EndopJetson.zip (507.1 KB)
hello 1256645363,
it looks due to alignment issue, you’ve to set the width alignment to 64.
hence, please try scale the frame into 384x200 for your use-case.
Thank you, 384*200 displays correctly. It seems that when scaling, the width being a multiple of 64 works fine.
There is another question: Based on the actual use case, we are considering scaling from 1920x1080 to 1440x960 because the extra areas of the sensor do not have video stream data. Is there a way to achieve this?
hello 1256645363,
you may using nvvidconv to crop the redundant region.
here’s sample pipeline for your reference,
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=2592, height=1944, framerate=30/1, format=NV12' ! nvvidconv left=300 right=2200 top=100 bottom=1800 ! xvimagesink
