frame0->width * pGMMParams->nHeight;
CUDAGMM_SAFE_CALL(cudaMalloc((void**)&(h_pGMMRet->d_inputImg), h_pGMMRet->nInputImgSize));
h_pGMMRet->h_outputImg = cvCreateImage(cvSize(pGMMParams->nWidth, pGMMParams->nHeight), IPL_DEPTH_8U, 1);
h_pGMMRet->nOutputImgSize = pGMMParams->nWidth * pGMMParams->nHeight;
CUDAGMM_SAFE_CALL(cudaMalloc((void**)&(h_pGMMRet->d_outputImg), h_pGMMRet->nOutputImgSize));
// d_arrImageInfo constant (device mem.)
int inpPixelCnt = pGMMParams->nWidth * pGMMParams->nHeight;
// number of pixels per thread must be 4k, i.e. 4, 8, 12, 16, 20...
int iPixelsPerThread = (int)ceil(inpPixelCnt *1.0 / (h_pGMMRet->nBlocksPerGrid * h_pGMMRet->nThreadsPerBlock));
iPixelsPerThread = 4*(int)ceil(iPixelsPerThread/4.0f);
h_pGMMRet->nBlocksPerGrid = (int)ceil(inpPixelCnt*1.0 / ((h_pGMMRet->nThreadsPerBlock) * iPixelsPerThread));
printf("%d pixels/thread, %d threads/block, %d blocks\r\n",
iPixelsPerThread, h_pGMMRet->nThreadsPerBlock, h_pGMMRet->nBlocksPerGrid);
int arrImgInfo[ImageInfoCount] = { inpPixelCnt, iPixelsPerThread };
CUDAGMM_SAFE_CALL(cudaMemcpyToSymbol(d_arrImageInfo, arrImgInfo, ImageInfoCount*sizeof(int),
CUDAGMM_SAFE_CALL(cudaStreamCreate(&(h_pGMMRet->copyStream)));
CUDAGMM_SAFE_CALL(cudaStreamCreate(&(h_pGMMRet->execStream)));
CUDAGMM_SAFE_CALL(cudaHostAlloc((void**)&(h_pGMMRet->h_pinnedIn), h_pGMMRet->nInputImgSize, cudaHostAllocMapped));
CUDAGMM_SAFE_CALL(cudaHostAlloc((void**)&(h_pGMMRet->h_pinnedOut), h_pGMMRet->nOutputImgSize, cudaHostAllocMapped));
CUDAGMM_SAFE_CALL(cudaMalloc((void**)&(h_pGMMRet->d_inputImg2), h_pGMMRet->nInputImgSize));
CUDAGMM_SAFE_CALL(cudaMalloc((void**)&(h_pGMMRet->d_outputImg2), h_pGMMRet->nOutputImgSize));
// copy the algorithm parameters to Constant memory
pGMMParams->fPrune = -(pGMMParams->fAlphaT) * (pGMMParams->fCT);
CUDAGMM_SAFE_CALL(cudaMemcpyToSymbol(d_GMMParams, pGMMParams, sizeof(CvFastBgGMMParams),
// setup the initial state for asynchronous execution
cvCvtColor(frame0, h_pGMMRet->inputFrame, CV_BGR2BGRA);
copyImageData<true>(h_pGMMRet->inputFrame, h_pGMMRet->h_pinnedIn, 4);
CUDAGMM_SAFE_CALL(cudaMemcpy(h_pGMMRet->d_inputImg2, h_pGMMRet->h_pinnedIn, h_pGMMRet->nInputImgSize, cudaMemcpyHostToDevice));
cudaUpdateFastBgGMM<<< (h_pGMMRet->nBlocksPerGrid), (h_pGMMRet->nThreadsPerBlock), 4, h_pGMMRet->execStream >>>
( h_pGMMRet->d_inputImg2, h_pGMMRet->d_outputImg2 );
CUDAGMM_SAFE_CALL(cudaMemcpyAsync(h_pGMMRet->d_inputImg, h_pGMMRet->h_pinnedIn, h_pGMMRet->nInputImgSize,
cudaMemcpyHostToDevice, h_pGMMRet->copyStream));
CUDAGMM_SAFE_CALL(cudaStreamSynchronize(h_pGMMRet->execStream));
