What’s the means of the parameter below when generate the Bootloader Payload Update (BUP),and How could I get the value for a new board.
FAB
BOARDID
BOARDSKU
BOARDREV
Run this command on your device can tell you the info.
sudo nv_bootloader_payload_updater --print-ver
jetson8@jetson8-desktop:~$ sudo nv_bootloader_payload_updater --print-ver
sudo: nv_bootloader_payload_updater: command not found
It says command not found.
Thank you.
Do you find it with this?
ls /usr/sbin/nv_bootloader_payload_updater
If so, then it just means the directory is not in your default path, and you could either name the full path, or else add the directory to your default path.
See “echo $PATH” and “sudo echo $PATH”.
