Hi @NVES,
I checked my model with check_model.py, that are the logs using trtexec:
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=CNN_shaped.onnx --fp16 --workspace=2048 --saveEngine=CNN_shaped.trt --verbose --dumpProfile
[06/28/2021-16:30:35] [I] === Model Options ===
[06/28/2021-16:30:35] [I] Format: ONNX
[06/28/2021-16:30:35] [I] Model: CNN_shaped.onnx
[06/28/2021-16:30:35] [I] Output:
[06/28/2021-16:30:35] [I] === Build Options ===
[06/28/2021-16:30:35] [I] Max batch: 1
[06/28/2021-16:30:35] [I] Workspace: 2048 MB
[06/28/2021-16:30:35] [I] minTiming: 1
[06/28/2021-16:30:35] [I] avgTiming: 8
[06/28/2021-16:30:35] [I] Precision: FP32+FP16
[06/28/2021-16:30:35] [I] Calibration:
[06/28/2021-16:30:35] [I] Safe mode: Disabled
[06/28/2021-16:30:35] [I] Save engine: CNN_shaped.trt
[06/28/2021-16:30:35] [I] Load engine:
[06/28/2021-16:30:35] [I] Builder Cache: Enabled
[06/28/2021-16:30:35] [I] NVTX verbosity: 0
[06/28/2021-16:30:35] [I] Inputs format: fp32:CHW
[06/28/2021-16:30:35] [I] Outputs format: fp32:CHW
[06/28/2021-16:30:35] [I] Input build shapes: model
[06/28/2021-16:30:35] [I] Input calibration shapes: model
[06/28/2021-16:30:35] [I] === System Options ===
[06/28/2021-16:30:35] [I] Device: 0
[06/28/2021-16:30:35] [I] DLACore:
[06/28/2021-16:30:35] [I] Plugins:
[06/28/2021-16:30:35] [I] === Inference Options ===
[06/28/2021-16:30:35] [I] Batch: 1
[06/28/2021-16:30:35] [I] Input inference shapes: model
[06/28/2021-16:30:35] [I] Iterations: 10
[06/28/2021-16:30:35] [I] Duration: 3s (+ 200ms warm up)
[06/28/2021-16:30:35] [I] Sleep time: 0ms
[06/28/2021-16:30:35] [I] Streams: 1
[06/28/2021-16:30:35] [I] ExposeDMA: Disabled
[06/28/2021-16:30:35] [I] Spin-wait: Disabled
[06/28/2021-16:30:35] [I] Multithreading: Disabled
[06/28/2021-16:30:35] [I] CUDA Graph: Disabled
[06/28/2021-16:30:35] [I] Skip inference: Disabled
[06/28/2021-16:30:35] [I] Inputs:
[06/28/2021-16:30:35] [I] === Reporting Options ===
[06/28/2021-16:30:35] [I] Verbose: Enabled
[06/28/2021-16:30:35] [I] Averages: 10 inferences
[06/28/2021-16:30:35] [I] Percentile: 99
[06/28/2021-16:30:35] [I] Dump output: Disabled
[06/28/2021-16:30:35] [I] Profile: Enabled
[06/28/2021-16:30:35] [I] Export timing to JSON file:
[06/28/2021-16:30:35] [I] Export output to JSON file:
[06/28/2021-16:30:35] [I] Export profile to JSON file:
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::Proposal version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::Split version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[06/28/2021-16:30:35] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
Input filename: CNN_shaped.onnx
ONNX IR version: 0.0.7
Opset version: 13
Producer name: keras2onnx
Producer version: 1.8.1
Domain: onnxmltools
Model version: 0
Doc string:
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::Clip_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::Split version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:202: Adding network input: my_input with dtype: float32, dimensions: (1, 32, 32, 3)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: my_input for ONNX tensor: my_input
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: dense_1/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: dense_1/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: dense/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: dense/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2d_2/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2d_2/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2d_1/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2d_1/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2d/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:90: Importing initializer: conv2d/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: Transpose6 [Transpose]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: my_input
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: Transpose6 [Transpose] inputs: [my_input -> (1, 32, 32, 3)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: Transpose6 for ONNX node: Transpose6
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: adjusted_input2 for ONNX tensor: adjusted_input2
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: Transpose6 [Transpose] outputs: [adjusted_input2 -> (1, 3, 32, 32)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: conv2d [Conv]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: adjusted_input2
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: conv2d [Conv] inputs: [adjusted_input2 -> (1, 3, 32, 32)], [conv2d/kernel:0 -> (1, 3, 3, 3)], [conv2d/bias:0 -> (1)],
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:450: Convolution input dimensions: (1, 3, 32, 32)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: conv2d for ONNX node: conv2d
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:533: Using kernel: (3, 3), strides: (1, 1), prepadding: (0, 0), postpadding: (0, 0), dilations: (1, 1), numOutputs: 1
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:534: Convolution output dimensions: (1, 1, 30, 30)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: convolution_output2 for ONNX tensor: convolution_output2
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: conv2d [Conv] outputs: [convolution_output2 -> (1, 1, 30, 30)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: Relu3 [Relu]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: convolution_output2
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: Relu3 [Relu] inputs: [convolution_output2 -> (1, 1, 30, 30)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: Relu3 for ONNX node: Relu3
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: conv2d/Relu:0 for ONNX tensor: conv2d/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: Relu3 [Relu] outputs: [conv2d/Relu:0 -> (1, 1, 30, 30)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: conv2d/Relu:0_pooling [MaxPool]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: conv2d/Relu:0_pooling [MaxPool] inputs: [conv2d/Relu:0 -> (1, 1, 30, 30)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: conv2d/Relu:0_pooling for ONNX node: conv2d/Relu:0_pooling
