Hello Experts,
CC: @Honey_Patouceul @DaneLLL @amycao @kayccc @WayneWWW @icornejo.a @AastaLLL @dusty_nv
I am facing a problem in accessing the RTSP streaming.
Camera Settings
Encode Mode: h264
Resolution : 1080p
FrameRate: 25 fps
Bitrate type: Constant bit rate
Bitrate : 2048 Kbps
Frame Interval : 50
where I am able to access the RTSP URL successfully from ffmpeg in Jetson Nano, Gstreamer running in another PC
But when I tried to access the URL from Gstreamer in Jetson Nano then, URI access fails.
Is there any way I can debug and see why it is not working in Jetson Nano Hardware.
DaneLLL
October 25, 2020, 11:09pm
#3
It looks like you have figured out the solution:
Hi @Honey_Patouceul
Oh finally issue resolved with the command.
sudo apt-get remove gstreamer1.0-plugins-ugly
Seems the Gstreamer RTSP source is sending some Header which the Camera doesn’t like and gives denial of service. Now it works after removing the above plugin. Thanks for the Help Guyz @Honey_Patouceul @DaneLLL
These plugins are native gstreamer plugins. If you would need more information about why is fails with ugly plugins, you may go to gstreamer forum:
http://gstreamer-devel.966125.n4.nabble.com/
Hi @DaneLLL
Yeah, but I am just confused about why this sends unwanted info in the header.
