Jetson.I keep getting this error when I’m trying to use the GPIO library manually, and I’ve also tried to install using pip.It continues in the same way.Help me, please.
hello furkant,
it looks you did not setup enviroment correctly,
are you able to execute python -V, or python --version command on your terminal to check the Python version has reported?
