I pulled down and smoke tested a GLM 5.3 Flash build and was impressed there is still some tuning an optimization to go. I know @MiaAI_Lab announced she is now working with them. I am curious if anyone else has worked with it or tested with it yet?
here we are running 2dgx spark on GLM 5.3 flash on tensorfold EXL3 4bit obliterated model.
We have amazing 62 tok/s peak an combined of more than 97tok/s. Easily more speed achivable !! also LOAD TIMES ARE AMAZING .
give it a try
62tk/s single stream or combined?
single stream42 , 97 combined x4
Does the abliterated model hallucinate alot more? I’ve heard those get quite damaged from the ablation. Also with a good system prompt GLM 5.3 flash doesn’t really refuse tasks for me.
not at all!! is grate!!!
I would have the same question. I have tested a few abliterated models in the past, and it’s hard to explain it concretely but looking through their reasoning, they often get damaged through the process. The reasoning is just worse. They also looped more.
But right now GLM 5.3-F doesn’t loop at all, so maybe that part will only be a minor difference.
I really love the EXL3 model, so always looking forward to more optimization for it though. Still just using entrpi’s engine. Too lazy to switch and it’s been rock solid, but looks like a lot of people are starting to optimize speeds even further so it’s been tempting to try swapping. But I’m more concerned about quality vs speed in my task.
Testing it now but MiaAI__Lab hasnt release their recipe for it yet. However, still will test it on my own. Here are my numbers running non oblate glm 5.3 flash on tensorfold vs vLLM. Significant improvement but this could certainly be optimized further.
| vLLM (before) | TensorFold (now) | |
| Single-user speed | ~21–23 tok/s | ~50 tok/s (startup self-test: 57–66) |
| Reading prompts | ~1,000–1,500 tok/s | ~1,600–1,850 tok/s |
| Restart | 8–10 min | 85 seconds |
| Context | 524K | 1M shared across 4 users |
I’ve tested Mia recipe with Qwen3.8 Flash but for now its unstable, it’s fast but there re 2 issues : If there is 1 image in the conversation each turn will get 5s-10s of ttft and I already got a dangerous garbage in a simple conversation (I’ve just said Hi and then than you and he started to run commands and to speak in Japanese…), without theses issues it’s the first time I obtain a really fast ttft (less than 0.3s) and the decode speed is really good (more than 50tok/s in prose for french).
Unfortunately Mia never fix the issues in the recipe he only publish and go to others recipes maybe someone else will fix that or the fix will be on the Tensorfold branch
| Test | vLLM before | TensorFold after | Gain |
| Code | 43.9 tok/s | 58.7 | 1.34x |
| Prose | 26.7 | 45.3 | 1.70x |
| Structured/JSON | 28.3 | 79.6 | 2.81x |
| File edit | 25.5 | 81.6 | 3.20x |
Here’s our non oblate recipe we’re running, feel free to copy and improve. Certainly an upgrade from vLLM. GitHub - TechGuardCoders/glm53-tensorfold-spark-recipe: One-command install: GLM-5.3-Flash on 2x NVIDIA DGX Spark with TensorFold + DFlash2. ~100 tok/s JSON, 4 users at once, measured evals. By Tech Guard. · GitHub
Here’s one that someone I know put together and I’ve been testing
And here is Mia’s
Can you run a tool eval bench, so we are all comparing apples to apples ?
With : tool-eval-bench --base-url http://0.0.0.0:8000 --seed 42 --backend vllm --perf --spec-bench
All the efficiency gains lately are really incredible. Imagine what Sparks will be capable of in another year! This is what open source and retail availability does compared to everything being locked down and only available through specialty sales channels.
Will Tool-eval-bench work with Tensorfold?
Reach out to @serapis and ask if it can be tested or easily integrated? There are a few other engines popping up recently as well.
With all the focus on speed of pp and tg, I am more interested in concurrency / large KV pool, as well as stability. Fast is great, but won’t help if it crashes all the time and can only sustain 1~2 streams
As long as it provides OpenAI-compatible endpoints, I would think so? I’m not sure about the tool calling though, but it would be pretty useless if it didn’t.
Does it just use the standard EXL3 variant that both entrpi and Mia are using already in their VLLM distributions? If so, definitely up for trying it. Does anyone know what the default model location is for this one, so I can create a soft link beforehand?
GLM53_TF_EFFORT_FIELDis unset, so a top-level OpenAIreasoning_effortis ignored. Thinking and effort go throughchat_template_kwargs. The server default is thinking off. The template writesReasoning Effort: LoworHighwhen that is the effort, andMaxotherwise. Requests that omittop_kstill sample withtop_k20 (temperature1.0,top_p0.95 from the checkpoint, then the server default).temperature0 is greedy.
Looks like it has a weird (well, weirder) way to set the reasoning effort field, too, which is pretty important to note.
I might wait until someone puts together a more polished version with more extensive testing tbh. I need quality more than quantity for my use.
