• Hardware (Jetson TX2 xavier NX JetPack4.6)
• Network Type (bodypostNet)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
step1:
git clone GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream
step2:
cd deepstream_tao_apps/configs/bodypose2d_tao
vim bodypose2d_pgie_config.txt
int8-calib-file=…/…/models/bodypose2d/int8_calibration_320_448.txt
infer-dims=3;320;384
network-mode=1
step3:cd deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app
./deepstream-bodypose2d-app 1 …/…/…/configs/bodypose2d_tao/sample_bodypose2d_model_config.txt file:///media/nvidia/SD/src/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app/dance.mp4 ./body2dout
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
terminate called after throwing an instance of ‘std::runtime_error’
what(): invalid input pafmap dimension.
Aborted (core dumped)
Thank you for your attention, these are two problems, 1. It is possible to use the default configuration of 3x288x384 with int8, but the effect is too bad. I want to use a larger size of 3x320x448 on int8, but an error is reported; 2. From fp16 to int8 detection The effect is too bad, I don’t know if there is a problem with the int8 calibration file
Thank you for your attention. The default configuration of 3x288x384 can be run with int8, but the effect is too bad. I want to use a larger size of 3x320x448 on int8. The official also gave 3 calibration files for reference: https://catalog.ngc. nvidia.com/orgs/nvidia/teams/tao/models/bodyposenet/files
command:
tao-converter -k nvidia_tlt -p input_1:0,1x320x448x3,1x320x448x3,1x320x448x3 model.etlt -t int8 -c int8_calibration_320_448.txt -e tao-converter.model_int8_b1_320_448.engine -b 1
the conversion of tao-converter to engine does not report an error, and the same error is printed when running
