Where is torchvision 0.20.0 for Jetpack 6.2.1
I’m using jetpack 6.2.1 in Jetson AGX Orin,and I found torch 2.5.0 for jp62. Unfortunately, I haven’t found torchvision 0.20.0 suitable for torch 2.5.0. Does anyone know the address of torchvision 0.20.0 wheel suitable for Jetson AGX Orin ?
I understand you’re using Jetpack 6.2.1 on Jetson AGX Orin and have found PyTorch 2.5.0 for JP6.2, but you’re having trouble finding a compatible torchvision 0.2.0 wheel.
After reviewing the context, I found that the CUDA Containers for Edge AI & Robotics section mentions that Ubuntu 24.04 containers for JetPack 6 are now available, which includes CUDA support. However, this might not directly help you with your specific issue.
Regarding your question, I couldn’t find a direct answer in the provided context. However, I can suggest some possible solutions:
  1. Check the NVIDIA PyTorch website: You can visit the NVIDIA PyTorch website and look for the torchvision 0.2.0 wheel compatible with Jetson AGX Orin and Jetpack 6.2.1. They might have a specific wheel available for your setup.
  2. Use the pip3 install method: As mentioned in the CUDA Containers for Edge AI & Robotics section, you can try installing torchvision using pip3 with the --index-url option pointing to the NVIDIA PyTorch repository. This might help you find the correct wheel for your setup.
  3. Check the Torch-TensorRT section: Although not directly related to your question, the Torch-TensorRT section mentions that it provides a simple API for leveraging inference optimizations of TensorRT on NVIDIA GPUs. You might find some relevant information or alternatives in this section.
Unfortunately, I couldn’t find the exact address of the torchvision 0.2.0 wheel suitable for Jetson AGX Orin. I recommend trying the above suggestions and exploring the NVIDIA PyTorch website for more information.
If you have any further questions or need more assistance, feel free to ask!
Thanks for your reply, but I didn’t get any specific operation or information. Does torchvision 0.20.0 for torch 2.5.0 exist ? If not, do I have to build torchvision 0.20.0 from source code?
You can find our PyTorch/TorchVision package for JetPack 6.2.1 in the link below:
If you need the exact 0.20.0 TorchVision, you can build it from the source.
OK,thanks for your reply.