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: conv2d/Relu:0_pooling0 for ONNX tensor: conv2d/Relu:0_pooling0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: conv2d/Relu:0_pooling [MaxPool] outputs: [conv2d/Relu:0_pooling0 -> (1, 1, 15, 15)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: conv2d_1 [Conv]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d/Relu:0_pooling0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d_1/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d_1/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: conv2d_1 [Conv] inputs: [conv2d/Relu:0_pooling0 -> (1, 1, 15, 15)], [conv2d_1/kernel:0 -> (64, 1, 3, 3)], [conv2d_1/bias:0 -> (64)],
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:450: Convolution input dimensions: (1, 1, 15, 15)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: conv2d_1 for ONNX node: conv2d_1
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:533: Using kernel: (3, 3), strides: (1, 1), prepadding: (0, 0), postpadding: (0, 0), dilations: (1, 1), numOutputs: 64
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:534: Convolution output dimensions: (1, 64, 13, 13)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: convolution_output1 for ONNX tensor: convolution_output1
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: conv2d_1 [Conv] outputs: [convolution_output1 -> (1, 64, 13, 13)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: Relu2 [Relu]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: convolution_output1
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: Relu2 [Relu] inputs: [convolution_output1 -> (1, 64, 13, 13)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: Relu2 for ONNX node: Relu2
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: conv2d_1/Relu:0 for ONNX tensor: conv2d_1/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: Relu2 [Relu] outputs: [conv2d_1/Relu:0 -> (1, 64, 13, 13)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: conv2d_1/Relu:0_pooling [MaxPool]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d_1/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: conv2d_1/Relu:0_pooling [MaxPool] inputs: [conv2d_1/Relu:0 -> (1, 64, 13, 13)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: conv2d_1/Relu:0_pooling for ONNX node: conv2d_1/Relu:0_pooling
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: conv2d_1/Relu:0_pooling0 for ONNX tensor: conv2d_1/Relu:0_pooling0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: conv2d_1/Relu:0_pooling [MaxPool] outputs: [conv2d_1/Relu:0_pooling0 -> (1, 64, 6, 6)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: conv2d_2 [Conv]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d_1/Relu:0_pooling0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d_2/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d_2/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: conv2d_2 [Conv] inputs: [conv2d_1/Relu:0_pooling0 -> (1, 64, 6, 6)], [conv2d_2/kernel:0 -> (128, 64, 3, 3)], [conv2d_2/bias:0 -> (128)],
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:450: Convolution input dimensions: (1, 64, 6, 6)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: conv2d_2 for ONNX node: conv2d_2
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:533: Using kernel: (3, 3), strides: (1, 1), prepadding: (0, 0), postpadding: (0, 0), dilations: (1, 1), numOutputs: 128
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:534: Convolution output dimensions: (1, 128, 4, 4)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: convolution_output for ONNX tensor: convolution_output
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: conv2d_2 [Conv] outputs: [convolution_output -> (1, 128, 4, 4)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: Relu1 [Relu]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: Relu1 [Relu] inputs: [convolution_output -> (1, 128, 4, 4)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: Relu1 for ONNX node: Relu1
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: conv2d_2/Relu:0 for ONNX tensor: conv2d_2/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: Relu1 [Relu] outputs: [conv2d_2/Relu:0 -> (1, 128, 4, 4)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: PushTranspose_0 [Transpose]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: conv2d_2/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: PushTranspose_0 [Transpose] inputs: [conv2d_2/Relu:0 -> (1, 128, 4, 4)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: PushTranspose_0 for ONNX node: PushTranspose_0
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: push_transpose_out_0 for ONNX tensor: push_transpose_out_0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: PushTranspose_0 [Transpose] outputs: [push_transpose_out_0 -> (1, 4, 4, 128)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: flatten [Flatten]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: push_transpose_out_0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: flatten [Flatten] inputs: [push_transpose_out_0 -> (1, 4, 4, 128)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: flatten for ONNX node: flatten
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: flatten/Reshape:0 for ONNX tensor: flatten/Reshape:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: flatten [Flatten] outputs: [flatten/Reshape:0 -> (1, 2048)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: dense [MatMul]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: flatten/Reshape:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: dense/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: dense [MatMul] inputs: [flatten/Reshape:0 -> (1, 2048)], [dense/kernel:0 -> (2048, 64)],
[06/28/2021-16:30:36] [V] [TRT] builtin_op_importers.cpp:2053: GEMM: using FC layer instead of MM because all criteria were met.
