Where can I find Open GLES3.x libraries for jetson tk1?
Found EGL, GLES1 and GLES2 libraries at the following location:
/usr/lib/arm-linux-gnueabihf/tegra-egl/
libEGL.so.1
libGLESv1_CM.so.1
libGLESv2.so.2
/usr/lib/arm-linux-gnueabihf/mesa-egl
libEGL.so.1.0.0
libGLESv2.so.2.0.0
Does any one know a location or link to get the GLES3.x libraries for TK1?
Appreciate the help in advance.
Thanks,
Does that application then explicitly link against some libGLESv3.so and fails to start because the library isn’t found? Or doesn it try to load it run time and fails because it doesn’t find it?
If the application just tries to find something called libGLESv3.so, try linking the libGLESv2.so.2 in /usr/lib/arm-linux-gnueabihf/tegra-egl/ with that name and see what happens (you may try linking it under /usr/lib/ just in case the application is too hardcoded).
