Hi expters,
I download Jetson_Linux_r36.4.3_aarch64.tbz2 https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.3/release/Jetson_Linux_r36.4.3_aarch64.tbz2
And then burn orin nx with below command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3768-0000-p3767-0000-a0-nvme external
after board boots up, I found out there are lots of dtb and dtbo files in /boot DIR
could you please tell which dtb file is used and which part of code load the dtb and kernel?
I am not familiar with uefi, I used u-boot before
I also run below command, is there any doc to show what is saved in below partitions?
And how to mount the “Microsoft basic data” type partitions
~$ sudo fdisk -l
Device Start End Sectors Size Type
/dev/nvme0n1p1 3050048 500118151 497068104 237G Microsoft basic data
/dev/nvme0n1p2 40 262183 262144 128M Microsoft basic data
/dev/nvme0n1p3 262184 263719 1536 768K Microsoft basic data
/dev/nvme0n1p4 263720 328487 64768 31.6M Microsoft basic data
/dev/nvme0n1p5 328488 590631 262144 128M Microsoft basic data
/dev/nvme0n1p6 590632 592167 1536 768K Microsoft basic data
/dev/nvme0n1p7 592168 656935 64768 31.6M Microsoft basic data
/dev/nvme0n1p8 656936 820775 163840 80M Microsoft basic data
/dev/nvme0n1p9 820776 821799 1024 512K Microsoft basic data
/dev/nvme0n1p10 821800 952871 131072 64M EFI System
/dev/nvme0n1p11 952872 1116711 163840 80M Microsoft basic data
/dev/nvme0n1p12 1116712 1117735 1024 512K Microsoft basic data
/dev/nvme0n1p13 1117736 1248807 131072 64M Microsoft basic data
/dev/nvme0n1p14 1248832 2068031 819200 400M Microsoft basic data
/dev/nvme0n1p15 2068032 3050047 982016 479.5M Microsoft basic data
thanks,
LImeng