[06/28/2021-16:30:36] [V] [TRT] onnx2trt_utils.cpp:1793: Original shape: (1, 2048), unsqueezing to: (1, 1, 1, 2048)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: dense for ONNX node: dense
[06/28/2021-16:30:36] [V] [TRT] onnx2trt_utils.cpp:1641: Original shape: (1, 64, 1, 1), squeezing to: (1, 64)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: dense0 for ONNX tensor: dense0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: dense [MatMul] outputs: [dense0 -> (1, 64)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: Add1 [Add]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: dense0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: dense/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: Add1 [Add] inputs: [dense0 -> (1, 64)], [dense/bias:0 -> (64)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: Add1 for ONNX node: Add1
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: biased_tensor_name1 for ONNX tensor: biased_tensor_name1
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: Add1 [Add] outputs: [biased_tensor_name1 -> (1, 64)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: Relu [Relu]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: biased_tensor_name1
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: Relu [Relu] inputs: [biased_tensor_name1 -> (1, 64)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: Relu for ONNX node: Relu
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: dense/Relu:0 for ONNX tensor: dense/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: Relu [Relu] outputs: [dense/Relu:0 -> (1, 64)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: dense_1 [MatMul]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: dense/Relu:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: dense_1/kernel:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: dense_1 [MatMul] inputs: [dense/Relu:0 -> (1, 64)], [dense_1/kernel:0 -> (64, 10)],
[06/28/2021-16:30:36] [V] [TRT] onnx2trt_utils.cpp:1793: Original shape: (1, 64), unsqueezing to: (1, 1, 1, 64)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: dense_1 for ONNX node: dense_1
[06/28/2021-16:30:36] [V] [TRT] onnx2trt_utils.cpp:1641: Original shape: (1, 10, 1, 1), squeezing to: (1, 10)
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: dense_10 for ONNX tensor: dense_10
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: dense_1 [MatMul] outputs: [dense_10 -> (1, 10)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: Add [Add]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: dense_10
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:119: Searching for input: dense_1/bias:0
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: Add [Add] inputs: [dense_10 -> (1, 10)], [dense_1/bias:0 -> (10)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: Add for ONNX node: Add
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: biased_tensor_name for ONNX tensor: biased_tensor_name
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: Add [Add] outputs: [biased_tensor_name -> (1, 10)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:103: Parsing node: softmax [Softmax]
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:125: softmax [Softmax] inputs: [biased_tensor_name -> (1, 10)],
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:141: Registering layer: softmax for ONNX node: softmax
[06/28/2021-16:30:36] [V] [TRT] ImporterContext.hpp:116: Registering tensor: softmax_1 for ONNX tensor: softmax
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:179: softmax [Softmax] outputs: [softmax -> (1, 10)],
[06/28/2021-16:30:36] [V] [TRT] ModelImporter.cpp:507: Marking softmax_1 as output: softmax
----- Parsing of ONNX model CNN_shaped.onnx is Done ----
[06/28/2021-16:30:36] [V] [TRT] Applying generic optimizations to the graph for inference.
