DeepSeek-V4.1-Flash-1017 TensorFold + VLLM Recipe
Sharing this as I’ve had a chance to get DeepSeek-V4.1-Flash-1017 working on dual sparks on both today.
Tensorfold decode on c1 is excellent! Vllm wins for aggregate currently.
One recipe to run either.
GitHub - x00byte/DeepSeek-V4.1-Flash-1017-Dual-Spark: DeepSeek V4.1 Flash 1017 on dual DGX Spark: TensorFold and vLLM recipes, matching Engrams, and C1–C8 thinking off/75 prefill and decode metrics. · GitHub
Update **18/10/2026
Some nice performance tweaks last night. Heres current baseline
Tuned TensorFold on two GB10 systems. Thinking off, temperature zero; code, prose, structured output and prefill each ran separately, with two isolated passes.
Generation, aggregate output tok/s C1 C2 C4 C8
Code 103.4 149.7 193.3 267.0
Prose 59.1 85.0 110.1 139.1
Structured (counting) 91.0 131.6 127.4 166.5
I am running under the previous recipe and it is slow. I will give your tensorfold recipe a try later.
welp…there goes my saturday night…
Try the new tweaks I put in this morning. Tensorfold is zoooom :D
Are there TEB numbers? I figure it’s still early for stability reports, I’ve just managed to load GLM5.3 (T recipe - technigmaai/glm-5.3-flash-gb10-tp2-native @ 24ba8fb) on my dual GX10 and it’s quite solid so far. My workloads are mostly electrical engineering design space exploration
Running all morning but to be honest I think for my own workload 8 agents heavy prefil multiturn, its not holding a torch to GLM or Qwen currently. Single Agent is good (And I like trying the latest + greatest to then realize what I had was good enough) its pretty fast but multi agent with heavy prefill its choking! VLLM with Qwen Flash, Or GLM 5.3 FP4 with adaptive drafting is just in a whole other league for usability imo.
Honesty and experimentation efforts appreciated. So far GLM5.3 seems to be the sweetest spot for a dual Spark for my workloads. I’ve burned a weekend setting it up, I’ll give it a rest keeping this thread under watch :)
then i am gonna keep an eye out , , i am also stastified with GLM 5.3 and hasitant to switch , if i need speed i use QFN
