vLLM code
# SPDX-License-Identifier: Apache-2.0
import torch
from vllm import LLM, SamplingParams
if __name__ == "__main__":
# Sample prompts.
prompts = [
"Hello, my name is",
"The president of the United States is",
"The capital of France is",
"The future of AI is",
# Create a sampling params object.
sampling_params = SamplingParams(temperature=0.8, top_p=0.95)
# Create an LLM.
llm = LLM(model="/root/xiaobin/Qwen3-8B")
# Generate texts from the prompts. The output is a list of RequestOutput objects
# that contain the prompt, generated text, and other information.
outputs = llm.generate(prompts, sampling_params)
# Print the outputs.
print("\nGenerated Outputs:\n" + "-" * 60)
for output in outputs:
prompt = output.prompt
generated_text = output.outputs[0].text
print(f"Prompt: {prompt!r}")
print(f"Output: {generated_text!r}")
print("-" * 60)
run nsight system to get report.
nsys profile -o report.nsys-rep --trace-fork-before-exec=true --cuda-graph-trace=node python test.py
Why can not get cuda information in nsight system?