[06/28/2021-16:30:36] [V] [TRT] Original: 27 layers
[06/28/2021-16:30:36] [V] [TRT] After dead-layer removal: 27 layers
[06/28/2021-16:30:36] [V] [TRT] Fusing PushTranspose_0 with flatten
[06/28/2021-16:30:36] [V] [TRT] Fusing PushTranspose_0 + flatten with (Unnamed Layer* 12) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] Fusing (Unnamed Layer* 15) [Constant] with (Unnamed Layer* 16) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] Fusing (Unnamed Layer* 23) [Constant] with (Unnamed Layer* 24) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] Removing (Unnamed Layer* 26) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] Removing (Unnamed Layer* 28) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] After Myelin optimization: 21 layers
[06/28/2021-16:30:36] [V] [TRT] After scale fusion: 21 layers
[06/28/2021-16:30:36] [V] [TRT] -----------SqueezePushDown kSQUEEZE_JOIN case: dense --> (Unnamed Layer* 14) [Shuffle] --> Add1
[06/28/2021-16:30:36] [V] [TRT] -----------SqueezePushDown kSQUEEZE_JOIN case: dense_1 --> (Unnamed Layer* 22) [Shuffle] --> Add
[06/28/2021-16:30:36] [V] [TRT] Fusing (Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] with unsqueeze_node_after_(Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] Fusing (Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle] with unsqueeze_node_after_(Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] -----------SqueezePushDown kSQUEEZE_FORK case: Add1 --> copied_squeeze_after_Add1 --> Relu
[06/28/2021-16:30:36] [V] [TRT] Fusing squeeze_after_Relu with (Unnamed Layer* 20) [Shuffle]
[06/28/2021-16:30:36] [V] [TRT] Fusing conv2d with Relu3
[06/28/2021-16:30:36] [V] [TRT] Fusing conv2d_1 with Relu2
[06/28/2021-16:30:36] [V] [TRT] Fusing conv2d_2 with Relu1
[06/28/2021-16:30:36] [V] [TRT] Fusing (Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] + unsqueeze_node_after_(Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] with Add1
[06/28/2021-16:30:36] [V] [TRT] Fusing (Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] + unsqueeze_node_after_(Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] + Add1 with Relu
[06/28/2021-16:30:36] [V] [TRT] Fusing (Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle] + unsqueeze_node_after_(Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle] with Add
[06/28/2021-16:30:36] [V] [TRT] Fusing dense with (Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] + unsqueeze_node_after_(Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] + Add1 + Relu
[06/28/2021-16:30:36] [V] [TRT] Fusing dense_1 with (Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle] + unsqueeze_node_after_(Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle] + Add
[06/28/2021-16:30:36] [V] [TRT] After vertical fusions: 12 layers
[06/28/2021-16:30:36] [V] [TRT] After final dead-layer removal: 12 layers
[06/28/2021-16:30:36] [V] [TRT] After tensor merging: 12 layers
[06/28/2021-16:30:36] [V] [TRT] After concat removal: 12 layers
[06/28/2021-16:30:36] [V] [TRT] Graph construction and optimization completed in 0.00534046 seconds.
[06/28/2021-16:30:36] [I] [TRT]
[06/28/2021-16:30:36] [I] [TRT] --------------- Layers running on DLA:
[06/28/2021-16:30:36] [I] [TRT] --------------- Layers running on GPU:
[06/28/2021-16:30:36] [I] [TRT] Transpose6, conv2d + Relu3, conv2d/Relu:0_pooling, conv2d_1 + Relu2, conv2d_1/Relu:0_pooling, conv2d_2 + Relu1, PushTranspose_0 + flatten + (Unnamed Layer* 12) [Shuffle], dense + (Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] + unsqueeze_node_after_(Unnamed Layer* 15) [Constant] + (Unnamed Layer* 16) [Shuffle] + Add1 + Relu, squeeze_after_Relu + (Unnamed Layer* 20) [Shuffle], dense_1 + (Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle] + unsqueeze_node_after_(Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle] + Add, copied_squeeze_after_Add, softmax,
[06/28/2021-16:30:38] [V] [TRT] Constructing optimization profile number 0 [1/1].
[06/28/2021-16:30:38] [V] [TRT] --------------- Timing Runner: <reformat> (Reformat)
[06/28/2021-16:30:38] [V] [TRT] Tactic: 1002 time 0.009896
[06/28/2021-16:30:38] [V] [TRT] Tactic: 0 time 0.00804
[06/28/2021-16:30:38] [V] [TRT] Fastest Tactic: 0 Time: 0.00804
[06/28/2021-16:30:38] [V] [TRT] Tactic: 1002 time 0.00762
[06/28/2021-16:30:38] [V] [TRT] Tactic: 0 time 0.007392
[06/28/2021-16:30:38] [V] [TRT] Fastest Tactic: 0 Time: 0.007392
[06/28/2021-16:30:38] [V] [TRT] Tactic: 1002 time 0.012532
[06/28/2021-16:30:38] [V] [TRT] Tactic: 0 time 0.005916
[06/28/2021-16:30:38] [V] [TRT] Fastest Tactic: 0 Time: 0.005916
[06/28/2021-16:30:38] [V] [TRT] Tactic: 1002 time 0.00754
[06/28/2021-16:30:38] [V] [TRT] Tactic: 0 time 0.00458
[06/28/2021-16:30:38] [V] [TRT] Fastest Tactic: 0 Time: 0.00458
[06/28/2021-16:30:38] [V] [TRT] *************** Autotuning format combination: Float(1,3,96,3072) -> Float(1,32,1024,3072) ***************
[06/28/2021-16:30:38] [V] [TRT] --------------- Timing Runner: Transpose6 (Shuffle)
[06/28/2021-16:30:38] [V] [TRT] Tactic: 0 time 0.004536
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1 time 0.006108
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004536
[06/28/2021-16:30:39] [V] [TRT] *************** Autotuning format combination: Float(1,3,96:32,96) -> Float(1,32,1024:32,1024) ***************
[06/28/2021-16:30:39] [V] [TRT] --------------- Timing Runner: Transpose6 (Shuffle)
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.006116
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1 time 0.009392
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.006116
[06/28/2021-16:30:39] [V] [TRT] *************** Autotuning format combination: Half(1,3,96,3072) -> Half(1,32,1024,3072) ***************
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004496
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1 time 0.00624
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004496
[06/28/2021-16:30:39] [V] [TRT] *************** Autotuning format combination: Half(1,3,96:2,1536) -> Half(1,32,1024:2,2048) ***************
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.005312
