Where an I download TensorRT 6 tar file
Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 6
Nvidia Driver Version:
CUDA Version: 10.1
I use many version of Cuda and I want To install TensorRT 6 for cuda 10.1 using his tar-file but I didn’t see it online. Please where can I install it.
Hi @romeokamgo,
You can download TensorRT here. We recommend you to install latest 7.2.x trt version.
https://developer.nvidia.com/nvidia-tensorrt-download#
Thank you.
I already have TensorRT installed but I encounter some Error during the Conversion of TensorFlow Model to TensorFlow-TensorRT Model. Exactly:
2021-04-06 10:32:01.542645: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2021-04-06 10:32:08.730981: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcuda.so.1
2021-04-06 10:32:08.843516: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1716] Found device 0 with properties:
pciBusID: 0000:01:00.0 name: GeForce GTX 1060 6GB computeCapability: 6.1
coreClock: 1.7085GHz coreCount: 10 deviceMemorySize: 5.93GiB deviceMemoryBandwidth: 178.99GiB/s
2021-04-06 10:32:08.843597: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2021-04-06 10:32:09.204673: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcublas.so.10
2021-04-06 10:32:09.220725: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcufft.so.10
2021-04-06 10:32:09.224209: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcurand.so.10
2021-04-06 10:32:09.278126: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusolver.so.10
2021-04-06 10:32:09.309410: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusparse.so.10
2021-04-06 10:32:09.463930: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudnn.so.7
2021-04-06 10:32:09.465787: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1858] Adding visible gpu devices: 0
2021-04-06 10:32:09.513535: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library ‘libnvinfer.so.6’; dlerror: libnvinfer.so.6: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda/lib64:/usr/local/cuda-10.1/lib64:/usr/local/cuda-10.2/lib64:/usr/local/cuda-11/lib64:/usr/local/cuda-11.1/lib64:/usr/local/cuda-11.2/lib64:/usr/local/cuda/lib64:/usr/local/cuda-10.1/lib64:/usr/local/cuda-10.2/lib64:/usr/local/cuda-11/lib64:/usr/local/cuda-11.1/lib64:/usr/local/cuda-11.2/lib64
Please refer to the installation steps from the below link if in case you are missing on anything
Also, we suggest you to use TRT NGC containers to avoid any system dependency related issues.
Thank you so much.
I have verified the installation its good.
I think I will use the container. Thanks!
