when I used TensorRT to complete the forward inference of simple network on GTX1070, batchsize is 5, the performance is lower than using caffe directly, I wonder whether 1070 can not let tensorrt play ies part?
layer {
type: "Input"
top: "data"
input_param { shape: { dim: 5 dim: 3 dim: 96 dim: 96 } }
layer {
type: "Convolution"
bottom: "data"
top: "conv1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 7
stride: 2
weight_filler {
type: "gaussian"
std: 0.01
bias_filler {
type: "constant"
value: 0.1
layer {
type: "ReLU"
bottom: "conv1"
top: "conv1"
layer {
type: "LRN"
bottom: "conv1"
top: "norm1"
lrn_param {
local_size: 5
alpha: 0.0005
beta: 0.75
k: 2
layer {
type: "Pooling"
bottom: "norm1"
top: "pool1"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 5
stride: 2
weight_filler {
type: "gaussian"
std: 0.01
bias_filler {
type: "constant"
value: 0.1
layer {
type: "ReLU"
bottom: "conv2"
top: "conv2"
layer {
type: "LRN"
bottom: "conv2"
top: "norm2"
lrn_param {
local_size: 5
alpha: 0.0005
beta: 0.75
k: 2
layer {
type: "Pooling"
bottom: "norm2"
top: "pool2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool2"
top: "conv3_"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "gaussian"
std: 0.01
bias_filler {
type: "constant"
value: 0.1
layer {
type: "ReLU"
bottom: "conv3_"
top: "conv3_"
layer {
type: "Convolution"
bottom: "conv3_"
top: "conv4_"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "gaussian"
std: 0.01
bias_filler {
type: "constant"
value: 0.1
layer {
type: "ReLU"
bottom: "conv4_"
top: "conv4_"
layer {
type: "Convolution"
bottom: "conv4_"
top: "conv5_"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "gaussian"
std: 0.01
bias_filler {
type: "constant"
value: 0.1
layer {
type: "ReLU"
bottom: "conv5_"
top: "conv5_"
layer {
type: "InnerProduct"
bottom: "conv5_"
top: "pool5/classifier_"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
inner_product_param {
num_output: 128
weight_filler {
type: "gaussian"
std: 0.01
bias_filler {
type: "constant"
value: 0.1
layer {
type: "ReLU"
bottom: "pool5/classifier_"
layer {
type: "Dropout"
dropout_param {
dropout_ratio: 0.4