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1 time 0.010348
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.005312
[06/28/2021-16:30:39] [V] [TRT] *************** Autotuning format combination: Half(4,12,1:8,384) -> Half(1,32,1:8,1024) ***************
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.005852
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1 time 0.01052
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.005852
[06/28/2021-16:30:39] [V] [TRT] --------------- Timing Runner: <reformat> (Reformat)
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.004592
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.00488
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 1002 Time: 0.004592
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.009424
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.00458
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.00458
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.010936
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004448
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004448
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.010224
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004796
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004796
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.007592
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.00542
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.00542
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.007688
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004592
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004592
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.009568
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004472
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004472
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.009308
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004468
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004468
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.009304
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004728
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004728
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.004944
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004932
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004932
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.009176
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.010576
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.004492
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.004492
[06/28/2021-16:30:39] [V] [TRT] Tactic: 1002 time 0.01006
[06/28/2021-16:30:39] [V] [TRT] Tactic: 0 time 0.00448
[06/28/2021-16:30:39] [V] [TRT] Fastest Tactic: 0 Time: 0.00448
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.007624
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004608
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004608
[06/28/2021-16:30:40] [V] [TRT] --------------- Timing Runner: <reformat> (Reformat)
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.00778
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004432
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004432
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.010084
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004504
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004504
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.010408
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004644
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004644
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.00944
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004564
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004564
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.009272
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004888
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004888
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.010392
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004508
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004508
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.00922
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004416
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004416
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.009204
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004476
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004476
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.009512
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.010292
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.00462
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.00462
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1002 time 0.009828
[06/28/2021-16:30:40] [V] [TRT] Tactic: 0 time 0.004572
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 0 Time: 0.004572
[06/28/2021-16:30:40] [V] [TRT] *************** Autotuning format combination: Float(1,32,1024,3072) -> Float(1,30,900,900) ***************
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_interior_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_medium_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x32_relu_interior_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn_winograd) Set Tactic Name: volta_scudnn_winograd_128x128_ldg1_ldg4_relu_tile148t_nt_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_xregs_large_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_small_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_xregs_large_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_small_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_interior_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_medium_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x32_relu_medium_nn_v1
[06/28/2021-16:30:40] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x32_relu_small_nn_v1
[06/28/2021-16:30:40] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (FusedConvActConvolution)
[06/28/2021-16:30:40] [V] [TRT] Tactic: 524287 time 0.009436