CUDAGMM_SAFE_CALL(cudaMemcpy(h_pGMMRet->h_pinnedOut, h_pGMMRet->d_outputImg2, h_pGMMRet->nOutputImgSize, cudaMemcpyDeviceToHost));
CUDAGMM_SAFE_CALL(cudaStreamSynchronize(h_pGMMRet->copyStream));
( h_pGMMRet->d_inputImg, h_pGMMRet->d_outputImg );
CUDAGMM_SAFE_CALL(cudaMemcpyAsync(h_pGMMRet->d_inputImg2, h_pGMMRet->h_pinnedIn, h_pGMMRet->nInputImgSize,
return h_pGMMRet;
void cvReleaseFastBgGMM(CvFastBgGMM** h_ppGMM)
CvFastBgGMM* h_pGMM = *h_ppGMM;
cvReleaseImage(&(h_pGMM->h_outputImg));
cvReleaseImage(&(h_pGMM->inputFrame));
CUDAGMM_SAFE_CALL( cudaStreamSynchronize(h_pGMM->copyStream));
CUDAGMM_SAFE_CALL( cudaStreamSynchronize(h_pGMM->execStream));
CUDAGMM_SAFE_CALL( cudaFree(h_pGMM->d_inputImg));
CUDAGMM_SAFE_CALL( cudaFree(h_pGMM->d_outputImg));
CUDAGMM_SAFE_CALL( cudaFree(h_pGMM->d_inputImg2));
CUDAGMM_SAFE_CALL( cudaFree(h_pGMM->d_outputImg2));
CUDAGMM_SAFE_CALL( cudaFreeHost(h_pGMM->h_pinnedIn));
CUDAGMM_SAFE_CALL( cudaFreeHost(h_pGMM->h_pinnedOut));
CUDAGMM_SAFE_CALL( cudaStreamDestroy(h_pGMM->copyStream));
CUDAGMM_SAFE_CALL( cudaStreamDestroy(h_pGMM->execStream));
CvFastBgGMMData* h_pGMMData = h_pGMM->internal_data;
CUDAGMM_SAFE_CALL( cudaFree(h_pGMMData->ucGaussian));
CUDAGMM_SAFE_CALL( cudaFree(h_pGMMData->rWeight));
CUDAGMM_SAFE_CALL( cudaFree(h_pGMMData->rnUsedModes));
delete h_pGMM->internal_data;
delete h_pGMM;
(*h_ppGMM) = 0;
void cvUpdateFastBgGMM(CvFastBgGMM* pGMM, IplImage* inputImg)
cvCvtColor(inputImg, pGMM->inputFrame, CV_BGR2BGRA);
CUDAGMM_SAFE_CALL(cudaStreamSynchronize(pGMM->copyStream));
copyImageData<true>(pGMM->inputFrame, pGMM->h_pinnedIn, 4);
copyImageData<false>(pGMM->h_outputImg, pGMM->h_pinnedOut, 1);
CUDAGMM_SAFE_CALL(cudaStreamSynchronize(pGMM->execStream));
unsigned char* pTmp;
SWAP(pGMM->d_inputImg, pGMM->d_inputImg2, pTmp);
SWAP(pGMM->d_outputImg, pGMM->d_outputImg2, pTmp);
CUDAGMM_SAFE_CALL(cudaMemcpyAsync(pGMM->d_inputImg, pGMM->h_pinnedIn, pGMM->nInputImgSize, cudaMemcpyHostToDevice, pGMM->copyStream));
CUDAGMM_SAFE_CALL(cudaMemcpyAsync(pGMM->h_pinnedOut, pGMM->d_outputImg, pGMM->nOutputImgSize, cudaMemcpyDeviceToHost, pGMM->copyStream));
cudaUpdateFastBgGMM_Wrapper( pGMM->d_inputImg2, pGMM->d_outputImg2 ,
(pGMM->nBlocksPerGrid), (pGMM->nThreadsPerBlock), 4, pGMM->execStream);
#ifdef _DEBUG
cudaError_t error = cudaGetLastError();
if(error != cudaSuccess)
printf("CUDA error: %d: %s\r\n", error, cudaGetErrorString(error));
#endif
float cvUpdateFastBgGMMTimer(CvFastBgGMM* pGMM, IplImage* inputImg)
cudaEvent_t start, stop;
float time = 0;
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaEventRecord( start, 0 );
