I want to modify the "AppDecGL" sample code to a HDR player.
But I am not sure whether GeForce 1080 support 10bit output over HDMI or Dport.
The information from forum is not clear.
Yongmin
Yongmin
Yes, GeForce 1080 has all capabilities needed to set up a HDR output.
Thanks,
Ryan Park
Hi Ryan,
Thanks for your reply.
The point is [b]Ubuntu
[/b].
Under Win10 I can use the Sample code output HDR signal, the TV connected with the GPU board can recognize the HDR signal.
But under Ubuntu I use the Sample code, the TV connect with the GPU can't enter HDR mode. Some thread said that maybe I need to change Xconfig of the Ubuntu.
I just want to confirm whether the linux driver support 10bit as windows.
Vincent.