[06/28/2021-16:30:40] [V] [TRT] Tactic: 8585215 time 0.010652
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 524287 Time: 0.009436
[06/28/2021-16:30:40] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CaskConvolution)
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1754569683116234317 time 0.016372
[06/28/2021-16:30:40] [V] [TRT] Tactic: 1825138533642645384 time 0.015788
[06/28/2021-16:30:40] [V] [TRT] Tactic: 2733356012094739613 time 0.012668
[06/28/2021-16:30:40] [V] [TRT] Tactic: 2775507031594384867 time 0.00928
[06/28/2021-16:30:40] [V] [TRT] Tactic: 2842488832350522458 time 0.01434
[06/28/2021-16:30:40] [V] [TRT] Tactic: 3915320020053085238 time 0.015636
[06/28/2021-16:30:40] [V] [TRT] Tactic: 6448355332020552203 time 0.0162
[06/28/2021-16:30:40] [V] [TRT] Tactic: 6808617066150061604 time 0.013932
[06/28/2021-16:30:40] [V] [TRT] Tactic: 9091006216302412844 time 0.013632
[06/28/2021-16:30:40] [V] [TRT] Tactic: -8060443123034038864 time 0.014152
[06/28/2021-16:30:40] [V] [TRT] Tactic: -4420849921117327522 time 0.009704
[06/28/2021-16:30:40] [V] [TRT] Tactic: -3946921629105938337 time 0.012328
[06/28/2021-16:30:40] [V] [TRT] Fastest Tactic: 2775507031594384867 Time: 0.00928
[06/28/2021-16:30:40] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CudaConvolution)
[06/28/2021-16:30:41] [V] [TRT] Tactic: 0 time 0.019008
[06/28/2021-16:30:41] [V] [TRT] Tactic: 2 time 0.01892
[06/28/2021-16:30:41] [V] [TRT] Tactic: 5 time 0.050928
[06/28/2021-16:30:41] [V] [TRT] Tactic: 6 time 0.024464
[06/28/2021-16:30:41] [V] [TRT] Tactic: 57 time 0.019484
[06/28/2021-16:30:41] [V] [TRT] Fastest Tactic: 2 Time: 0.01892
[06/28/2021-16:30:41] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CudaDepthwiseConvolution)
[06/28/2021-16:30:41] [V] [TRT] CudaDepthwiseConvolution has no valid tactics for this config, skipping
[06/28/2021-16:30:41] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: CaskConvolution Tactic: 2775507031594384867
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn_winograd) Set Tactic Name: volta_scudnn_winograd_128x128_ldg1_ldg4_relu_tile148t_nt_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_interior_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_medium_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x32_relu_interior_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_xregs_large_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_small_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x128_relu_xregs_large_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_small_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_interior_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x64_relu_medium_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x32_relu_medium_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (scudnn) Set Tactic Name: volta_scudnn_128x32_relu_small_nn_v1
[06/28/2021-16:30:41] [V] [TRT] *************** Autotuning format combination: Half(1,32,1024,3072) -> Half(1,30,900,900) ***************
[06/28/2021-16:30:41] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (FusedConvActConvolution)
[06/28/2021-16:30:41] [V] [TRT] FusedConvActConvolution has no valid tactics for this config, skipping
[06/28/2021-16:30:41] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CaskConvolution)
[06/28/2021-16:30:41] [V] [TRT] CaskConvolution has no valid tactics for this config, skipping
[06/28/2021-16:30:41] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CudaConvolution)
[06/28/2021-16:30:41] [V] [TRT] Tactic: 0 time 0.019292
[06/28/2021-16:30:41] [V] [TRT] Tactic: 1 time 0.019008
[06/28/2021-16:30:41] [V] [TRT] Tactic: 2 time 0.02002
[06/28/2021-16:30:41] [V] [TRT] Tactic: 4 time 0.042012
[06/28/2021-16:30:41] [V] [TRT] Tactic: 5 time 0.04676
[06/28/2021-16:30:41] [V] [TRT] Tactic: 6 time 0.112576
[06/28/2021-16:30:41] [V] [TRT] Fastest Tactic: 1 Time: 0.019008
[06/28/2021-16:30:41] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: CudaConvolution Tactic: 1
[06/28/2021-16:30:41] [V] [TRT] *************** Autotuning format combination: Half(1,32,1024:2,2048) -> Half(1,30,900:2,900) ***************
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x64_relu_large_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x64_relu_medium_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x32_relu_medium_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x64_relu_small_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x128_relu_small_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x32_relu_large_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x64_relu_interior_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x32_relu_interior_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x128_relu_medium_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn_winograd) Set Tactic Name: volta_fp16x2_hcudnn_winograd_fp16x2_128x128_ldg1_ldg4_relu_tile148t_nt_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x128_relu_interior_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x32_relu_small_nn_v1
[06/28/2021-16:30:41] [V] [TRT] conv2d + Relu3 (hcudnn) Set Tactic Name: volta_fp16x2_hcudnn_fp16x2_128x128_relu_large_nn_v1
[06/28/2021-16:30:41] [V] [TRT] Tactic: 1145226902788474763 time 0.012436
[06/28/2021-16:30:41] [V] [TRT] Tactic: 2418518597804310654 time 0.010824
[06/28/2021-16:30:41] [V] [TRT] Tactic: 8292881859266835088 time 0.012216
[06/28/2021-16:30:41] [V] [TRT] Tactic: 8401509141903434922 time 0.01136
[06/28/2021-16:30:41] [V] [TRT] Tactic: -8654297089785671176 time 0.01226
[06/28/2021-16:30:41] [V] [TRT] Tactic: -7448936905981214224 time 0.012352
[06/28/2021-16:30:41] [V] [TRT] Tactic: -7140760933967189247 time 0.011264
[06/28/2021-16:30:41] [V] [TRT] Tactic: -4097850214384059472 time 0.011092
[06/28/2021-16:30:41] [V] [TRT] Tactic: -3689982367035295496 time 0.012744
[06/28/2021-16:30:41] [V] [TRT] Tactic: -3140347171730126532 time 0.00912
[06/28/2021-16:30:41] [V] [TRT] Tactic: -2534402059426524406 time 0.012864
[06/28/2021-16:30:41] [V] [TRT] Tactic: -2027588946874785071 time 0.010988
[06/28/2021-16:30:41] [V] [TRT] Tactic: -245090590808296743 time 0.012776
