Good day everyone!
I have a problem performing batch inference in TensorRT. When the batch size is 1 it works like a charm, but when I change it to any other number it gives out plain garbage.
Step by step, I downloaded TensorRT (5.0) and installed it on my Ubuntu 18.04 laptop with GTX755M. I then built the samples that went with it and tested it on sampleMNIST sample and it worked OK. I then proceeded to change every occurrence of mParams.batchSize to 10. Of course I also changed the size of allocated memory and modified result printing along. But after I recompiled the sample I got completely weird results - the output says 80% 7 20% 1 for every given input:
grim@shigoto:~/tensorrt/bin$ ./sample_mnist
Building and running a GPU inference engine for MNIST
Input:
Output:
0:
1: ********
2:
3:
4:
5:
6:
7: **
8:
9:
This output repeats 10 times. I’ve tried this with different networks but results were similar, most of networks give 1 correct output and plain garbage the other 9 times. The complete sample can be found here: https://gist.github.com/GrimMaple/f64693887452a9c659d3e48a0161098a. I’ve tried googling documentation but I can’t understand what I’m doing wrong. Could you please tell me what am I doing wrong or how to perform batch inference correctly in TensorRT?
