I’m using some code that looks for the start and stop bits of the MJPEG in unity and I can see my stream.
When trying to use a gstreamer pipeline to stream an MJPEG, the stream is encoded differently or the format is different. Normally, my pipeline would look like this:
However, when I try to stream a larger video using caps “video/x-raw,width=1280,height=720” I get an error:
Error sending message: A message sent on a datagram socket was larger than the internal message buffer or some other network limit, or the buffer used to receive a datagram into was smaller than the datagram itself.
Are you able to use h264/h265 encoding? Generally we use h264/h265 in RTSP/UDP streaming on Jetson platforms. You can use hardware encoder to get better performance.
That is what I would normally do. However the video input I’m getting into my jetson nano is already MJPEG encoded and the receiver in unity is built to decode the MJPEG stream. If I hardware encode to H264 from MJPEG, I have to custom build a receiver that can depay the H264 then convert it back to MJPEG for a second broadcast that is through websockets.
FFMPEG doesn’t seem to have any issue with larger resolution (up to 1080p) when transmitting the data as MJPEG, so I was wondering what the difference was when transmitting from gstreamer. Is there a way to break up the chunks sent over UDP?