[06/28/2021-16:30:41] [V] [TRT] Fastest Tactic: -3140347171730126532 Time: 0.00912
[06/28/2021-16:30:41] [V] [TRT] CudaConvolution has no valid tactics for this config, skipping
[06/28/2021-16:30:41] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: CaskConvolution Tactic: -3140347171730126532
[06/28/2021-16:30:41] [V] [TRT] *************** Autotuning format combination: Half(1,32,1:4,1024) -> Half(1,30,1:8,900) ***************
[06/28/2021-16:30:41] [V] [TRT] *************** Autotuning format combination: Half(1,32,1:8,1024) -> Float(1,30,900,900) ***************
[06/28/2021-16:30:41] [V] [TRT] *************** Autotuning format combination: Half(1,32,1:8,1024) -> Half(1,30,1:8,900) ***************
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x64_ldg8_relu_exp_interior_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_128x128_ldg8_relu_exp_small_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_128x128_ldg8_relu_exp_interior_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x128_ldg8_relu_exp_medium_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x64_sliced1x2_ldg8_relu_exp_medium_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x64_ldg8_relu_exp_medium_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x64_sliced1x2_ldg8_relu_exp_small_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_128x128_ldg8_relu_exp_medium_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x128_ldg8_relu_exp_interior_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x128_ldg8_relu_exp_small_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x64_ldg8_relu_exp_small_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] conv2d + Relu3 (h884cudnn) Set Tactic Name: volta_h884cudnn_256x64_sliced1x2_ldg8_relu_exp_interior_nhwc_tn_v1
[06/28/2021-16:30:42] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (FusedConvActConvolution)
[06/28/2021-16:30:42] [V] [TRT] FusedConvActConvolution has no valid tactics for this config, skipping
[06/28/2021-16:30:42] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CaskConvolution)
[06/28/2021-16:30:42] [V] [TRT] Tactic: 2105695814191699972 time 0.016976
[06/28/2021-16:30:42] [V] [TRT] Tactic: 3754069740140581927 time 0.017064
[06/28/2021-16:30:42] [V] [TRT] Tactic: 5666160310350604399 time 0.017132
[06/28/2021-16:30:42] [V] [TRT] Tactic: 5925270497649423688 time 0.02354
[06/28/2021-16:30:42] [V] [TRT] Tactic: 6680916730816870145 time 0.02564
[06/28/2021-16:30:42] [V] [TRT] Tactic: 7158029511300006471 time 0.01716
[06/28/2021-16:30:42] [V] [TRT] Tactic: 7859952145590271433 time 0.025368
[06/28/2021-16:30:42] [V] [TRT] Tactic: 8283847742354150423 time 0.017156
[06/28/2021-16:30:42] [V] [TRT] Tactic: -8391760416076885205 time 0.023116
[06/28/2021-16:30:42] [V] [TRT] Tactic: -4534876761957424274 time 0.023672
[06/28/2021-16:30:42] [V] [TRT] Tactic: -3237051169894153788 time 0.017084
[06/28/2021-16:30:42] [V] [TRT] Tactic: -2422160065350346448 time 0.025408
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 2105695814191699972 Time: 0.016976
[06/28/2021-16:30:42] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CudaConvolution)
[06/28/2021-16:30:42] [V] [TRT] CudaConvolution has no valid tactics for this config, skipping
[06/28/2021-16:30:42] [V] [TRT] --------------- Timing Runner: conv2d + Relu3 (CudaDepthwiseConvolution)
[06/28/2021-16:30:42] [V] [TRT] CudaDepthwiseConvolution has no valid tactics for this config, skipping
[06/28/2021-16:30:42] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: CaskConvolution Tactic: 2105695814191699972
[06/28/2021-16:30:42] [V] [TRT] --------------- Timing Runner: <reformat> (Reformat)
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.004616
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004564
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004564
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.00812
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.00462
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.00462
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.009304
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004356
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004356
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.00486
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004576
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004576
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.00782
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004556
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004556
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.009164
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004548
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004548
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.007556
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004584
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004584
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.0083
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004468
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004468
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.009012
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004472
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004472
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.006164
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004484
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004484
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.007788
[06/28/2021-16:30:42] [V] [TRT] Tactic: 1002 time 0.009384
[06/28/2021-16:30:42] [V] [TRT] Tactic: 0 time 0.004488
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: 0 Time: 0.004488
[06/28/2021-16:30:42] [V] [TRT] *************** Autotuning format combination: Float(1,30,900,900) -> Float(1,15,225,225) ***************
[06/28/2021-16:30:42] [V] [TRT] --------------- Timing Runner: conv2d/Relu:0_pooling (Pooling)
[06/28/2021-16:30:42] [V] [TRT] Tactic: -1 time 0.005344
[06/28/2021-16:30:42] [V] [TRT] Fastest Tactic: -1 Time: 0.005344
[06/28/2021-16:30:42] [V] [TRT] --------------- Timing Runner: conv2d/Relu:0_pooling (TiledPooling)
