• Hardware (Jetson TX2 xavier NX JetPack 4.6)
• Network Type (bodypostNet)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Do you mean you still get bad result in Geforce 1080Ti machine? Could you share below info in your Geforce 1080Ti machine?
$ dpkg -l |grep cuda
$ ls -rltsh models/bodypose2d/
@ai:~/src/deepstream_tao_apps$ dpkg -l |grep cuda
ii cuda 11.5.1-1 amd64 CUDA meta-package
ii cuda-11-5 11.5.2-1 amd64 CUDA 11.5 meta-package
ii cuda-cccl-11-5 11.5.62-1 amd64 CUDA CCCL
ii cuda-command-line-tools-11-5 11.5.2-1 amd64 CUDA command-line tools
ii cuda-compiler-11-5 11.5.2-1 amd64 CUDA compiler
ii cuda-cudart-11-5 11.5.117-1 amd64 CUDA Runtime native Libraries
ii cuda-cudart-dev-11-5 11.5.117-1 amd64 CUDA Runtime native dev links, headers
ii cuda-cuobjdump-11-5 11.5.119-1 amd64 CUDA cuobjdump
ii cuda-cupti-11-5 11.5.114-1 amd64 CUDA profiling tools runtime libs.
ii cuda-cupti-dev-11-5 11.5.114-1 amd64 CUDA profiling tools interface.
ii cuda-cuxxfilt-11-5 11.5.119-1 amd64 CUDA cuxxfilt
ii cuda-demo-suite-11-5 11.5.50-1 amd64 Demo suite for CUDA
ii cuda-documentation-11-5 11.5.114-1 amd64 CUDA documentation
ii cuda-driver-dev-11-5 11.5.117-1 amd64 CUDA Driver native dev stub library
ii cuda-drivers 495.29.05-1 amd64 CUDA Driver meta-package, branch-agnostic
ii cuda-drivers-495 495.29.05-1 amd64 CUDA Driver meta-package, branch-specific
ii cuda-gdb-11-5 11.5.114-1 amd64 CUDA-GDB
ii cuda-libraries-11-5 11.5.2-1 amd64 CUDA Libraries 11.5 meta-package
ii cuda-libraries-dev-11-5 11.5.2-1 amd64 CUDA Libraries 11.5 development meta-package
ii cuda-memcheck-11-5 11.5.114-1 amd64 CUDA-MEMCHECK
ii cuda-nsight-11-5 11.5.114-1 amd64 CUDA nsight
ii cuda-nsight-compute-11-5 11.5.2-1 amd64 NVIDIA Nsight Compute
ii cuda-nsight-systems-11-5 11.5.2-1 amd64 NVIDIA Nsight Systems
ii cuda-nvcc-11-5 11.5.119-1 amd64 CUDA nvcc
ii cuda-nvdisasm-11-5 11.5.119-1 amd64 CUDA disassembler
ii cuda-nvml-dev-11-5 11.5.50-1 amd64 NVML native dev links, headers
ii cuda-nvprof-11-5 11.5.114-1 amd64 CUDA Profiler tools
ii cuda-nvprune-11-5 11.5.119-1 amd64 CUDA nvprune
ii cuda-nvrtc-11-5 11.5.119-1 amd64 NVRTC native runtime libraries
ii cuda-nvrtc-dev-11-5 11.5.119-1 amd64 NVRTC native dev links, headers
ii cuda-nvtx-11-5 11.5.114-1 amd64 NVIDIA Tools Extension
ii cuda-nvvp-11-5 11.5.126-1 amd64 CUDA Profiler tools
ii cuda-runtime-11-5 11.5.2-1 amd64 CUDA Runtime 11.5 meta-package
ii cuda-samples-11-5 11.5.56-1 amd64 CUDA example applications
ii cuda-sanitizer-11-5 11.5.114-1 amd64 CUDA Sanitizer
rc cuda-toolkit-11-4-config-common 11.4.148-1 all Common config package for CUDA Toolkit 11.4.
ii cuda-toolkit-11-5 11.5.2-1 amd64 CUDA Toolkit 11.5 meta-package
ii cuda-toolkit-11-5-config-common 11.5.117-1 all Common config package for CUDA Toolkit 11.5.
ii cuda-toolkit-11-config-common 11.6.55-1 all Common config package for CUDA Toolkit 11.
ii cuda-toolkit-config-common 11.6.55-1 all Common config package for CUDA Toolkit.
ii cuda-tools-11-5 11.5.2-1 amd64 CUDA Tools meta-package
ii cuda-visual-tools-11-5 11.5.2-1 amd64 CUDA visual tools
ii nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.2.1.8-ga-20211117 1-1 amd64 nv-tensorrt repository configuration files
@ai:~/src/deepstream_tao_apps$ ls -rltsh models/bodypose2d/
total 65M
65M -rw-rw-r-- 1 laokc laokc 65M Jun 24 10:27 model.etlt
4.0K -rw-rw-r-- 1 laokc laokc 1.0K Jun 24 10:27 labels.txt
4.0K -rw-rw-r-- 1 laokc laokc 2.3K Jun 24 10:27 int8_calibration_320_448.txt
4.0K -rw-rw-r-- 1 laokc laokc 2.3K Jun 24 10:27 int8_calibration_288_384.txt
4.0K -rw-rw-r-- 1 laokc laokc 2.3K Jun 24 10:27 int8_calibration_224_320.txt
