• GTX 1070
• DeepStream 6.2
• TensorRT 8
• NVIDIA GPU Driver Version 525
• questions
I am using the VehicleMakeNet and VehicleTypeNet models from: deepstream_reference_apps/deepstream_app_tao_configs at master · NVIDIA-AI-IOT/deepstream_reference_apps · GitHub
Their config files are this:
[property]
gpu-id=0
net-scale-factor=1
offsets=124;117;104
tlt-model-key=tlt_encode
tlt-encoded-model=../../models/tao_pretrained_models/vehiclemakenet/resnet18_vehiclemakenet_pruned.etlt
labelfile-path=labels_vehiclemakenet.txt
int8-calib-file=../../models/tao_pretrained_models/vehiclemakenet/vehiclemakenet_int8.txt
model-engine-file=../../models/tao_pretrained_models/vehiclemakenet/resnet18_vehiclemakenet_pruned.etlt_b4_gpu0_int8.engine
input-dims=3;224;224;0
uff-input-blob-name=input_1
batch-size=4
process-mode=2
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
network-type=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=predictions/Softmax
classifier-threshold=0.2
Also they have the .caffemodel files, so I use opencv to load their caffemodel files. Here is my code:
import sys
import cv2
import numpy as np
from scipy.special import softmax
model = cv2.dnn.readNetFromCaffe("resnet18.prototxt", "resnet18.caffemodel")
img = cv2.imread("test2.jpg")
img = cv2.resize(img , (224, 224))
mean_values = cv2.imread("mean.ppm")
img = cv2.subtract(img, mean_values)
img_blob = cv2.dnn.blobFromImage(img)
model.setInput(img_blob)
output = model.forward()
print(output)
labels_filename = 'labels.txt'
labels = np.loadtxt(labels_filename, str, delimiter=';')
print(labels)
probs = softmax(output, axis=1)
pred_label = labels[np.argmax(probs, axis=1)]
print (probs)
print (pred_label)
however, I did all the tests with more than 10 cars. It always output the wrong restults. I checked the file “mean.ppm”, it is the same value as “offsets=124;117;104” in the deepstream config file. Why can’t I get the correct result by using opencv to call caffe model directly?