[06/28/2021-16:30:42] [V] [TRT] Tactic: 5505281 time 0.004644
[06/28/2021-16:30:42] [V] [TRT] Tactic: 5570817 time 0.004492
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5636353 time 0.004656
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5701889 time 0.004548
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5767425 time 0.004452
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5832961 time 0.004532
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5898497 time 0.00468
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5964033 time 0.004724
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6029569 time 0.00478
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6095105 time 0.004592
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6160641 time 0.004564
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6226177 time 0.004708
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6291713 time 0.004732
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6357249 time 0.004648
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6422785 time 0.004536
[06/28/2021-16:30:43] [V] [TRT] Tactic: 6488321 time 0.00474
[06/28/2021-16:30:43] [V] [TRT] Fastest Tactic: 5767425 Time: 0.004452
[06/28/2021-16:30:43] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: TiledPooling Tactic: 5767425
[06/28/2021-16:30:43] [V] [TRT] *************** Autotuning format combination: Half(1,30,900,900) -> Half(1,15,225,225) ***************
[06/28/2021-16:30:43] [V] [TRT] --------------- Timing Runner: conv2d/Relu:0_pooling (Pooling)
[06/28/2021-16:30:43] [V] [TRT] Tactic: -1 time 0.004664
[06/28/2021-16:30:43] [V] [TRT] Fastest Tactic: -1 Time: 0.004664
[06/28/2021-16:30:43] [V] [TRT] --------------- Timing Runner: conv2d/Relu:0_pooling (TiledPooling)
[06/28/2021-16:30:43] [V] [TRT] TiledPooling has no valid tactics for this config, skipping
[06/28/2021-16:30:43] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: Pooling Tactic: -1
[06/28/2021-16:30:43] [V] [TRT] *************** Autotuning format combination: Half(1,30,900:2,900) -> Half(1,15,225:2,225) ***************
[06/28/2021-16:30:43] [V] [TRT] Tactic: -3 time 0.004588
[06/28/2021-16:30:43] [V] [TRT] Fastest Tactic: -3 Time: 0.004588
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5505281 time 0.004816
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5570817 time 0.004912
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5636353 time 0.0047
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5701889 time 0.004924
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5767425 time 0.004696
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5832961 time 0.0044
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5898497 time 0.004464
[06/28/2021-16:30:43] [V] [TRT] Tactic: 5964033 time 0.005296
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6029569 time 0.004532
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6095105 time 0.004492
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6160641 time 0.004724
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6226177 time 0.004768
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6291713 time 0.004708
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6357249 time 0.004452
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6422785 time 0.00504
[06/28/2021-16:30:44] [V] [TRT] Tactic: 6488321 time 0.004932
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 5832961 Time: 0.0044
[06/28/2021-16:30:44] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: TiledPooling Tactic: 5832961
[06/28/2021-16:30:44] [V] [TRT] *************** Autotuning format combination: Half(1,30,1:8,900) -> Half(1,15,1:8,225) ***************
[06/28/2021-16:30:44] [V] [TRT] --------------- Timing Runner: conv2d/Relu:0_pooling (Pooling)
[06/28/2021-16:30:44] [V] [TRT] Tactic: -2 time 0.004848
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: -2 Time: 0.004848
[06/28/2021-16:30:44] [V] [TRT] --------------- Timing Runner: conv2d/Relu:0_pooling (TiledPooling)
[06/28/2021-16:30:44] [V] [TRT] TiledPooling has no valid tactics for this config, skipping
[06/28/2021-16:30:44] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: Pooling Tactic: -2
[06/28/2021-16:30:44] [V] [TRT] --------------- Timing Runner: <reformat> (Reformat)
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.004816
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.004488
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.004488
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.006104
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.0072
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.00454
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.00454
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.007516
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.00462
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.00462
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.00456
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.004444
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.004444
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.006416
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.007792
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.004624
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.004624
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.006216
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.004544
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.004544
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.007468
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.004612
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.004612
[06/28/2021-16:30:44] [V] [TRT] Tactic: 1002 time 0.008212
[06/28/2021-16:30:44] [V] [TRT] Tactic: 0 time 0.00468
[06/28/2021-16:30:44] [V] [TRT] Fastest Tactic: 0 Time: 0.00468
[06/28/2021-16:31:01] [I]
&&&& PASSED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=CNN_shaped.onnx --fp16 --workspace=2048 --saveEngine=CNN_shaped.trt --verbose --dumpProfile