cvUpdateFastBgGMM(pGMM, inputImg);
cudaEventRecord( stop, 0 );
cudaEventSynchronize( stop );
cudaEventElapsedTime( &time, start, stop );
cudaEventDestroy( start );
cudaEventDestroy( stop );
return time;
// CUDA-related functions
#if __DEVICE_EMULATION__
pGMM->nThreadsPerBlock = pGMM->nBlocksPerGrid = 256;
return 0;
#else
int count = 0;
int i = 0;
cudaGetDeviceCount(&count);
if(count == 0)
fprintf(stderr, "There is no device.\n");
return -1;
for(i = 0; i < count; i++)
cudaDeviceProp prop;
if(cudaGetDeviceProperties(&prop, i) == cudaSuccess)
if(prop.major >= 1)
pGMM->nThreadsPerBlock = prop.maxThreadsPerBlock / 4;
// temporarily hard-code a little here...
break;
if(i == count) {
fprintf(stderr, "There is no device supporting CUDA.\n");
return -1;
cudaSetDevice(i);
return i;
#endif
__device__ int _cudaUpdateFastBgGMM(int pixel,
float red, float green, float blue,
int* pModesUsed
//calculate distances to the modes (+ sort???)
//here we need to go in descending order!!!
int pos;
bool bFitsPDF = 0;
int bBackground = 0;
float m_fOneMinAlpha = 1 - d_GMMParams.fAlphaT;
int nModes = (*pModesUsed);
float weight, totalWeight = 0.0f;
float dR, dG, dB;
float dist, k, sigmanew;
//go through all modes
for (int iModes = 0; iModes < nModes; iModes++)
pos = pixel + iModes*d_arrImageInfo[ImageInfoPixelCount];
weight = d_GMMData.rWeight[pos];
//fit not found yet
if (!bFitsPDF)
//check if it belongs to some of the modes
float4 cGauss = d_GMMData.ucGaussian[pos];
dR = cGauss.x - red;
dG = cGauss.y - green;
dB = cGauss.z - blue;
//check if it fits the current mode (Factor * sigma)
//square distance -slower and less accurate
//float maxDistance = cvSqrt(m_fTg*var);
//if ((fabs(dR) <= maxDistance) && (fabs(dG) <= maxDistance) && (fabs(dB) <= maxDistance))
//circle
dist = dR*dR + dG*dG + dB*dB;
//background? - m_fTb
if ((totalWeight < d_GMMParams.fTB) && (dist < d_GMMParams.fTb * cGauss.w))
bBackground = 1;
//check fit
if (dist < d_GMMParams.fTg * cGauss.w)
//belongs to the mode
bFitsPDF = 1;
//update distribution
k = d_GMMParams.fAlphaT/weight;
weight = m_fOneMinAlpha * weight + d_GMMParams.fPrune;
weight += d_GMMParams.fAlphaT;
cGauss.x -= k*(dR);
cGauss.y -= k*(dG);
cGauss.z -= k*(dB);
//limit update speed for cov matrice
//not needed
sigmanew = cGauss.w + k*(dist - cGauss.w);
//limit the variance
cGauss.w = sigmanew < 4 ? 4 :
sigmanew > 5 * d_GMMParams.fSigma ? 5 * d_GMMParams.fSigma : sigmanew;
d_GMMData.ucGaussian[pos] = cGauss;
//sort
//all other weights are at the same place and
//only the matched (iModes) is higher -> just find the new place for it
