Whether the stream of acc_get_cuda_stream() and async() are the same
I try to do a cuda function, such as cusolverDnXgesvd. Before excuting this function, a handle should be created, which need to be tied a cuda stream. For example:
    istat = cusolverDnCreate(handle)
    istat = cusolverDnSetStream(handle,acc_get_cuda_stream(22))
When finishing the cusolverDnXgesvd function, the vector or matrix is usually copied to the host from device. However, this program must be excuted on the device, i.e. between a kernel with a specified thread. For example:
    !$acc kernels async(22) copy(S_c)
    !$acc loop
        do I=1,cols
            S_c(i) = S(i)
        enddo
    !$acc end kernels
I am not sure that both of the stream tied the handle and the label in the async all indicate the same stream. Two part wiil be run following the order or concurrent? I can give you some codes I test the function I use.
SUBROUTINE test_cusolverDnXgesvd
    IMPLICIT NONE
    INTEGER(4)::i
    !============= CUSPARSE APIs =============
    type(cusolverDnHandle):: handle								! A handle that handle to the cuSolver library context
    type(cusolverDnParams) :: params								! A handle that handle to the cuSolver library context
    INTEGER(KIND=8), parameter ::rows=2, cols=2 											! The number of rows of the dense matrix
    INTEGER(KIND=4):: istat											! This data type represents the status returned by the library functions and it can have the values from 0 to 31
    INTEGER(KIND=8), parameter :: lda=rows, ldu=rows, ldvt=cols
    CHARACTER(1) :: jobu, jobvt
    integer(8) :: workspaceInBytesOnDevice, workspaceInBytesOnHost
    REAL(KIND=8), device:: A(rows,cols)
    REAL(KIND=8), device:: S(cols)
    REAL(KIND=8), device:: U(ldu,rows)
    REAL(KIND=8), device:: VT(ldvt,cols)
    INTEGER(1), DIMENSION(:), device, ALLOCATABLE :: bufferOnDevice
    INTEGER(1), DIMENSION(:), ALLOCATABLE :: bufferOnHost
    integer(4), device :: devinfo
    REAL(KIND=8):: S_c(cols)
    istat = cusolverDnCreateParams(params)
    istat = cusolverDnSetAdvOptions(params, CUSOLVERDN_GETRF, CUSOLVER_ALG_0)
    jobu  = "A"
    jobvt = "A"
    S_c = 0
    A(1,:) =(/1,-2/)
    A(2,:) =(/1,2/)
    ! A(3,:) =(/2,1/)
    istat = cusolverDnXgesvd_bufferSize(handle,params,jobu,jobvt,rows,cols,cudaDataType(CUDA_R_64F),&
                                A,lda,cudaDataType(CUDA_R_64F),S,cudaDataType(CUDA_R_64F),U,ldu,&
                                cudaDataType(CUDA_R_64F),VT,ldvt,cudaDataType(CUDA_R_64F),&
                                workspaceInBytesOnDevice, workspaceInBytesOnHost)
    allocate(bufferOnDevice(workspaceInBytesOnDevice) , bufferOnHost(workspaceInBytesOnHost)  )
    istat = cusolverDnXgesvd(handle,params,jobu,jobvt,rows,cols,cudaDataType(CUDA_R_64F),&
            bufferOnDevice,workspaceInBytesOnDevice,&
            bufferOnHost,workspaceInBytesOnHost,&
            devinfo)
    !$acc kernels copy(S_c)
    !$acc loop
        do I=1,cols
            S_c(i) = S(i)
        enddo
    !$acc end kernels
    write(*,*)S_C
    istat = cusolverDnDestroy(handle)
    istat = cusolverDnDestroyParams(params)
    istat = cudaStreamDestroy(acc_get_cuda_stream(22))
    deallocate(bufferOnDevice,bufferOnHost)
    stop
END SUBROUTINE test_cusolverDnXgesvd
You can call this subroutine directly and the correct results can be obtained (2.828427124, 1.4142135623). However, the results are incorrect if you add “async(22)” as flag of kernels.
Best wishes,
Amor
