TLT ResNet18 classifier don't get proper predictions in DS
• Hardware Platform (Jetson / GPU) 1080 Ti
• DeepStream Version 5.0
• TensorRT Version 7.0.0.1
• NVIDIA GPU Driver Version (valid for GPU only) 450.80.02
• Issue Type( questions, new requirements, bugs) bugs/question
Hello, I’m train the model using TLT - ResNet18 simple classifier. It works perfect with tlt-infer or with clear TensorRT app. But when I try to use it inside DS pipeline as secondary model it doesn’t work.
I’ve use the following config and preprocessing parameters as described there.
[property]
gpu-id=0
net-scale-factor=1.0
offsets=123.67;116.28;103.53
model-color-format=1
infer-dims=3;224;224
uff-input-order=0
uff-input-blob-name=input_1
batch-size=1
model-engine-file=resnet18_version2_classifier_bs_1_res_224_fp32.engine
labelfile-path=labels.txt
#force-implicit-batch-dim=1
output-blob-names=predictions/Softmax
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
process-mode=2
network-type=1
#classifier-async-mode=0
classifier-threshold=0.0
#input-object-min-width=64
#input-object-min-height=64
operate-on-gie-id=1
operate-on-class-ids=0;1;
gie-unique-id=4
output-tensor-meta=1
I can’t get proper predictions inside deepstream app. I get rare predictions and class_id=0. I add tensor-meta to see predictions, and predictions/Softmax layer even not listed in probe.
I try default sgie1 model config_infer_secondary_vehicletypes.txt and get all detections and see predictions/Softmax in probe:
[property]
gpu-id=0
net-scale-factor=1
model-file=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleTypes/resnet18.caffemodel
proto-file=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleTypes/resnet18.prototxt
#model-engine-file=/opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b1_gpu0_fp16.engine
#int8-calib-file=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleTypes/cal_trt.bin
#mean-file=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleTypes/mean.ppm
labelfile-path=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleTypes/labels.txt
batch-size=1
network-mode=2
network-type=1
classifier-threshold=0.01
input-object-min-width=128
input-object-min-height=128
operate-on-gie-id=1
gie-unique-id=4
is-classifier=1
#scaling-filter=0
#scaling-compute-hw=0
I’ve tried the same configurations for my model and don’t get any result also:
[property]
gpu-id=0
net-scale-factor=1
model-color-format=0
uff-input-order=0
batch-size=1
#onnx-file=/home/rostislav/trt_converter/res18_simple.onnx
#model-engine-file=/home/rostislav/onnx_trt_converter/export/resnet18_bs-1_res-(224, 224).engine
#model-engine-file=/home/rostislav/trt_converter/resnet18_engine_classifier.buf
model-engine-file=/home/rostislav/tlt_data/resnet18_version2_classifier_bs_1_res_224_fp32.engine
labelfile-path=labels_grocery.txt
network-mode=0
process-mode=2
network-type=1
operate-on-gie-id=1
gie-unique-id=4
Could somebody explain me how to correctly setup sgie classification model for deepstream pipeline and which preprocessing parameters should I use for TLT model inside DS?
Refer to
/opt/nvidia/deepstream/deepstream/samples/configs/tlt_pretrained_models/deepstream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt
and
/opt/nvidia/deepstream/deepstream/samples/configs/tlt_pretrained_models/config_infer_secondary_vehicletypenet.txt
Hello @Morganh,
Thanks, I’ve tried such configurations. And found out, that with
process-mode=1
I’ve got strange detection and class_id=0 predictions from classifier all the time (probably due to using whole image).
When I’ve set process-mode=2 I’ve got nothing. Why?
I’m using python wrapper, and my pipeline is pgie → tracker → sgie
Please try to run with above mentioned config file and default models.
and
Then compare the models/configs with yours.
Thank you, I’ve found the problem.
My model return only 1 class_id, because labels file for classifier should be with “;” delimiters in one line despite labels for detectors, where delimiters are “\n” new line, e.g. each class in one line. It’s not obvious, and there’s no any information in doc. Even example in TLT documentation points out, that labels for classifiers should be in new lines.
Also for enable output-tensor-meta=1 I needed to set it up in config upper model-engine-file line. I don’t know why, but it works for me.