for (int iLocal = iModes; iLocal > 0; iLocal--)
int posLocal = pixel + iLocal*d_arrImageInfo[ImageInfoPixelCount];
if (weight < (d_GMMData.rWeight[posLocal-d_arrImageInfo[ImageInfoPixelCount]]))
break;
else
//swap
float tmpVal;
float4 tmpuChar;
SWAP(d_GMMData.ucGaussian[posLocal],
d_GMMData.ucGaussian[posLocal - d_arrImageInfo[ImageInfoPixelCount]],
tmpuChar);
SWAP(d_GMMData.rWeight[posLocal],
d_GMMData.rWeight[posLocal - d_arrImageInfo[ImageInfoPixelCount]],
tmpVal);
else
//check prune
if (weight < -(d_GMMParams.fPrune))
weight = 0.0f;
nModes--;
// bPrune=1;
//break;//the components are sorted so we can skip the rest
//check if it fits the current mode (2.5 sigma)
} //fit not found yet
else
weight=0.0;
nModes--;
//bPrune=1;
totalWeight += weight;
d_GMMData.rWeight[pos] = weight;
//renormalize weights
for (int iLocal = 0; iLocal < nModes; iLocal++)
d_GMMData.rWeight[pixel + iLocal*d_arrImageInfo[ImageInfoPixelCount]] /= totalWeight;
//make new mode if needed and exit
if (!bFitsPDF)
if (nModes == d_GMMParams.nM)
//replace the weakest
else
//add a new one
//totalWeight+=m_fAlphaT;
//pos++;
nModes++;
pos = pixel + (nModes-1)*d_arrImageInfo[ImageInfoPixelCount];
if (nModes == 1)
d_GMMData.rWeight[pos] = 1;
else
d_GMMData.rWeight[pos] = d_GMMParams.fAlphaT;
for (int iLocal = 0; iLocal < nModes-1; iLocal++)
d_GMMData.rWeight[pixel + iLocal*d_arrImageInfo[ImageInfoPixelCount]] *= m_fOneMinAlpha;
float4 cGauss;
cGauss.x = red;
cGauss.y = green;
cGauss.z = blue;
cGauss.w = d_GMMParams.fSigma;
//sort
//find the new place for it
for (int iLocal = nModes - 1; iLocal>0; iLocal--)
if (d_GMMParams.fAlphaT < (d_GMMData.rWeight[posLocal - d_arrImageInfo[ImageInfoPixelCount]]))
break;
else
//swap
float4 tmpuChar;
float tmpVal;
tmpuChar);
tmpVal);
//set the number of modes
*pModesUsed=nModes;
return bBackground;
__device__ int _cudaRemoveShadowGMM(int pixel,
int nModes)
// long posPixel = pixel * m_nM;
int pos;
float tWeight = 0;
float numerator, denominator;
// check all the distributions, marked as background:
for (int iModes=0;iModes<nModes;iModes++)
pos=pixel+iModes*d_arrImageInfo[ImageInfoPixelCount];
float weight = d_GMMData.rWeight[pos];
tWeight += weight;
numerator = red * cGauss.x + green * cGauss.y + blue * cGauss.z;
denominator = cGauss.x * cGauss.x + cGauss.y * cGauss.y + cGauss.z * cGauss.z;
// no division by zero allowed
if (denominator == 0)
break;
float a = numerator / denominator;
// if tau < a < 1 then also check the color distortion
if ((a <= 1) && (a >= d_GMMParams.fTau))//m_nBeta=1
float dR=a * cGauss.x - red;
float dG=a * cGauss.y - green;
float dB=a * cGauss.z - blue;
//float maxDistance = cvSqrt(m_fTb*var);
//circle
float dist=(dR*dR+dG*dG+dB*dB);
if (dist<d_GMMParams.fTb*cGauss.w*a*a)
return 2;
if (tWeight > d_GMMParams.fTB)
break;
return 0;
__device__ void _cudaReplacePixelBackgroundGMM(int pixel, uchar4* pData)
uchar4 tmp;
float4 cGauss = d_GMMData.ucGaussian[pixel];
tmp.z = (unsigned char) cGauss.x;
tmp.y = (unsigned char) cGauss.y;
tmp.x = (unsigned char) cGauss.z;
(*pData) = tmp;
extern __shared__ int sharedInfo[];
if(threadIdx.x == 0)
// the start pixel for current block
sharedInfo[0] = (blockIdx.x * BLOCK_SIZE)*d_arrImageInfo[ImageInfoPixelsPerThread];
__syncthreads();
int iPxStart = sharedInfo[0] + threadIdx.x;
int iPxEnd = min( d_arrImageInfo[ImageInfoPixelCount],
sharedInfo[0] + (BLOCK_SIZE * d_arrImageInfo[ImageInfoPixelsPerThread]));
uchar4* pGlobalInput = ((uchar4*)data) + iPxStart;
unsigned char* pGlobalOutput = output + iPxStart;
int* pUsedModes = d_GMMData.rnUsedModes + iPxStart;
uchar fRed, fGreen, fBlue;
uchar4 currentInputPx;
for(int i = iPxStart; i < iPxEnd; i += BLOCK_SIZE)
// retrieves the color
currentInputPx = *pGlobalInput;
fBlue = currentInputPx.x;
fGreen = currentInputPx.y;
fRed = currentInputPx.z;
pGlobalInput += BLOCK_SIZE;
// update model + background subtract
int result = _cudaUpdateFastBgGMM(i, fRed, fGreen, fBlue, pUsedModes);
int nMLocal = *pUsedModes;
pUsedModes += BLOCK_SIZE;
if (d_GMMParams.bShadowDetection)
if (!result)
result= _cudaRemoveShadowGMM(i, fRed, fGreen, fBlue, nMLocal);
switch (result)
case 0:
//foreground
(*pGlobalOutput) = 255;
if (d_GMMParams.bRemoveForeground)
_cudaReplacePixelBackgroundGMM(i, pGlobalInput-BLOCK_SIZE);
break;
case 1:
//background
(*pGlobalOutput) = 0;
break;
case 2:
//shadow
(*pGlobalOutput) = 128;
break;
pGlobalOutput += BLOCK_SIZE;
switch(iBlockSize)
case 8:
cudaUpdateFastBgGMM<8> <<< iGridSize, 8, sharedSize, stream>>>
(data, output);
break;
case 16:
cudaUpdateFastBgGMM<16> <<< iGridSize, 16, sharedSize, stream>>>
(data, output);
break;
case 32:
cudaUpdateFastBgGMM<32> <<< iGridSize, 32, sharedSize, stream>>>
(data, output);
break;
case 64:
cudaUpdateFastBgGMM<64> <<< iGridSize, 64, sharedSize, stream>>>
(data, output);
break;
case 128:
cudaUpdateFastBgGMM<128> <<< iGridSize, 128, sharedSize, stream>>>
(data, output);
break;
case 256:
cudaUpdateFastBgGMM<256> <<< iGridSize, 256, sharedSize, stream>>>
(data, output);
break;
case 512:
cudaUpdateFastBgGMM<512> <<< iGridSize, 512, sharedSize, stream>>>
(data, output);
break;
#endif
Please help me. Thank you
